72 or 73 Peugeot PX-10...?
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Alas, the plastic part of the nut on the other side of this broke apart when I was taking the wheel off....
Quoted: 761 Post(s)
Liked 1,563 Times
I have this idea that while I'm definitely not going to attempt at 100% vintage authenticity/accuracy, I am going to try and keep it 'French' as much as possible... Though we'll see how long that lasts when it comes to the DRs.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...yes. A lot of people get sucked into this "Keep it French" vortex. I think I got over that when Motobecane first started using Asian components on all their bikes, and their frame fit and finish was better, too. But everyone needs a direction to go in, and this is yours.
Likes For 3alarmer:
Bikes: '72 Peugeot PX-10, '09 A. Homer Hilsen, '78 Masi Gran Crit, '79 Echelon Spectra
Quoted: 104 Post(s)
Liked 162 Times
I had that same plan but then I ended up with a Super Record headset and seatpost. 3ttt bars as well. I still have a French crank, shifters, derailleurs, stem, and hubs though.
Likes For BertoBerg:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
No one will notice a high quality front derailleur in place of the original, which was never any good, anyway. The only tricky part is the "hard metric" 28.0mm seat tube OD, because most Asian and Italian derailleurs are designed for 28.6mm.
Likes For John E:
feros ferio
Liked 1,329 Times
My UO-8 with barcon cables routed between the rack and the cylindrical Bellwether front bag.
Likes For John E:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I’m allowed to ship 10,000# of household goods when I move, I think when I rotate back to the states I’m going to pack 9000# of old French bike frames and become the pro bike kit of old French stuff
Quoted: 761 Post(s)
Liked 1,563 Times
Just ship a few dozen Lyotard pedal dust caps and you'll make a tidy sum.....
Likes For ehcoplex:
Quoted: 761 Post(s)
Liked 1,563 Times
I am pretty sure I will relent on the attempt to stay French fairly soon.... $, availability, parsing general French 'oddness'! The fact that I need decent wheels will very likely be the breaking point!
Quoted: 761 Post(s)
Liked 1,563 Times
Even more than the rear derailleur, I would look into replacing the shifters. Those appear to be the Simplex Criterium made of Delrin ("plastic") and a metal sleeve. My eyes aren't so good, so maybe I'm not seeing it correctly. If those are made of Delrin, I hate those shifters, especially if they flex and have gone soft with age. Metal-bodied Simplex Criterium--or better yet, the retrofriction shifters--are a big step forward.
Likes For ehcoplex:
Quoted: 761 Post(s)
Liked 1,563 Times
Pretty much stripped/tore the whole thing down today. And so the ??s begin…
The frame tab for the clamp-on DT shifters came off in my hand, and on closer examination it appears to have been JB Welded on (assuming it had fallen off at some point in the past- surprising it wasn’t lost….). JB it back on? Have it brazed and just deal with the paint/finish issues? Do without (though it seems every bike I’ve ever seen with clamp-on DT shifters have some kind of tab, so it seems necessary..)
The Stronglight crank dust caps are really on there… I feel like I’m on the verge of stripping out the hex socket, and I’d prefer not to do that….. Gave it a dose of PB Blaster, but it’s still tight. Tips? (BTW, I’ve got the proper puller on order)
Got to get the suicide levers off the Mafacs. Anybody have a (cheap) source for the original pivots?
Those spacers in the rear dropouts….. what is the story there? Cheaper than using dropouts with adjustment screws? Did they come in different sizes? What happens if you use different size wheels…?
Purely for aesthetic debate….. Why the black-painted lugs? OK, sure, cheaper than chrome (though it looks to me like the entire fork is chromed under the paint…), but…. black?
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
....I spent a year in Italy, assigned to the NATO base in Agnano, near Naples. I brought back nothing except my personal effects and the standard duffle bag. Sometimes I wonder why I didn't bring back a bike, but honestly speaking, I was going to a Sub Tender, and I'm not sure I'd have had a place to use it.
Likes For 3alarmer:
Quoted: 1952 Post(s)
Liked 2,013 Times
Maybe I missed it. Does it fit? Pretty exciting getting that bike you wanted when you were a kid and yours will certainly be a fantastic ride on the first day out and only get better as you "restore" it: Think steel Simplex FD, Campy hubs, Tubulars, and 1972 is 5 speed. Have fun.
French BB availability is improving. There is Phil Wood and Vélo Orange.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Those threads you expose, when you finally get the caps out, are a different size, specific to Stronglight, so you need the right puller. Which is part of the adventure.
If you do strip the hex hole in the cap, the standard remedy is to drill two small holes the right size to use a pin spanner on the cap. Measure your pins on the pin wrench, because you need a good, tight fit.
Most of the Stronglight cranks I have here have no caps, I just replace the crank bolts with one of these newer style ones.
...Peugeot aesthetics is not something I would opine on. The PX-10's of this era were built to a price point, and are pretty much fun to ride. I try not to ask more. But you can certainly re-paint one without ruining an original historical masterpiece. I think mine are all stock, so I guess it's pretty durable paint.
Likes For 3alarmer:
Quoted: 104 Post(s)
Liked 162 Times
I’m into the black, white, and gold lining paint scheme. I used to think it made the bike look too busy but one day it all just clicked for me.
Quoted: 761 Post(s)
Liked 1,563 Times
Ah, well, mine is blue..... which adds a whole other element, 'cause you got the big white seat-tube decal.... I'm pretty sure the one I picked up had the original white brake cable housing (well, really old and dirty white....) and the original black bar tape. And then there's the chrome elements. And the brown Brooks....! There's a lot goin' on... But admittedly, when I was a kid the look of the white PX-10 both repulsed and compelled me- it's so visually not clean looking, but at the same time has a certain Je ne said qoui..
Quoted: 761 Post(s)
Liked 1,563 Times
Likes For ehcoplex:
Quoted: 104 Post(s)
Liked 162 Times
Maybe they could’ve done blue with silver/grey lugs instead? I still like your blue and black though.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...for some reason that is doubtless related to money and importing, I've seen very few of the 1970's 24" frames in the US, where I live. To get a 24" frame here in California, I had to buy a bike from a guy who bought it originally in a pro shop in Germany. This changed in the later 70's and early 80's...because by then I think more people buying them were demanding a more exact fit than the jump from 23" to 25".
Likes For 3alarmer:
Quoted: 761 Post(s)
Liked 1,563 Times
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Quoted: 761 Post(s)
Liked 1,563 Times
...since you are already talking fatter tyres, you can make it a little taller by building up 27" rims as the wheels, and using 1 1/4" tyres from Panaracer. This makes an acceptably light wheel for me, and is fun enough for my riding. The MAFAC calipers will accommodate 27" wheels in most, if not all cases. IIRC, that's what I did with this one. But it uses up a lot of the space for fenders, so if that's your plan, probably don't do that.
*and if I go 650b, it seems I ought to maybe cold-set the rear spacing to 130...
Quoted: 104 Post(s)
Liked 162 Times
I’m running 700x30 Grand Bois Cypres tires on my PX-10. They measure out at 32mm on my 19mm internal width rims though. They are great!
I don’t think I could fit fenders on the 32s. 30s are probably as big as I could go before running into clearance issues around the fork crown.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Quoted: 601 Post(s)
Liked 781 Times
I have been enjoying all the info on the PX-10.
Had one back in my HS days and loved the ride.
Long story short, just before leaving on holiday, I found a deal locally for the one I have attached below pictures, looks to be in outstanding condition. Will be my oldest bike and only France ride.
Look forward to pickup after new years ...
Likes For joesch:
