Tips for riding with broken spokes
Quoted: 6974 Post(s)
Liked 10,975 Times
Quoted: 2700 Post(s)
Liked 486 Times
Sorry, both wheels were trashed, by "true things up" I meant he did some wrenching and tuning of the bikes when installing the new wheels. I got a good deal especially since I got 4 free tires (2 were installed for free on the wheels and 2 were given to me out the door because I asked for an old tire back which they threw away.) I think I was charged 75$ for one wheel, 50$ for another wheel and 100$ for labor. 50 was tax and 3 tubes. Its a high end road bike store and they gave me some of the cheaper stuff they happened to have on hand. They also realigned my mechanical disk brakes on the bike that I rode in to pick up the other 2 for free, the front was barely functional and the back was literally just zip tied to the frame after I gave up. Ooh and they swapped out my seatposts to make my 47 cm frame bike somewhat safe to ride.
I have a good relationship with the shop so they take care of me, my father is buying a carbon road bike from them so I give back in my own way
Quoted: 7653 Post(s)
Liked 3,485 Times
Liked 10,975 Times
Quoted: 2490 Post(s)
Liked 2,961 Times
If the tension is low enough, wheels can definitely suddenly fail. Especially if one or more spokes are already broken, but even without broken spokes. Saw it happen. Riding behind a guy who was on a cheapish Raleigh---when he went into a tight turn, his rear wheel was fine one moment and then instantly turned into a potato chip. His weight probably contributed, though---he must have weighed nearly 200 pounds.
Quoted: 18382 Post(s)
Liked 4,515 Times
You can sometimes get away with removing your brake pads to get home. But break 2 or 3 spokes, and you're rubbing paint, perhaps even grinding into the frame.
You can potentially rip a spoke through the rim. So now you've gone from a $2 repair to a $100+ repair.
Liked 3,485 Times
Sorry .... I tried .... but even after a cup-and-a-half of coffee I just cannot take LarrySellerz seriously anymore.
Maybe if i still drank bourbon or something .... but not worth it.
Liked 10,975 Times
Quoted: 8287 Post(s)
Liked 9,064 Times
A few years ago I was riding Ksyrium wheels and a spoke ripped out of the rim. These were the wheels where the nipples thread into the rim. I limped it along until 2 more ripped out and then I couldn't even push it. I walked a couple miles carrying the bike until someone called a cab for me.
Twice I have seen the brake track blow off of a rim on the road. Once I saw a hub split open and a spoke pulled out of the hub. On my bikes I have had sections of the rim pull away from the brake tracks.
I never raced track but I have seen wheels collapse under men and women on the velodrome.
These are just the first ones that I remember when I read your post.
Quoted: 3957 Post(s)
Liked 7,310 Times
Likes For tomato coupe:
Quoted: 970 Post(s)
Liked 1,632 Times
It's pretty simple. Ya just switch to your back up wheel set till ya fix the broken spoke.
There is no leaving it at the shop or even taking it to the shop. Ya fix it yourself. Granted the first time I replaced a broken rear spoke it took me about 2 1/2 hours. Half of that time was getting the wheel true after replacing it.
Now days its a one hour job if that. Plus the satisfaction of knowing it was done right because ya did it yourself.
Bike shops? We don't need no stinking Bike Shops... But then again I sure wish there was one close by. It would also be nice if they served Coffee and Beer... Ha
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Spokes break for a reason. On a high spoke count wheel, you could probably get away with adjusting adjacent spokes to make the wheel true and keep riding. But on a lower spoke count wheel, you are putting much greater stress on the existing spokes leading to greater chances of breaking more spokes. Key words here are "probably get away with".
Quoted: 2333 Post(s)
Liked 2,097 Times
Larry, I have not broken a spoke in ages but this is what I do. Assume we're talking the rear wheel. Widen the brakes up as much as possible. I've ridden many hundreds of miles that way when no recourse was possible. Ride slow and don't pedal hard. Evaluating individual risk is difficult because nobody knows what components are involved. YMMV
What I do generally is to have the spokes bought in advance. I carry them either on the left chain stay or if it is a pretty bike, they go inside right handlebar.
Replacing a spoke takes minutes. I cannot believe how *****ty bike shops are nowadays.
Liked 3,485 Times
It takes me more than two minutes to get the cassette off ..... and I don't carry the tools.
Liked 10,975 Times
Liked 2,961 Times
