Marking puncture on tube
Location: Was born and raised in Philadelphia, PA. For the past 30 years we have been living in Fort Smith, AR
Bikes: Two road bikes, Zanes and Specialized.
Quoted: 31 Post(s)
So, I always patch my flats. A lot of the group riders just buy new tubes! Never had a problem with a patched tube. HOWEVER, I do have a problem with after I find the hole, marking the spot so I can patch it!....I've tried pens, felt tipped markers, pencils, you name it, can't find anything that marks the tube so when I take it to the kitchen table to prep the hole I know where it is........What do you guys use? Went to Walmart and a car parts store, nope, they don't have anything.....
Thanks
Lloyd
Thanks
Lloyd
Quoted: 2953 Post(s)
Liked 3,106 Times
I put my thumb over it.
Draw a large cross on it with chalk, then rub the bit you need for the patch to roughen it up and add glue, what's left of the cross will point to the hole
![Big Grin](images/smilies/biggrin.gif)
Likes For cambiker71:
LET'S ROLL
I think some flat repair kits come with a small chalk(Rema?).
I just use a pen that writes/works:
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4383 Post(s)
Liked 3,054 Times
If it's a really tiny hole, sometimes I'll poke it into a bigger hole so it's easier to patch.
In my garage I have some twisty ties that I can wrap around the puncture area for fast locating - I'll save the tubes up and patch in bulk.
Quoted: 31 Post(s)
Quoted: 31 Post(s)
Quoted: 31 Post(s)
Hmmm....I'll have to look at that idea...thanks
Quoted: 31 Post(s)
https://www.youtube.com/watch?v=w-0p...aIoDLA&index=8
Quoted: 31 Post(s)
SuperGimp
LET'S ROLL
I think some sharpies/markers come in a sliver color; maybe you can try those.
Was just about to Google it; but decided to check here in my office drawer. I have an opened box of Rema Tip Top
TT 01 Tour repair kit. Most of the stuff inside are gone/used. But on the side of the package; in addition to 5 patches, 1 sandpaper, 1 glue - there should have been 1 chalk.
working on my sandal tan
Quoted: 3874 Post(s)
Liked 2,578 Times
I use a ballpoint pen which shows up decently under a good light regardless of the passage of time. One thing I'd like to pass along is that instead of circling the puncture, I draw a big and wide "+" through the hole. That helps me center the patch in case I didn't make a big enough circle.
![Thumbs Up](images/smilies/thumb.gif)
Likes For ThermionicScott:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Do you guys really carry chalk, sharpies, pens and toothpicks on rides?
I always know where the hole is without carrying any of those things. I put the tube in the garbage can and the hole is right there with it.
-Tim-
-Tim-
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 683 Post(s)
Liked 788 Times
The silver Sharpie works well when I patch at home. I seldom need to patch on the road, but when I do it's usually a large enough hole that it's easy to find. If it's not visible but you can feel it, keep some air in the tube, spread the glue over the area, and the hole will show up nicely as a whitish bubble.
Likes For andrewclaus:
Bikes: canondale silk trail--92 schwinn criss cross--sun atlas x type--fugi odessa--2018 trek domane ALR5 disc
Quoted: 47 Post(s)
They make tire chalk. It writes well even on wet tires or tubes. Your local auto parts should stock it. Use the big cross as others have mentioned so its easy to center the patch over the hole.
Quoted: 83 Post(s)
I carry a patch kit to use in a pinch but I also carry a spare tube and use that first. I almost never need a second tube so I patch the tube when I get home and it goes back in the kit. At home, the conditions are better and I can take my time doing a good job. I don't mind patching them and to me, it's actually kind of enjoyable.
Liked 3,106 Times
Quoted: 31 Post(s)
I keep the tube inflated. Rough up the spot. Inflate the tube some more. Put the glue on while the air is still "pi$$ing out". The glue bubbles where the hole is and you can still see the spot when the glue dries. And that's how I locate it hole.
The kits cost about £1 so if you've used the glue once throwing it away for another kit is simple enough.
![](https://cdn.dotcomgiftshop.com/sites/dotcom.pleasetest.co.uk/files/styles/uc_product/public/Bicycle%20Puncture%20Repair%20Kit.jpg?itok=HJwQ8rHM)
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
I use a marker and draw a large cross with arms extending far away. Then after I operate on the center the arms are still there and I can trace back where the puncture was.
It's MY mountain
Liked 3,054 Times
(or one spare tire for the tubular wheelset)
I've had three flats on the same ride TWICE in 35 years of riding... I can live with those odds.
Likes For DiabloScott:
