Show your Trek Multitrack!
#726
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
Unfortunately, the 750 has been moved on, as has the 950. I found a 1990 Cannondale ST1000 and sold the two Treks to offset some of the cost. My Voyageur SP is next on the auction block. That ST1000 didn't come cheap, but I love it!
#727
Greetings all,
So much good information & pictures and great thread, I had to join. I just picked up a 1993 700 that looks like it had very limited use that still had the original tires. Looks to have been stored in a basement or garage most of its life. Tires were easy to identify from previous post and good pictures, what a great resource for identifying components and upgrade possibilities and give me reasons to support my LBS.
#729
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Very much like this! I converted my 750 to drop bars, but I'm headed to something looking like this soon.
My 1992 Trek 790. I upgraded this quite a bit from stock. replaced the headset with a sealed cartridge bearing headset from Velo and a quill adapter so I could use threadless stems. Added a stem and Salsa Bend Deluxe bars from my Salsa Marrakesh when I upgraded that to Surly Moloko bars. swapped out the shifters and brakes for XTR dual controls and V-Brakes. Built these wheels from XT 9-speed hubs and DT Swiss TK540 rims. Terra Speed 40 mm tires. XT 9-speed cassette and RD. Brooks B67. Only stock parts are the seat post, FD and crankset.
#730
Pretty excited... I purchased a 750 and it arrived last night. Today, I put it together and took it for a test ride. Smooth as silk. Anyways... i took some pics with the other Multitrack. The green 720 was purchased back in 05 or 06 for my wife, for about 75 dollars, if I remember right. Seat is low bc my 9 yr old son has been messing with it.
Just wanted to share.
Bikes: C'dale, Trek, Cervelo and Santana
Likes For Wheels4:
#731
This is my multitrack I purchased from marketplace from someone who was flipping thrift store bikes with his father. After comparing pictures on a previous post here, the tire’s look original with a rattle can paint job covering the disintegrated gum walls and overspray on wheels for good measure. This bike looks minimally used and unmolested in its past life with some updates on the horizon. I already have 40’s on it and I am looking to change the handle bars and stem to achieve a mountain bike geometry feel like my trek 4300. I’m leaning towards a gravel hybrid build and will most likely let my favorite LBS do the work. I am really enjoying all the postings of some great looking builds on this thread and look forward and welcome to any members ideas for my project.
Before any modifications.
Likes For goodwrench84:
#732
Just recently moved and the areas for me to ride have changed, so I converted my 1992 drop bar Trek 750 over to riser bars. Picked up a SRAM GX 10-Speed trigger shifter, a pair of Tektro Eclipse MT 3.0 brake levers (can be switched to/from cantilever and linear/v-brake pull), and a new brake cable set and I was good to go. I already had bars, grips, stem, and bar ends. After riding it a bit, I decided I needed a bit lower gearing, so I picked up a cheap 104 BCD crank and a narrow/wide 32T oval chainring to finish it out.
Likes For theMotoMan:
#733
I found a diamond in the rough on FB Marketplace and picked it up for my wife. It is a 1996 730, 17". It appears to have been ridden very little and was in storage for many years, although the paint did fade a little. Paid $100 for it.
This is the photo from the FB ad, but I will get it cleaned up and make a few mods to it and will repost some photos.
#734
theMotoMan, Looks like you put new wheels on it too. Those aren't original are they?
#735
Quoted: 576 Post(s)
Liked 1,003 Times
Likes For DorkDisk:
#736
BTW, your crank might have been recalled in 97. The 95 730 had the recalled FC-MC12; I'm not sure if 96 also had that crank, a quick look for a serial number will settle it.
For my '95 730, I purchased a used FC-MC16 crankset, then installed my (still pretty good) original chainrings on the newer crank arms.
#737
Great buy! That looks very, very nice.
Likes For John Valuk:
#738
#739
Nice bike, neat color. BTW, your crank might have been recalled in 97. The 95 730 had the recalled FC-MC12; I'm not sure if 96 also had that crank, a quick look for a serial number will settle it.
#740
Hey guys, I posted a picture of my wife's 1996 Trek 730 the other day and I have been busy upgrading a few things, one of which is the brakes. I am upgrading to V-Brakes from the old cantilevers. the front went fine, but I ran into a snag on the back. Instead of having a cable housing holder brazed to the back of the top tube, it has a metal tube brazed to the frame, which allows the cable to bend around the seat tube and connect to the cantilever V cable. In order to install V-brakes, I need something to hold one end of the cable housing and then the normal cable housing to brake noodle, like it is designed.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
#741
I did find a solution on YouTube and that is to install a cable stop clamp on the top tube.
Here is a link to the video:
Here is a link to the adapter on eBay
https://www.ebay.com/itm/BICYCLE-PRO...S/391667166809
I also found it on Amazon for cheaper, so I bought it there. I got the double 28.6mm one.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Last edited by theMotoMan; 02-10-22 at 10:57 AM. Reason: Add another link to needed adapter
#742
Out for a ride yesterday. It was a lovely 45 degrees F so I stopped at the elementary school to snap a pic:
The more I ride this bike the more I like it!
Likes For Smokinapankake:
#744
Lookin good! I used that exact same piece on my Raleigh Peak MTB where the cable housing stop broke off on the rear of the top tube. Has been there for years now. Good piece of kit. Nice looking 730, too. I love the color!
#745
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I used the silver single stop version on my 750 to convert to linear pull...and it's been a solid component -- no slipping, no chipping, no fading...it's a good part that'll be there as long as you care to have it there. Nice job with the conversion!
What tires are those? Gravel Kings? WTB Byways or siblings? They look nice on there.
Likes For hokiefyd:
#746
The tires are American Classic and I bought them on Amazon. $35 each. They are 40mm wide, but measured about 38mm or so.
#747
Found a 700 in the garbage. Excited to see the love for this bike.
Hello, I actually just made the count to post in this thread specifically. I’ve been a big fan of retro bikes on YouTube and been keeping my eye out in the free section on craigslist hoping to find someone giving old the bikes away. Just the other night someone posted they saw some decent looking bikes in the garbage at the curb so I took the gamble and drove 30 minutes picking up all three. There was a child’s trek learning bike, A Royce Union, and everyone’s beloved trek seven series specifically the 700 in forest green. I’m afraid I couldn’t tell you the year if you know of a place I can look on the bike and online to figure it out it would be much appreciated. Figuring the track was the better of the two adult bikes I started looking for ideas on what I could do with this. I am very excited to come across this thread and see that it’s still somewhat active. I figured the safest thing to upgrade right off the bat without scouring this thread was to upgrade the rotten tires to panaracer gravel kings. I didn’t change the size because I wasn’t sure how it works but now that I see some of your posts maybe I should’ve gotten a wider tire. Well live in learn I’ll ride these for a bit.
I plan on learning bike maintenance by doing a small tear down and cleaning its existing parts. Everything seems to be working if not a little gummed up and definitely in need of some grease. I’ll be sure to post updates here for those interested in my beginner experience and love seeing all the work you’ve all done to the series of bike.
keep being awesome.
keep being awesome.
Likes For StumblingCorgi:
#748
There is some information there on years / colors. They also have scanned copies of some Trek brochures and technical manuals.
#749
fun fact! I did not know new tires only came in packs of one. So my Panaracer tire looks great… the crumbling rear not so much. Oh well like i said, beginner bike for a beginner wannabe bike mechanic. We’re a perfect match for each other.
#750
Quoted: 141 Post(s)
Liked 9 Times
I’ve always kind of wanted one of these, and found this the other day at a thrift shop for twenty bucks. wheels are beat to crap, can’t believe I got them as strait as I did. Put some different brakes on as the originals plastic had cracked and they couldn’t be adjusted. 26.4 seat post I had seems to work well in place of the original. I’ve changed the stem and bar cause it was just impossible riding up some of the steep hills where I live. The original grip shift was pretty nasty so found some better ones in my parts bin.
just rode it twenty some miles to town and back, and I don’t know if I like it. Might have to get the stem lower and find a different saddle. Might put a butterfly bar on it. Have enough bikes with drop’s already.
It rides smooth, very comfortable on the flats.
I even like this drivetrain, it just works well.
Likes For shipwreck:
