Addiction 2022.3
#7226
Quoted: 8287 Post(s)
Liked 9,057 Times
I was hoping you'd weigh in. Thanks! The general consensus on the forum is that the key off draws on the battery are too great for the size of the battery. Unless it is commuted in every day, for a significant period of time, it doesn't charge fully. We take public transport whenever we can, because we hate driving in the city, so the car gets used little. maybe once a week sometimes. One poster postulated that if is let sit for a full week without being started, the offline draws would completely drain the battery, at least for being able to start it. I'm going to get a voltmeter that plugs into the cigarette lighter, in order to keep tabs on it. And maybe a portable jump start unit. Seems like it would be handy to have.
I still think your problem is just crappy batteries.
#7227
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Hey, datlas or any one else with a wheel-on trainer. Do you use a trainer tire and do they go bad on you? My Zaffiro Pros all develop a permanent lump after a couple of seasons. It’s a little S-like, sideways deviation which just gets worse and until the noise and bumping become intolerable. Suggests to me the thing is expanding circumferentially, maybe due to drag or heat or both.
#7228
Quoted: 1401 Post(s)
Liked 1,886 Times
A voltmeter can tell you if the voltage drops but it can't tell you why. An ammeter can tell you how much parasitic draw is on the battery. We like to see less than 50 milliamps. If it's under that number it shouldn't go down in a week. An inductive ammeter is expensive but cheap ones are available that connect in series. When checking for a draw you have to wait for all modules to go "to sleep". This might take 15 minutes. If the draw is intermittent, good luck.
And for some cars an AGM battery might be a better option
We have two Acura's with a fairly high parasitic draw - so a low end or even medium level battery will not be sufficient
Also have batteries in three garden tractors that will sit for extended periods - again a low end battery will not be sufficient
At one time I used Sears Diehard batteries with good results - but then Sears went under and don't know if the reintroduced Diehard batteries sold by (?) auto parts stores are the same high quality as the Sears Diehard batteries of decades ago
I believe the top level Sears DieHard batteries were manufactured by Johnson Controls - as opposed to Exide - but not sure (I believe both companies have been purchased and / or renamed )
More recently I've purchased Duracell batteries that (I believe) are manufactured by East Penn ; these batteries have provided good service in our cars including both cars that have high parasitic draw and also in the garden tractors that sit for extended periods
The last Duracell battery I installed is an AGM battery - more expensive and the slightly smaller size forced battery tray / hold down modifications - but the AGM battery has higher cold cranking power and will tolerate longer periods without use / more tolerant to drain
Likes For t2p:
#7229
Liked 1,886 Times
can also charge our phones with it - and with an adapter can charge / run laptop computer
#7230
Liked 9,057 Times
We had a customer with a new truck and he would let it sit for a month or more and then have it towed in. The service writer insisted I "fix it". General Motors said it wasn't supposed to sit for 3 weeks and recommended disconnecting the battery. Still had it towed in several more times after that.
#7231
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3205 Post(s)
Liked 1,845 Times
This is our first new car since the 91 Corolla. A lot has changed.
#7232
Liked 1,845 Times
This item costs $89 at amazon.com and doesn't ship to Mexico. On amazon.com.mx it costs $300. Typical. There are many advantages to living here, and a few disadvantages.
#7233
Liked 9,057 Times
The Duralast battery that lasted 22 months was guaranteed for 5 years. The point of the volt meter is simply to give warning about when it's time for a new battery. To prevent it going dead in an underground parking lot late in the day. It's something we will now plan for, rather than being blind-sided again.
If the voltage drops below about 10 volts for any reason it probably needs a jump. Batteries going dead in cars can be a real pain to diagnose. We had a $5000 computerized tester/charger from GM and it was mandatory to use and get a printout from on warranty battery claims. Even that thing isn't 100% reliable.
#7234
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Agree - some cars will not tolerate low end or even average batteries ... not for long at least
#7235
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
It’s a cool 46F but dry, time to ride!
Hey MoAlpha I use an old/worn tire. The outer tread layer is starting to delaminate at sidewall margin, but still seems functional. Maybe a few lumps but not enough to motivate me to put another tire on. I have a few worn tires lying around which will be repurposed as trainer tires when current trainer one is really shot. All Conti GP4000’s.
#7236
Liked 1,845 Times
Wordle 476 6/6
#7237
Quoted: 20810 Post(s)
Liked 9,456 Times
You don't leave the bike/trainer set-up, and the tire under roller tension, do you?
#7238
Liked 1,845 Times
I don't want to argue but I don't understand how a voltmeter can give a warning. If you have a substantial draw the voltage will drop as the car sits. You might need to jump start it but it doesn't need a new battery if you left the lights on, for example. As soon as it's running it will go up to 14 volts.
#7239
Bikes: Shmikes
Liked 5,872 Times
I used one of those Vittoria trainer tires for 5+ seasons and it still ran smooth and true when I sold it. This was pre-Zwift for me, so my "mileage" was lower, but probably still several hundred miles per winter.
#7240
Liked 9,057 Times
A battery can test good and start the car normally and go bad the next day. A battery can go dead and after a jump can work fine for months until the next failure.
They can test good and be dead every morning.
The AGM batteries are the worst to diagnose. They almost always test good, even when they have to be jumped regularly.
Likes For big john:
#7241
Liked 9,456 Times
#7242
Bikes: Shmikes
Liked 5,872 Times
If you don’t use the car much, you might consider an inexpensive solar trickle charger, which you can just put on and leave. Lead-acid batteries love to sit at a full charge and it will definitely lengthen their life.
Likes For MoAlpha:
#7243
Bikes: Shmikes
Liked 5,872 Times
#7244
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
The 2017 Fit, purchased in 2018, has lost its second battery. 70,000 km. I just came from Fit Forums, and it is a common problem. Seems the battery is just too small, and the 'smart charging' is dumb. Folks are disconnecting it and getting better life. Beware @datlas. How about you, Humbug? Battery issues?
#7245
Liked 9,057 Times
Wordle 476 5/6
Had a hard time with this word.
#7246
Quoted: 115 Post(s)
Liked 204 Times
A DTC does trigger for that disconnected sensor wire, a P!550. When I did this mod about 6 years ago, I installed in-line bullet connectors so when it was time for yearly emissions/inspections in NYC, I'd reconnect it. But I eventually forgot about it a year or so later with it disconnected and didn't have any issues passing emissions even with the P1550. We just moved to Sugar Land, TX this past July and had to get the truck inspected first before registration. Same thing, no problems even with the P1550; I was more afraid of all the modified and aftermarket performance bolt-ons on the truck would be an issue but all good there too.
Likes For primov8:
#7247
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
#7248
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#7249
Liked 1,845 Times
I hit 'reply to thread' 3 times. Re-loaded the site. Same result. I can't reply without quoting. This happens on occasion.
#7250
Liked 1,845 Times
16 back road miles. So much more relaxing. Why did it take me so long to think of it?
Likes For seedsbelize2:
