Vintage MTB To Upright Bar / Urban Bike Conversions
#177
Quoted: 213 Post(s)
Liked 1,509 Times
Thank you.
I like the DTH tires.
As I recall the weight is right around 550 grams each and they are a foldable tire
for what that's worth.
They roll well and I don't think I have ever flatted on them as of yet.
They also come in a tan sidewall.
I've ridden them on gravel b4 and they held up well.
However on another vintage Trek mt bike, a 950, I have the Rat Trap Pass tires and these Maxxis do not measure up to them.
The Rat Traps make a noticeable difference on a bike.
They are definitely a step or 3 above in my view.
The Maxxis are good tires. I think they are also a good value and work well for me and saved me money over the another set of Rat Traps which I cannot justify buying for all 4 of my vintage 26 inchers.
#179
Thank you.
#180
Quoted: 213 Post(s)
Liked 1,509 Times
Thanks. Pretty much in line with what I thought. I prefer black walls on my Stumpjumper and afaik the RTP’s only come in gumwall. Also I am not sure I want to put that much into this bike. DTH seems like a decent middle ground between those and the Schwalbe Big Apples I have on there now (which I like OK, but they are heavy - around 930 iirc).
are the Tioga Power Blocks.
They are also foldable tires and weigh about the same as the Maxxis DTH around 550 grams each.
I really can't tell a lot of difference between the Power Blocks and DTH in my riding.
For me they are a toss up, nice rolling , not excessively heavy and fairly flat resistant
and a pretty good value for the money.
I looked around quite a bit for 26" tires
in about that size of 26 x 2.15
that were no more than about 550 grams and that's the two best I came up with.
I would definitely be interested to know of others if someone cares to share.
I understand the DTH also comes in a fatter size like around 26 x 2.35.
By the way in case anyone is wondering
DTH stands for "Drop the Hammer "
which I no longer attempt.
#181
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Another pair of 26 x 2.15 tires I have
Tioga Power Blocks are great!
#182
Safari Master
Bikes: 84 Ross Mt.Whitney - 84 Specialized Stump Jumper - 84 Nishiki Kodiak - 86 Specialized Rockhopper - 86 Cannondal SM-600 with 24" wheels - + more project frames than I'd care to admit to
Quoted: 34 Post(s)
Liked 49 Times
New build for me - Schwinn High Sierra. 1.75 Paselas, Velo Orange Tourist bars and a good helping of shellac. I'm very impressed with the overall quality even knowing the High Sierra was a higher-end MTB back in the day. First ride ended up being a 40mi loop - it's goooood.
The 4130 frame is light, sealed bearing high flange hubs roll like butter and I like the roller cam brakes so far.
#183
Safari Master
Quoted: 34 Post(s)
Liked 49 Times
Great color choice on your paint there! You got a super nice, well balanced, sleek build here. I'm really diggin it. Thanks for giving out the 411 on your DTH experience. I've been eyeballing them for my next build for quite a while now. I have a friend with a great bike that he runs RTP's on. They're clearly unbeatable comfort wise, but he gets flats pretty regularly. Wanted to ask what your experience with them has been like.
#184
Quoted: 213 Post(s)
Liked 1,509 Times
I went with the Standard version.
Currently the listed price is $68 vs $86.
The listed weight is 454 grams vs 418 grams. (36 g difference )
I also really try to watch the budget on builds like this and it was an indulgence for me to get the pair of standard Rat Traps for $68 each which was a stretch for my budget .
I have enjoyed riding them so the extra dough outlay was worth it to me on this occasion but I cannot justify the cost on every build.
I'm not sure I could even tell the difference in a 36 gram weight savings between the Standard and Extra Light versions at my slow speeds?
#185
Quoted: 213 Post(s)
Liked 1,509 Times
Flats have been fairly rare on my Rat Traps.
The first couple hundred miles I had 3 or 4 flats on them.
I run tubes and for a while used the 'not cheap' Schwalbe tubes.
Two of the flats were tube seam separation
so were the fault of a Schwalbe manufacturing defect.
So overall I haven't had all that many flats on mine over about two years of use.
I've run them on several different bikes and guesstimate I gave between 1200 to 1500 miles on the pair so far.
They look to be wearing well and have many miles left in them.
I ride mostly on city streets.
With me flats seem to be mysterious things to pin down. I may go over a year with none and then have 3 or 4 in fairly rapid succession. This is spread over 5 or 6 rideable bikes.
My current strategy is to carefully try to access the cause of the flats,
carefully repair and remount the tire/tube
and keep an eye out for glass in the streets.
Broken glass seems to be the most often cause of flats for me as so many thoughtless dimwits seem to enjoy throwing their bottles on the streets.
With my Rat Traps I have been fairly lucky.
I have been reading many seem to have success minimizing flats by going tubeless with a good sealant .
#186
#188
Safari Master
Quoted: 34 Post(s)
Liked 49 Times
Lots of great conversions here!
This is an '85 Cimarron that was repainted by @fender1 a few years ago. Paint is starting to chip, so I'm considering a powdercoat or maybe that spray.bike stuff I see from time to time.
I swapped it out to drop bars a month ago, but that didn't last a day. The upright "cruiser" mode was just too much fun and comfortable for bumming around the neighborhood or running errands. Dynamo lighting and fenders makes this bike an option any time, day or night. I really feel like a 10 year old every time I hop on.
#189
Quoted: 10 Post(s)
I have enjoyed looking through all the posts and admiring the work you all have done. As a neebie it would be nice if more people would list all the parts they used on their bikes. It would help me and may be others by considering options available. I know some things like saddles are personal, but it would be nice have the name and model to check out, especially with so many choices. Also, websites that you recommend for purchasing parts along with Amazon. Again, thanks for the ideas.
#193
I consider myself a noob as well, and I find it much more helpful on this forum when you ask direct questions. Reply to a particular post, ask about stuff you are curious about. This crowd is always ready with pretty good opinions and answers when asked.
#194
Quoted: 4512 Post(s)
Liked 6,388 Times
#197
Maybe not "upright" bars but I feel like it kinda qualifies. Maybe more "adventure/ trekking" style I suppose. I'm in the middle of putting an early stumpy together though, will post once I get it rolling.
#198
Quoted: 213 Post(s)
Liked 1,509 Times
Nicely done photo and Rockhopper.
Two super black beauty bikes in a row.
Likes For cooperryder:
#200
