#6501
Quoted: 1304 Post(s)
Liked 1,912 Times
I went to my Co-Op today for a few parts and did a bit of work while there. At the end of the day a fellow brings in a Trek 720 and donates it. It appears complete with the original components and set up for touring. However, it had bad crash damage to the front end with wrinkles in both the top and down tube. The Co-Op does not have a comparable frame to transfer the parts to. There will be a complete group available for a reasonable price if anyone might be interested. I did not have a camera with me, so no pictures. If interested in this group of parts PM me and I will put you into contact with the Co-Op. Smiles, MH
#6502
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 437 Times
Now I need to do some research into early mountain bicycles. This frame looks like something that could carry quite a lot. As in: possibly a great touring bicycle.
Likes For VintageSteelEU:
#6503
Quoted: 5888 Post(s)
Liked 3,471 Times
Agreed the Trek 830s and the 850 tend to fly under the radar as the 900 series gets all the attention. But the 830 I picked up is a nice bike with a double butted True Temper frame. I plan on using it as a loaner bike.
Likes For bikemig:
#6504
Quoted: 1952 Post(s)
Liked 2,013 Times
What do people here do when repairing metallic paint?
The paint shop (that sells paint) didn't want to sell me paint, because for measuring the color they need a bigger area. Should I just polish it a bit and use transparent paint to protect the metal against rust? Or should I just try to pick the right color from a website and have a guess?
What does the BF hive mind think and do about this?
It will be a rider, not a museum piece
#6505
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by VintageSteelEU;[url=tel:22941116
22941116[/url]]Now I need to do some research into early mountain bicycles. This frame looks like something that could carry quite a lot. As in: possibly a great touring bicycle.
89 Panasonic Mountain Cat- for illustrative purposes!
Likes For mrv:
#6506
Quoted: 215 Post(s)
Liked 437 Times
It seems the chainstays are a bit longer than on typical touring frames. What I'm actually thinking about is building a city bicycle that can withstand a bit of weight on the rack without being a bulky longtail bike. Something I can actually carry on my shoulder up some stairs if need be. And something that's obviously made of decent lugged steel I'll have to do some trawling and have a look at Panasonic and maybe Koga Miyata models from the early to mid 80's
#6507
Quoted: 1612 Post(s)
Liked 2,594 Times
Likes For curbtender:
#6508
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by VintageSteelEU;[url=tel:22942021
22942021]It seems the chainstays are a bit longer than on typical touring frames. What I'm actually thinking about is building a city bicycle that can withstand a bit of weight on the rack without being a bulky longtail bike. Something I can actually carry on my shoulder up some stairs if need be. And something that's obviously made of decent lugged steel I'll have to do some trawling and have a look at Panasonic and maybe Koga Miyata models from the early to mid 80's
Lots-a upgrades! Linear pull brakes. Paul levers. Cliffhanger wheelset. Brooks saddle!
About 25ish pounds I think. Not sure.
Likes For mrv:
#6509
Liked 1,912 Times
Building a beater bike that comes complete wit a few glitches. Schwinn World step through with 27 x1 wheels and tires. New rear wheel and then the front turns out to be 700c so building a wheel later this afternoon. I managed to get the stem, bars and rack installed, and yet to find a seat, and figure out the brake set up. Hopefully done this week with some good luck.
A quick build change, from straight bars to a bit of rise, and shortening the bars by 1" on each side. Makes for a much better posture for the rider.
Rack required a bunch of stash parts but it will be solid. Bike is set to be a single speed free-wheel with a nice city gear.
#6510
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by Mad Honk;[url=tel:22942089
22942089[/url]]Building a beater
Likes For mrv:
#6511
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
Body work on the Stratos is done, filler used was JB Weld, on to paint prep and primer.
Top tube filled small dent.
Untitled by nemosengineer, on flicker
Left chainstay filled ripples.
Untitled by nemosengineer, on Flickr
Right chainstay filled ripples
: Mike
: Mike
Booyah Hubba-Hubba!!!
#6512
Bergz
Suntour Superb Pro RD parallelogram replacement
"What God has yoked together let no man put apart..."
I had a Suntour Superb rear derailleur that had been crashed and had a bent inner parallelogram link. There was no way to straighten it while assembled and it was bent just enough to mis-align the chain cage when mounted on the dropout.
I was able to scavenge a damaged donor and set to dismantling the parallelogram links. This involved drilling 2 small holes in the knuckles and driving out the pins. Reassembly was tricky as one end of the inner parallelogram has the spring that needed compressing just so to refit the pin.
Photos should explain everything. The pins splines grip firmly when reinstalled and besides they are held captive by the cage pivot and cable adjuster barrel.
Bent inner link
Reassembly
Pin at the barrel adjuster almost fully pressed in
Completed, 2 small holes visible on top of the knuckles
Bent inner link
Reassembly
Likes For Bergz:
#6513
Quoted: 215 Post(s)
Liked 437 Times
Clearing out stuff continues. I was quite pleased to find out the wheels I built a year and a bit ago are still perfectly true. Cleaned them up, removed the old grease from the hubs, repacked with fresh one and adjusted. And flushed the freehub with some oil. These are built on Exage HB-RM50 and FH-HB50, so respectable but not overly fancy. Now I need to source another CXP33 rim and build some Ultegra Tricolor hubs I have into another wheelset to use up some more of my stash of spokes.
#6514
Finally finished a 650b conversion on Fuji S12S LTD:
Sugino triple with RSX front and Rear DR. MKS touring pedals. A nice pair of TA cages to hold the Mickey's Big Mouth bottles. 105 hubs, 2.0/1.8/2.0 Sapim spokes with CR18 rims.
Velo Orange touring saddle. Panaracer Pacenti 1.50" tires
Sora shifters. I ride the hoods a lot and like these. Crossover 'turkey wings' for city riding and out of habit.
Fuji logo bar plug. Why not?
The boring side
Now for the little stuff, like bell, pump, ODO, saddle bag, etc. A way overdue build that was prompted by a broken frame on old bike. Riding butted Chromoly is sure a nice treat!
The boring side
"It's a fine line between absolute genius and sheer stupidity"
Likes For etherhuffer:
#6515
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Allez Catastrophé
This amazing time suck Specialized Allez has cable guides. Oops. One cable guide when I got it.
I removed it and just brazed two cable stops.
my brazing prowess leaves much to be desired- much like Quasimodo was found desirable by All The Ladies…
any who. It’s done.
next up an acid bath for the frameset, as the bike neglect was significant.
i was thinking my best go at a full on restoration- then I thought-plum paint and white cables white near period correct components would better suit me!
any who. It’s done.
Likes For mrv:
#6516
Quoted: 215 Post(s)
Liked 437 Times
Out with the old:
In with the old:
I actually prefer Weinmann Carrera levers. They are slightly lighter (not much, 10g per lever), but the main thing is they do not need additional ferrules on them. One less item to displace.
Also, decided it's time to replace the handlebar tape, the old one was a bit tired. Still need to spray it with water repellent spray. I think eventually I will go with some leatherette stitched together, but don't have much time to explore this route now.
The 600EX conversion is almost complete. Only the shifter levers are newer - Shimano SL-A400 (Exage 300EX 7sp), but I don't think I actually want the SL-6208 as I read they are not very durable. I kind of got used to Suntour ratcheting ones (in Superbe / Cyclone variety) so much now that indexed shifting feels almost like a downgrade. Might go for the Dia Compe version at some point.
Now I'm just waiting for new brake inner cables and need to adjust the derailleur cable (shifters are 7 speed, freewheel is 6 cogs, so I think I might need alternative cable routing in this case).
In with the old:
#6517
Quoted: 215 Post(s)
Liked 437 Times
any who. It’s done.
next am acid bath for the frameset, as the bike neglect was significant.
any who. It’s done.
#6518
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
That sounds interesting and good to remember - I presume this method works for you?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
#6519
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by Nemosengineer;[url=tel:22942208
22942208[/url]]Body work on the Stratos is done, filler used was JB Weld, on to paint prep and primer.
Top tube filled small dent.Untitled by nemosengineer, on flicker
: Mike
: Mike
maybe that helps prevent cracking in the future. Maybe.
I’m good to give Spray.Bike puddy a try.
This Allez has a number of tube dings. Possibly from a bike carrier.
cheers
Likes For mrv:
#6520
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by VintageSteelEU;[url=tel:22944054
22944054[/url]]I can't say anything about your brazing prowess, but sure I'd love to have the skills and option.
I had an early 90s RockHopper crack around the bottom bracket, so I used that one a couple years ago to practice. And the frame builders section is fantastic. Those guys are extremely helpful and patient. As long as you’re willing to not do dumb stuff….😬
Likes For mrv:
#6521
Quoted: 215 Post(s)
Liked 437 Times
I used a my retired and rusted through Cherry race bike for practice.
#6522
Liked 3,471 Times
snip . . .
snip . . .
Likes For bikemig:
#6523
I searched high and low for a ‘gentle to the frame’ mount. I will look for a link. Made in Italy.
#6524
Look at the Topeak Versa Mount. That is almost identical to what I used. I really didn’t want to use a metal clamp.
#6525
Liked 3,471 Times
https://bikepacking.com/index/add-cage-mounts-bike/
I'm leaning towards using a metal clamp of some type. If you run electrical tape underneath, it won't scratch the paint.
Alternatively I like some the bikepacking bags that hold a nalgene bottle and mount under the downtube but they're expensive.
