ISO and for trade thread part 5
#5126
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
Here's one of those minor-yet-important irritants that puts an entire project on hold. Open to requests for any couple of small items that I might have in exchange. I need two rear axle spacers. Could be either 2mm or 3mm. Yeah, I could probably run down to Ace and get something close or buy some of the pure gold ones I see for sale online, but figured I'd check here first.
#5128
Quoted: 177 Post(s)
Liked 313 Times
Looking for one each of the following:
Simplex brake cable clip
Weinmann brake cable clip
Brake cable adjuster screw and nut for the first generation Carrera sidepull brake.
1st generation Carrera
I have extra DuraAce and Shimano cable clips as well as $$.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
#5129
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Has the nut but minus the screw.
PM me if you want it.
#5130
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
https://philadelphia.craigslist.org/...512370946.html
https://images.craigslist.org/00n0n_...t2_600x450.jpg
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
#5131
KillBosby144
RE: 600 Toe clips
#5132
KillBosby144
RE: 600 Toe clips
regards the 600 toe clips. Let me know if you're still looking.
#5133
Not positive if this is truly C&V, but here goes anyway.
Looking for the upper fixed race (e.g., the part that's pressed into the top of the headtube) for a Tange Levin CDS headset. Can't find one online unless I want to buy a complete headset.
If anyone out there has an extra upper fixed race from a Tange Levin-series headset and can spare it, please PM me. (I might also be able to use one from the Passage series, but current versions of the upper fixed race for the Passage are slightly shorter and I want to preserve stack height if I can.)
My trade parts stash is meager, but let me know what you need/want - you never know. Also have $ if it comes to that.
#5134
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
Which size?
#5135
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
ISO rear tandem hub, 140mm...
Looking for a 140mm OLD tandem hub, threaded for a drum brake, cassette (but freewheel could work, too). thx
#5138
Quoted: 76 Post(s)
Liked 41 Times
Looking for wheels, wheelset, or wheel components to have a set of 700c, clincher, 7 speed freehub, 126mm rear/100mm front. Ideally FH-1055 or 600 FH-6401 so they would be compatible with both uniglide and hyperglide, but open to being locked in to only hyperglide. It seems as though the only way to get these would be to find a vintage set, or I have to have the wheels custom built (or learn to build wheels myself). I'm trying to go the vintage route first if possible
#5139
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
If the threaded drum brake isn’t needed by ehcoplex, I would be interested in it. I might be able to convince my wife to go downhill on the tandem…
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
#5140
Quoted: 761 Post(s)
Liked 1,563 Times
I’ve actually already got an Atom drum hub (in need of restoration). I want to build up a wheel with the option of adding an Arai drum down the line if we decide we really need it. But much appreciated.
#5141
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
I have a 48h Sansin sealed bearing freewheel hub threaded for the Arai drum laced to a 27" rim. The whole thing is available or I could remove the hub. Bearings feel decent.
#5142
Quoted: 566 Post(s)
Liked 1,053 Times
ISO Suntour Thumb shifter
ISO - the mate/sibling/partner/whatever for this lonely Suntour shifter. I have $$ or random stuff in bins so ask and thou may (or may not) receive.
If you have a set of said shifters I might be a player for that too.
#5143
I have a set, and I am in Beaverton too. I will dig them out tomorrow.
I.C.
I.C.
#5144
Edumacator
Quoted: 2444 Post(s)
Liked 3,137 Times
Best thumb shifters ever.
#5145
Quoted: 761 Post(s)
Liked 1,563 Times
Let me take some measurements- the bike has 700c and cantilevers so I'm not sure if a 27" wheel would work. What's the OLD on the hub?
#5146
Quoted: 346 Post(s)
Liked 175 Times
#5147
Quoted: 1106 Post(s)
Liked 1,328 Times
Campy locknut service life: 50 yrs.
Was just snugging up the bearing on a Campy Tipo rear hub and this happened:
So I need another - would take more than one, a lot of hubs don't have one locking the FW side cone.
#5148
I recently picked up a lot of mixed chainrings. The lot included a disc rotor.
I have no need for 2 of the chainrings or the disc rotor. If you need or want them, they're yours for cost of postage.
First, the disc rotor.
Disc rotor appears to be a Formula 180mm 6-bolt rotor; It's marked "FORMULA", "FD-50697-00", and "180mm". It's also marked "MIN TH1.75mm". Cheap digital caliper says it's 2.0mm thick in the wear track (6 measurements, each taken in the pad wear track near where curved spoke meets disc showed apparent wear track thickness of 2.0mm - I had one reading of 1.9mm but could not repeat it on re-measuring the same spot repeatedly; re-measurements all showed 2.0mm.) Rotor appears serviceable to me. Disclaimer: I have zero experience with bike disc brakes, so I could be out to lunch on that point.
First chainring.
This chainring is a Shimano Hyperdrive. It's 48T, steel, and appears to be symmetric 4-hole 104mm BCD. It's marked "HG Z-48" on what seems to be the inside of the chainring (opposite side from the "Hyperdrive" label).
Second chainring.
Second chainring is a Shimano Hyperdrive C. It's 42T, also steel, and appears to be 5-hole 94mm BCD (adjacent bolt holes are a touch over 55mm apart). It's marked "I-42" on what appears to be the inside of the chainring (again, opposite side from the label).
PM me if interested. Photos provided on request.
Edited to add: yeah, I know these parts may not really be C&V. But some folks here might be able to use them, and I don't really want to put serviceable parts in a recycle barrel.
First chainring.
Second chainring.
#5150
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
72 and 74 actually.
