Official Trek FX Thread
#1076
Quoted: 119 Post(s)
Liked 23 Times
Just wondering -- has anyone adapted an FX3 to be a gravel bike/more trail bike?
I am loving my FX3, but I was thinking I want a road bike. I have 32 tires right now (kind of slick). Was wondering if I put like 35 with more tread and maybe got a more shock-absorbant seat stem, could I use this as more of a trail bike?
#1077
Bikes: I'm a Flatbar Guy
Quoted: 356 Post(s)
#1079
I have a 7.2 FX and loved it when I first picked it up new. I've had it for several years so maybe it's because I'm older now at 61, but I find the ride to be very stiff for my taste. I've tried to lower the tire air pressure, thought about trying wider tires - the tires on it are 35mm and I was considering 38mm. But I think instead I'm going to move to a more forgiving bike. My older 7.2 FX has an aluminum fork so maybe a bike with a carbon or steel fork would be better but I've been testing some with lockout front suspension like the DS line and so far I've liked the way a couple of them smoothed out my ride. Thats just me though.
Good luck with your decision!
#1080
Quoted: 23 Post(s)
Other bike im considering is cannondale quick 7. Only major difference is a chromoly fork, but 80 dollars steeper price.
#1081
Quoted: 119 Post(s)
Liked 23 Times
I added bar ends for multiple hand positions, and use it like a road bike. I do wonder if I should have just gotten a road bike, but then again, I saved several hundred dollars in getting the FX3 over e.g. a Domane, and if I compare it to a gravel grinder, many more hundred.
I am not 100% sure if I would buy it again, as I might have gone road bike/MTB duo, but if your needs are more family-focused, casual riding, or an inexpensive road bike experience, I think it's a good buy.
I'm only two months in, but I have zero issues with the bike itself. My questions are as they were when I purchased it -- which type of bike do I really want. I got the FX because it's an in-betweener, and it functions just like that. If you KNOW you want one (serious road) or the other (off-road), I would say get a bike for that purpose, but the FX is a great generalist, and could even do light touring, as others here have shown.
#1082
Quoted: 23 Post(s)
I have an FX3 with a carbon fork. I find it a bit jittery over gravel paths, but it's butter on asphalt. I think it would be better on hard pack trails if I had different tires. I have pretty slick 32s right now. (stock tires - bontrager hard case light)
Thanks for the input. I think im pretty set on getting a hybrid at this point, just stuck between which one. At 400-500 bucks I can get a decent entry level hybrid without breaking the bank, still ride hard packed trails, and go a decent speed on pavement. I want an all around bike to be able to switch between different road types, and one that I can beat up a bit and not worry too much about taking it out.
In my mind, If I stick to the sport like I plan, Ill buy a road bike in a year or two when I have more $$$ saved up, and then will have a bike for trails and one for the road. But for now, Im really strapped for cash and am just looking to break into cycling again.
Just as an example, my last bike was a big box store bike with 2 inch heavy ass tires, a crank/gears that would slip every time I tried to stand and pedal... and I would typically do ~15 miles a day on it... So a decent hybrid is a huge step up for me.
Im just not very decisisve on which one to get :/
#1083
Quoted: 119 Post(s)
Liked 23 Times
#1084
Quoted: 23 Post(s)
It felt pretty zippy in the parking lot, but not really a good comparison. Im sure the bike is much more efficient. The problem is, the engine gained about 30lbs and is totally out of shape compared to the old steel walmart bike days
#1085
How comfortable are folks here with an FX series (FX3 here) for trail riding -- compressed dirt, sand/small gravel? The trails with compressed dirt also has grass bumps and roots here and there.
This is a stock 2017 FX3 with 700X32 tires (kind of slick, but lets ignore traction for the moment).
Would you be comfortable riding an FX3 on trails like these? I've never had an alum frame/carbon fork. My hybrid before was steel.
Steel is more comfortable than alum frame/carbon fork IMO, but it's not a punishing ride. I do think it's important to at least get the carbon fork, and not go all aluminum.
I changed my stock tires to Specialized Nimbus 700 x 35 and it was a huge upgrade for gravel or dirt, while still giving good rolling on pavement.
#1086
Quoted: 5224 Post(s)
Liked 3,585 Times
I buy used so I can buy more bikes
#1088
Liked 3,585 Times
but had to play w pressure to get them to to fit!
I am actually running them lower than 60 now, 40 I think cuz they don't deform much
#1091
Liked 3,585 Times
they are 40mm tires but at max pressure measure 43mm. to get them down to 40mm had to air down to 60lbs. I experimented lower & they seemed fine, so I ride them as they are. if I wanted them harder & faster I would get the 35mm version. funny thing is only the larger sizes run larger than advertised. then the smaller sizes run true to labeled size. so I think the 35s at max would be 38mm (I think)
but really happy with them at a lower pressure. and because they don't deform (meaning bulge at the bottom) you wouldn't know I was running them at 1/2 their max pressure! as large volume tires, they have an interesting ride quality, especially at 45lbs. only started using them last spring & a tiny bit this summer. plenty fast enough on pavement. not dangerous if you wander off road onto sand, perfectly stable on grass
would like to try them on some gravel & stone dust trails I discovered last fall / winter
#1093
Liked 3,585 Times
lol yeah had a problem holding the camera w my right hand & the tape w my left hand, but if you add/subtract the mm line marks you can measure the width. I took like 12 pics & gave up
#1094
Quoted: 356 Post(s)
Glad you got the joke You got those tires in there pretty tight, does it rub at all when you're running under 60 psi ?
#1095
Liked 3,585 Times
60 was OK no tire rubbing but I didn't see any bulging so I kept going lower to see what gains I could make. with the sidewalls holding surprisingly well I went down to 45. there's even more clearance now, so no rubbing, even under torque pedaling out of the saddle
#1096
Quoted: 9 Post(s)
Hi guys, I am about to buy a 2017 Fx S5. It comes with 25mm tires. The new 2018 Fx s5 comes with 32mm tires. If I replace the tires to 32mm, will my ride become slower?
#1097
ordered a pair of continental cyclocross tires today, hopefully using it for gravel and some rides during winter months.. anyone have them on their FX?
#1098
Liked 3,585 Times
I rode 25s on my road bike on this frozen mud dirt trail with ease but it was hard as rock at 17? degrees. at softer temps I would want a wider tire
while you can run thinner on an unpaved trail the 32s & 35s are better, like on this trail (small well packed gravel) I rode my son's FX 7.1 with the original Bontrager H2 Hardcase 700 x 35 tires
so what are your intentions, plans & body weight? (meaning heavier, wider is better) aka a 150 lb guy can go anywhere on a 23 or 25mm tire but bigger guys like me (225 lbs + gear) I prefer wider especially on unpaved trails
when I hit this stuff I go to 45mm gravel tires
#1099
New member and proud owner of a new Trek FX1. I have been riding cheap bikes for so long I had forgotten how good riding a quality bike feels.
