ISO and for trade thread part 5
#4201
I have been rebuilding my Sears fleet and expanding it with purchases so am in need. Yes, Sears.
a set of black grips that were common on 70’s models. I have brown ones so ONLY need a black set. Don’t want to substitute.
What do you want?
Looks like this...
And this. Dirty, moldy okay. No sun baked bubble ones.
What do you want?
Looks like this...
#4202
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
2 swap opportunities
Have: Campy Record one-bolt fluted seatpost 27.2
Need: Same in 27.0
Have: Cinelli 1A 26.4 stem 100mm
Need: Same in 120mm
Neither are show quality, but in reasonable shape for age. The stem, though with a little rust on the quill bolt, is the better of the two. The post has some marks below, and even a lug outline above the minimum insertion line.
Swap one or both. CONUS only please.
Need: Same in 27.0
Need: Same in 120mm
#4203
Quoted: 1088 Post(s)
Liked 1,205 Times
noobinsf , I have a few of these types of washers, but I do not know what size you are looking for., or if what you need is specific for that caIiper. I can measure the outside and inside diameters, and thickness, if you can tell us what you need, I may be able to help. I can post pics here.
#4204
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
noobinsf , unfortunately, the washers I have do not match up with yours. The inner diameter is too small and the depth is too large. When I saw your pictures I knew they were not going to match, but I measured them and it seems to me, they are just too far off from what you are looking for. Sorry I could not be of help.
Likes For delbiker1:
#4205
Liked 1,205 Times
#4206
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
noobinsf , that's awesome. I was going to stop by my LBS tomorrow to see if they had any in all the stuff they have stashed. I have a good relationship with them and have found such things there in the past that they let me have gratis. I am glad it worked out for you.
#4207
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
I have a 1985 Gitane Champion completely built up (less tires and bar tape)
Oh, and the rear derailleur won't work! Seems PO had a loose bolt on the RD that cause the tension sprint to twist up. I can't just switch to a Suntour or Shimano RD as the drop out hanger takes a smaller bolt and I'll strip the threads in the hanger. RD is a Sachs-Huret "Eco" model also shown sometimes as a Huret Eco. I am going to try to find a way to bend another tension spring to fit, but not holding my breath.
I added a photo of my actual RD and one from the 'net. Mine doesn't have the hook attachment but it's the same RD. The photo is of one for sale in Holland but there it's $7 and $50 for shipping!
** I just need the spring though if you'd prefer to trade the whole RD, I'm in
Can trade a set of Sachs Huret LUX AS double Shifters. These are NOS
#4208
Quoted: 1106 Post(s)
Liked 1,328 Times
b) looks to me as if the same spring was used in the Alvit and possibly some other Hurets. I think I have both an Alvit and a Challenger (similar to yours) and will check.
#4209
Quoted: 887 Post(s)
Liked 335 Times
ISO a Suntour AR front derailleur:
I have a butt ugly rusty functional version, but I would like to do better. Have stuff to trade or buy.
#4210
WGB
Liked 2,334 Times
oneclick Alas, genius that I am I snapped the old one. I heated it and tried to bend and snap....
#4211
Edumacator
Quoted: 2441 Post(s)
Liked 3,137 Times
I had this for sale a while back.
Likes For jdawginsc:
#4212
WGB
Liked 2,334 Times
#4213
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
If anyone fails you on the AR front, gimme a shout. I'm pretty sure I've got what you need also.
Longshot here, but I'm looking to convert, apply or build a decent 8/9/10 speed capable 26" wheelset 100/135. Got two ways to accomplish:
End goal is going 1x10 or 1x11 on this bike, to which point, if you have a suitable 10s/11s capable crank to go with the wheel stuff ....
- Find someone with a spare 36H Shimano FH-RM40-8 hub
- An 8-speed freehub that fits RM40-8 rear hub, it looks like I can retrofit, I've got the extra 5mm available
Likes For malcala622:
#4220
Quoted: 787 Post(s)
Liked 521 Times
#4222
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Force I do have a pair of Franco Italia drop bars, these are 40cm and per my digital calipers the clamp dia. is 25.27mm. If these sound like the ticket, PM me. I just happen to have a perfect box to ship them.
#4223
WGB
Liked 2,334 Times
Bumping me search for a spring for my Huret Eco RD.
Top photo shows my RD and bottom shows actual spring Ineed.
** It will take pretty much any spring from any Sach Huret RD as they were all very similar
#4224
PM me your cotters
Liked 590 Times
I have quite a number of these RD. I don't often check this thread. I may need to dig to find a mech that's "parts worthy" but definitely have something.
Quoted: 9 Post(s)
In search of a Rivendell Silver thumb shifter mount. What Riv calls 'shifter mount X' - to mount a shifter on the outside of the left side of the handlebar or inside of the right side of the handlebar. Anyone got one? Thanks!
