Building vintage gravel-type bike
Likes For MikeTé:
#52
Quoted: 634 Post(s)
Liked 444 Times
Really nice bike's being presented here!
What are the worthy MTB brands to look for besides Trek? I think I'm leaning more to MTB frame due to 21"+ frames being more accessible than touring 25". Also I like the point mentioned by zukahn1 that maybe MTB frame will suit more a gravel type bike and be more robust. Still I find MTB frames to be less aesethicaly pleasant than touring bikes - mainly boring paintwork (examples below).
By the way I have managed to find interesting 25" bike take a look. It's current price is around 200 dollars but the auction has 7 days left.
Nice Panasonic on Tange tubes, seller claims center-center frame is 57cm with a set of brand new continental tires. Not sure if it would be possible to fit bigger wheels there.
25' Giant Speeder, seller claims it has a little rust marks so the frame would need some work and maybe repainting.
Peugeot Mont Blanc 25'
Edit: Oops! I didn't read far enough into the thread. Looks like you bought a rockhopper. Nice work! Should be a fun bike for you.
#53
Make sure the frame can support the tire size you want/need. Also tires are not consistent regarding clearance needed. My Specialized Tricross Steel can support up to about 38-39 tires. Many of the newer gravel type bikes support larger widths. Wider tires will normally improve your ride and provide greater traction and stability.
#54
Port
Quoted: 986 Post(s)
Liked 1,871 Times
OK, is that an internally geared rear hub? And are you using a Dura Ace rear derailleur as a chain tensioner??? And mixed with a Campy Crank???
#56
Quoted: 227 Post(s)
Liked 392 Times
Here is mine:
It weighs 3 or 4 tons, but it is incredibly responsive, fits 38s with fenders and is surprisingly lively for its weight. The build surprised me quite a lot, since I wasnt sure how the drop bars would turn out, but it's a keeper for now. Gravel bike with a very nice "road bike" feel. Good luck with your build and post pics when its finished!
I stripped the paint off mine today and in one application of paint stripper it was gone. When the scraping was done there was virtually nothing on the ground!! Seeing as the frame weighs 2.5kg maybe they thought they could save a gram with the thinnest coat ever, not even any undercoat. You've done well to keep yours looking good.
#57
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
something like this old Raleigh has generous room for bigger tires ! Contemplated doing a gravel conversion with this one myself but resisted due to this bikes condition and am going with a MTB based one instead --- but theres lots of suitable bikes out there
#58
Bikes: ‘09 Ibis Silk SL, ‘08 Cannondale Synapse, ‘97 Cannondale R300, '96 CKC, '91 Batt., '86 Simoncini Cromor, '85 Allez, '78 PX10, '76 Gran Jubile, '73 Arctic, '73 Interclub, '72 TdF, '71 PX10, '70 Mondia SS, ‘90 Basso Paris Roubai
Liked 6 Times
My old commuter, an early ‘70s Gitane Interclub, recast for gravel. It’s geared low and running 650B wheels with 38mm tires.
Likes For BluePx10:
#59
Hey there! Bike finally arrived, yay!
Front wheel, steering and pedals were dissasembled for the transport so had to assemble them. Frame is in a really good condition couldn't see any damage which is good. Paint is in pretty good condition. Saddle is really horrible so it will be one of the first things to change.
Things I'm planning to change for now:
1. Saddle
2. Wheels to 27,5" (as 29" might not fit) + new gravel tires
3. Drop bar
4. New brakes
Time to do some resarch...
1. Saddle
3. Drop bar
4. New brakes
#60
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Switching wheels to 27.5" (650b) may present a challenge, as the brakes may not line up with the taller rims.
Nice looking bike!
Nice looking bike!
#61
Quoted: 1088 Post(s)
Liked 1,205 Times
1. Saddle
3. Drop bar
4. New brakes
1. Saddle
3. Drop bar
4. New brakes
I'd first focus on getting the seat to the right height, which may involve buying a longer seat post given your height. Next, read up on drop bars to decide what you want, and try to focus on bars with the same clamp diameter as your flat bars (likely 25.4, but you should measure with calipers) so you can use the same stem for now. Then, decide on brake levers and shifters, since your best options will probably be bar-end shifters or brifters. For now, leave the brakes and wheels alone, and if the tires are rideable, ride them while you dial in the fit.
#62
Why are you switching to 650b? It's going to reduce clearance, and even if you find some brakes that allow the pads to reach, keep in mind that you'll be massively lowering the mechanical advantage by setting the pads half an inch higher than intended. If you choose tires that give the 650b wheels a higher rolling diameter, you'll also be increasing trail, which is often higher than optimal to begin with when drop-bar converting a mountain bike.
#63
Quoted: 801 Post(s)
Liked 754 Times
If you had v-brakes you could some pretty cool (and pretty $$) modular brakes from Paul components, but, since they're canti...
Just stick with 26" for now.
https://www.paulcomp.com/shop/compon...akes/motolite/
I will also caution you from making this bike your end all be all bike from the get go. Swap some inexpensive things out to make it comfy, ride it for a few hundred miles, and then make a decision about where next to take it.
Likes For Piff:
#64
Bikes: Foundry Overland Rival 22, 2008 Mercier Elle 650c, Specialized Langster, 1989 Schwinn Prelude, 2017 Norco Valence 650c
This is a great idea. I would like to do something similar but old school MTBs typically had long top tubes... Seeing that I already need a very short reach (~360mm), it's been difficult to find an existing frame that would work for me.
I also second the idea of keeping the 26" tires for now. Looks like there are plenty of good choices still out there for 26".
#65
Liked 6 Times
Brakes are Weinmann 999 750s. Still needed to fabricate a drop bolt for the rear. Crank is a Stronglight TS, 52/36.
#67
Quoted: 5888 Post(s)
Liked 3,472 Times
#68
Hey guys, after few rides I decided to buy new brakes - Tektro CR720. They will be good for future testing if it's possible to use them on 650b's. Now I'm hunting for some good used saddle and drop bar.
#70
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
2 cents here. Maybe your enthusiasm for a 650B gravel bike is clouding your judgement. You likely won't benefit much from the wheel change and it's going to cost you way more money. As suggested, ride it, dial it in, spend money on great tires and the existing brakes can be dialed in with ease or upgraded cheaply.
#72
Quoted: 801 Post(s)
Liked 754 Times
To expand off of clubman 's advice
Handlebars: $20-50
Brake Levers: $20
Stem: $20
Shifters: $20
Handlbar tape: $10
Saddle: $??
Tires: $60-80
Kool-stop Brake pads: $20
1 set of brake/shifter cables/housing: $10
Total: $180-230 (not including new saddle)
That list is basically the bare minimum you'll need in order to turn your bike into a drop bar gravel grinder sorta deal. The prices are a bit conservative as well, you may end up paying more. Especially if you go for brifters. You may or may not really need a new stem, the one that's currently on there looks like it has the appropriate angle and height for this sorta conversion.
In my opinion, you should go about the conversion in this order if you are sure about everything:
1. Buy drop bar handlebars. Install and coast around a flat area to figure out if you need to buy a different stem, or if your fit on the bike feels good. If it isn't right, get a new stem that has more or less reach as your needs require. If the new stem doesn't result in a good bike fit, take some pictures of the set up and ask the forum for recommendations. If we don't have any good solutions, just drop the project, find a new bike. Don't throw good money after bad.
2. Buy brake levers, shifters (or brifters, dunno what you're deciding on), handlebar tape, 1 length each of brake/shifter cables/housing (you can reuse the rear derailleur/brake cables/housing for the front derailleur/brake), tires, and get your bike set up as a drop bar gravel grinder. Give it some good rides and figure out if this is what you want.
3. If it is, buy the saddle you want and some kool-stop brake pads. Ride off into the sunset. And on your way back, only now consider 650b wheels, and realize that a 26" mountain bike probably isn't the right candidate for a 650b conversion. I really don't think going to 650b on this bike would be worth the headache of getting the brakes to work properly. If you really want a 650b gravel grinder, a 700c touring bike or hybrid (there are some very nice 90s steel hybrids) will be your best bet.
Handlebars: $20-50
Brake Levers: $20
Stem: $20
Shifters: $20
Handlbar tape: $10
Saddle: $??
Tires: $60-80
Likes For Piff:
#73
Quoted: 792 Post(s)
Liked 1,785 Times
1. Saddle
3. Drop bar
4. New brakes
1. Saddle
3. Drop bar
4. New brakes
