Addiction 2022.3
#6226
Quoted: 1401 Post(s)
Liked 1,886 Times
Had a nice 60ish mile ride with the club. Some new faces and abilities all over the map. One of the ladies got bad leg cramps and walked part of a longish climb, another shouted obscenities at how difficult the climb was.
One of the women had a new Emonda and her shop installed a different saddle for her yesterday and it ended up pointing way up. Try as I might, I couldn't rotate the stupid thing inside the mast and eventually turned it around and it worked! I was pretty ham fisted with it and when I got home I looked it up and the mast is $200!
I also found a discussion where they said the thing can get stuck but I guess they just forced it. A giant PITA to save some grams.
https://i.ebayimg.com/thumbs/images/...Spp/s-l200.jpg
#6227
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3206 Post(s)
Liked 1,848 Times
lplo
#6228
Quoted: 389 Post(s)
Liked 255 Times
A couple of months ago, my new cardiologist put me on beta blockers. On my first ride of only 10 miles my heart rate was 70 or under. I quit using them and went back to my old meds. Two days ago I saw him and he was angry because I didn't follow his directions. I explained my hobby and what I wanted to do, but it was just blah, blah, blah to him. I told him I would try them again. So today, after being on them for a day, my 33 mile ride was probably my worst ever. Started out OK, felt good, then just lost ALL energy in a headwind on the way home. The internet says I should get used to them somewhat. I'm hoping so.
#6229
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
Likes For datlas:
#6230
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
Rain. Should clear out for a ride later.
Keep the chain tight!
#6231
Liked 8,930 Times
#6232
Liked 1,848 Times
Wordle 456 5/6
#6233
Liked 1,848 Times
#6234
Quoted: 18428 Post(s)
Liked 15,582 Times
Well I’m stuck inside of Frenchtown with a broken seat post bolt again.
#6235
Quoted: 8287 Post(s)
Liked 9,064 Times
#6236
Liked 9,064 Times
Wordle 456 5/6
Over thinking it again.
#6237
Liked 15,582 Times
#6238
Liked 9,064 Times
I mentioned the AC seatpost because that's the one several people have had trouble with,, including myself. On those things, it's the adjusting bolt that breaks leaving the saddle dangling unrideable. Mine broke on the top of a small mountain pass while on a solo ride. I found a ball bearing and forced it into the post to hold the saddle on enough to descend into town to find a bolt.
#6239
Liked 1,886 Times
good info on the American Classic seatpost - had / have them on a few bikes
have not seen one fail - but will now be aware of the potential issue
more recently have been using Thomson posts
#6240
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
EDIT: Because I have short femurs for the length of my legs, I tend to run my saddles pretty far forward, so zero setback posts work well for me in many cases.
#6241
Liked 11,923 Times
I wanted to give all my bikes more saddle time, so I started choosing one bike a week to ride for all my midweek rides, while still reserving the Litespeed or the Canyon for long Sunday rides. A couple weeks ago, it was the Schwinn Circuit's turn. That's the 22" (~55-56cm) one that's too small, but which I fitted with a 130mm stem and long seatpost to make it fit, but that leaves the bar 2cm lower than any other bike in my stable. And a couple hard rides, with lots of time in the drops left me with lower back spasms, so I decided I needed one that fit. So I bought a 23" frame with no fork, but with a Sante BB, AND a 24" frame with fork and most of a Sante headset but no BB. I found a local builder who can cut and re-thread the fork to fit the 23", so last night I took the 22" bike down.
Here are the 3 frames, side by side, from the smallest to the largest. The largest is a 1988 Circuit, which was a different color (bright red vs candyapple red), but otherwise the same. The forks are in the front.
And here's a pic of The Mighty Schwinn, as I named the 22" Circuit. Requiescat in pace. When I build up the 23"frame into a bike, it'll have to earn a new name.
#6242
Quoted: 10238 Post(s)
Liked 5,189 Times
Just went to pick up my new bontrager shoes and they don’t fit. I am a size 42, I checked my foot measurement while I was there, but these shoes are significantly more narrow than the XXX and I don’t know why. I would have thought they would keep the shoe fit the same for all of their shoes. Anyways, order a 42.5 to try, but I’m not convinced. The toe box area was super tight.
#6243
Liked 8,930 Times
My friend who works for that startup company that makes a computer which sounds like a jumping marsupial now works for a bigger company that sounds like spam since the big company bought the startup. He has to go to South Dakota tomorrow to do some work with a power meter company which has the same name as Deep Space 9’s most famous Ferengi….anyway I did ask him, while he is there, to peek into the dumpsters and if he sees a PM size 175, to snag it for me.
With my luck he will only find a half-filled bottle of vodka.
#6244
Quoted: 9656 Post(s)
Liked 6,366 Times
#6245
Liked 8,930 Times
#6246
Liked 6,366 Times
#6247
Mostly Harmless
Bikes: Have two wheels
Quoted: 13720 Post(s)
Liked 4,533 Times
#6248
Liked 8,930 Times
I was speaking with a clubmate today on today's ride. She had been having all types of "problems" with her drivetrain, not shifting right, skipping etc.
She took it to the LBS. Turns out she had not changed her chain in over 3.5 years!! And this person rides about 5K miles/year. She was complaining that they had to not only change the chain but the cassette and chainrings and RD pulleys. I told her chains are cheap, and to use a ruler to measure and change them when they get beyond say 0.75% and/or at LEAST yearly.
She said only "a few" of her cogs/chainring teeth were really shark-finned. I advised that any is too many. I hope she gets it now.
#6249
Super Modest
Liked 4,621 Times
#6250
Liked 11,923 Times
