Looking for a faster 20" folding bike
Quoted: 463 Post(s)
Liked 567 Times
..i guess the numbers are not about the picture. It would appear very different in 37-451. But i would love to know how the owner managed to prepare the fork steerer tube to work with that short-clamping handlebar stem. I did that before, so i know about but i'm very curious how others did.
..sorry for OT
..sorry for OT
Quoted: 3462 Post(s)
Liked 1,470 Times
I put a Sram Dual Drive on my Airnimal Joey. That is a three speed internally geared hub that has a standard 8 or 9 speed cassette freehub. Sram took that hub out of production a number of years ago, but it is my understanding that Sturmey Archer makes one like it.
The reason that I mention this is that in high gear on the three speed hub it is in an overdrive mode. You could use a standard 8 or 9 speed cassette with a small sprocket of 11 teeth and get gearing higher than you would with a 10T sprocket on a standard hub.
But since I am ignorant of the Sturmey Archer, others would have to elaborate on that. Not sure what hub spacing you would need, the Sram that I have fits in 135mm dropouts. And this would also be an issue for your budget.
If you are racing with roadies, there is some extra drag in the hub, but I can't feel it. For recreational riding, I think that such a hub is great.
Likes For Tourist in MSN:
iti biking
It is my understanding from other posters on a different forum that the Sturmey Archer dual drive hub, although sold as 135mm wide has several locking bolts, one of which can be removed for use in a 130mm wide dropout without any issues.
Quoted: 463 Post(s)
Liked 567 Times
I prioritize climbing so top end gear-inches in the 80s is perfectly fine for my terrain and riding style. Ergo, 50t is as big as I would need and install on a 406er. I once had a folder with 120-odd gear inches at the top. That was a total waste so I went to 1x and a more limited gearing range.
I'm into climbing as well and I live in amongst some high mountain ranges. Right now my Swift is set up with 406 wheels and 56_11-42 gearing. Personally I think that maybe the 11-42 cassette is a bit more than I actually need - I did all the same mountain roads with 56_11-36 last year and it was a little lighter. That said I do like having a big ring in front. These days it's easy to get a very good spread of high to low gears on the cassette, so no need to keep it small up front for the mountain imo.
Quoted: 463 Post(s)
Liked 567 Times
Touring is not about speed, but rather endurance and proper pacing. It's more about spinning and cadence than mashing and speed. Cross a country loaded up spanning weeks and we can talk.
I've been in the area where you are, the Granada, Ronda & Alpujarra environs. I know it's quite mountainous with the highest peak in Spain. One day I hope to base myself in Ronda and cycle each day.
I actually toured with a 11-36t cogset in South Korea, and that was fine (ironically member 2_i questioned the use of only 11-36t). But for other places, volcanic places, I'd definitely need more than that.
Likes For Ron Damon:
