[Carbon Fiber] Would this bike scare you?
#152
Bikes: old ones
Quoted: 26448 Post(s)
Liked 10,406 Times
A lot of the more specious arguments put forth follow the model in this thread. Someone does a "calculation" of exactly how important weight on the wheel might be, in comparison to weight on the frame and rider. They use the commonly available equations for the acceleration force for spinning a wheel, versus the linear acceleration of the same weight on the bicycle frame. They get a relatively trivial answer. Not asking themselves whether this could be suspect as an answer, using their real world experience with bicycle wheels and tires, the question of where on the wheel this weight is added never enters the modeling. It turns out that a bike wheel, for some very practical reasons with regard to the conditions of the surfaces it travels upon, is kind of a poor design from the acceleration standpoint, with much of the weight out at the rim and tire, where it requires more force to spin. (This was the reasoning behind Moulton's designs, using small wheels.)
I forget now, but it's something like a factor of ten in difference, if you add the wheel weight at the rim on a 700c wheel, as opposed to adding it at the hub, at the center of rotation. Which is, I think, where that .3% number came from. Probably an engineer, or ex-engineer, who is used to letting the science guys do the modeling..."just give me the equations, damn it." IIRC, the actual number for requisite additional force is in the 2.5% area for something like a half pound at the rim. It's been a very long time since I bothered to calculate something like this, because aero wheels are all the rage, and they do seem to work, even if I don't use them. Offsetting advantages and disadvantages with them make them the obvious choice, when permitted in the rules for your event, and there is no drafting or quick maneuvering involved.
But all other things being equal (and they are not in this case), putting a pound of additional weight onto your bike by using tires that weigh that much more on your rims, will slow you down quite a bit more than sticking it in your pockets. Try it yourself, if you don't believe me.
How's that for mansplaining ? Good luck in your endeavors. I was a physical wreck from a lifetime of athletic abuse by the time I hit 50. Stay flexible, and remember your breathing.
#153
Quoted: 3966 Post(s)
Liked 7,383 Times
#154
Quoted: 7033 Post(s)
Liked 11,067 Times
To be fair, you've been addressing plenty of other (presumably male) posters in the same manner in which you've addressed the OP, so I wouldn't accuse you of 'mansplaining.'
#155
Bikes: old ones
Liked 10,406 Times
In an earlier post, I mentioned ordering some new cf-rimmed gravel wheels. This point was a key factor in my choice: the wheelset I ordered has the same rims as some much more expensive Specialized wheels, but cheaper and heavier (and likely more durable) hubs. As long as the hubs are reliable, I don't think their weight matters much. But lighter rims, especially when they're much wider than my current rims and hence will allow me to use a nominally narrower (and hence lighter) tire? Sure, I'll take that gain, even if it's not as high as 2.5%.
I think we all understand some of the epistemological problems with personal perception. I prefer science.
If the radius of a wheel increases 10 times, then the tangential acceleration will increase by 10 times, while the angular acceleration will remain unaffected but the torque required to displace the angle θ will be more.
https://lambdageeks.com/how-to-find-...on-of-a-wheel/
But the simplest experiment I can envision is to get some really heavy tires (not sure where you'd find tires that are heavier than your current ones by half a pound each). and mount them to your wheels. Then see how it rides. You could probably inflate the lighter tires to lower pressures to more or less the equivalent of the crummy heavyweight ones, but it will probably alter rolling resistance. So not an ideal experiment. Maybe just turn the rear wheel on a stand, using the different weight tires, and measure the required torque in each case. But then you lose sight of the real world aerodynamics. It's not a simple problem to isolate one variable like this in a complex system.
#156
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Likes For Lombard:
#157
just another gosling
Quoted: 3901 Post(s)
Liked 1,953 Times
Weight of neither the rim nor the tire will make a bicycle slower, other than the increased weight will slow it on climb, but no more than the weight anywhere else on the bike. This is really very simple, no need to do any calculations.
Why? Consider the pendulum. What determines the period of a pendulum? Only the length of the string or arm, not the weight of the object at the end of the string or arm. That makes no difference at all:
https://www.acs.psu.edu/drussell/Dem.../Pendulum.html
It is possible to prove this through calculation, but it requires calculus. Perhaps some more recent graduate than I can provide the equations.
But why is that true, anyway? It's simple. The acceleration of gravity accelerates the weight from the end of its swing. That increases its kinetic energy. It then uses that kinetic energy to propel itself up the rest of the swing, against the acceleration of gravity. At the end of the swing, it then has a certain amount of potential energy, which it then coverts to kinetic energy as it swings down to the center point. The amount of weight involved makes no difference, there's only the conversion of one type of energy into another.
It's the same thing with a bicycle rim. It's true that it's harder to accelerate a heavier rim, but then it gains kinetic energy which makes it want to continue to spin. So a heavier rim/tire combo will be harder to accelerate at the start of the sprint, but will make no difference once top speed is attained, and thus also makes no difference when holding a steady pace on the flat or on a climb. Eric F, in post 64 noticed this effect and described it very well. When one pedals OOS, especially pedaling hard, one only hammers the downstroke. Maximum acceleration happens very briefly, when a pedal is at 90° on the downstroke. The bike then rather coasts a bit until the other pedal hits that point. A bike with heavier rims will coast better and seem to pulse less, both if speed over the ground and in perceived pedal speed. Eric said that "it felt like they were pulling me along." Exactly.
Of course a lighter bike is faster on climbs, and accelerates faster, but weight is weight and it's distribution does not matter except when accelerating the bike's average speed, when we have to add a little (very little) additional energy to spin up the rims and tires. Holding a steady pace, rim and tire weight do not matter - though is the extra weight happens to improve the aero quality of that rim/tire combo, then the bike will be faster.
Those super light Helium rims came and went very quickly. Riders quickly discovered that those rims weren't faster, in fact box section rims are slower. All the pros use aero rims on climbs now. The little bit of extra weight is more than offset by the aero advantage, even at climbing speeds. Look at 2:08 for example:
As an aside: note how still the top riders' upper bodies are now. Nothing like appropriate gearing and being smooth.
Results matter
Results matter
Likes For Carbonfiberboy:
#158
Bikes: old ones
Liked 10,406 Times
...wow.
Nice talk. I stand corrected.
...wow.
#159
The usual mud-slinging fest aside, it would be interesting to see an actual study or accurate mathematical model on the effects of a 500-gram lighter wheelset acceleration from 0 to 30kph. Then run the same test with 500 gram weight placed on the bike. My guess the difference is negligible. This myth that weight at the wheels is somehow much more relevant seems like bs. That said the gyroscopic forces would be stronger giving the bike a different feel thus the perception it is slower.
Likes For son_of_clyde:
#160
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Looks pretty negligible. This isn't to 30 kph, but rather a 90kg bike/rider modeled with a constant 50N propulsive force (~828W at ~37mph) with CdA = 0.3. Rolling resistance not accounted for. Two wheel weights were considered: light set at 1500g, heavy set at 2000g. All weight concentrated at rim. EOMs used : dxdt(1) = x(2), dxdt(2) = (1/(m + 2*I/r^2))*(F - 0.5*rho*CdA*x(2)^2) with rho (air density) = 1.23 kg/m^2, r (wheel radius) = 0.343m, I (wheel moment of inertia) = mass_wheel*r^2, m (mass bike+rider) = 90kg, and F (propulsive force) = 50N. Many details were not included in this model, so it's not a highly accurate representation of reality.
And yes, I am being sarcastic. When the MTB world moved from 26" wheels to 29" wheels, people said the extra weight of the bigger wheels, tires and frame would make them really slow to accelerate and such, and as we know, that is not the case. Bike weight is sooo over-rated for anything on the bike. In fact, for off-road riding, a heavier bike (and heavier wheels) actually feels much better - again something the MTB world learned years ago.
Likes For vespasianus:
#162
Sock Puppet
Liked 863 Times
But what if the wheels were 1200g instead of 2000g?
Likes For Lombard:
#163
Quoted: 406 Post(s)
Liked 389 Times
I also still have a 26er that I ride often but also a modern 29er (Ripley). Both are fun. The wheelbase on the Ripley does impact the ability of tight trails and you definitely feel the gyro-effect of 2.6 inch tires on 29ers. I can feel it on my gravel bike as well (700x45 tires), which is the only reason to have lighter tires (maybe?).
Likes For Lombard:
#165
Habitual User
Quoted: 5006 Post(s)
Liked 8,176 Times
https://www.youtube.com/watch?v=Ux7ahP4uSNs
#166
Habitual User
Liked 8,176 Times
I ride both a 26er and a 29er. Both are hardtails that weigh fairly close to the same. To me, the difference in handling is not significant. The rollover capabilities of the 29er are definitely appreciated, however.
#167
Bikes: old ones
Liked 10,406 Times
...that's very interesting, and much more detailed a calculation than any I've seen put forth elsewhere.
One question, if you will permit me. Your first graph (above), there seems to be no difference at all in the two wheelsets, even accelerating from low speed.
I'm not questioning either your expertise (I don't know you), or your mathematics. But this seems to fly in the face real world experience, even of the staunchest "wheel weight doesn't matter" folks here. All of them have argued that it does, at least, matter in accelerating from a standing start. In fact, a couple of them took great offense at my suggestion we go back to steel as a wheel rim material. Am I reading your graph wrong, or is there some other explanation ? If I am going to be wrong about something, I'd at least like to learn from it. And I freely admit, I learned little about pendulums here.
Is 6 or 7 MPH the magic number where this weight difference no longer matters ? There seem to be no blue line values below that.
#168
Liked 1,953 Times
As climbs get steeper, and speeds continue to reduce, wouldn't gravity reduce the contribution of the flywheel/pendulum effect, so you're effectively having to accelerate the wheel again on every pedal stroke in order to keep moving? It seems to me that a lighter rotating mass to accelerate becomes more of a factor as grades increase. I'm not very smart on the theory stuff, so I'm probably wrong. When I was racing, there was a choice of light or aero. These days, there are wheels that are lighter than the old "light" wheels, and more areo than the "aero" wheels. It's like having both cake and pie!
But of course one will feel the deceleration much more on steep grades. Which is a good reason to use low gears, pedal fast, and keep the bike moving. On really steep stuff, when I've run out of gears, I prefer to sit and pedal circles. I'm not good at standing for long periods or I'd probably like that better.
Results matter
Results matter
#169
Bikes: old ones
Liked 10,406 Times
...two more discussions on this same topic. One for bicycles, and one for cars (which is pretty much where I originally learned this stuff.)
#170
Bikes: old ones
Liked 10,406 Times
...and here, for all the world to see, is the sort of writing that set me on the wrong path in this world of wheel weights.
We Can Prove Why Extra Mass on Bike Wheels Is Your Worst Enemy
#171
Habitual User
Liked 8,176 Times
No. You still get that energy back. The only way to destroy energy is to turn it into heat (brakes). The heat death of the universe . . . is something we'll never see and good on us. That pendulum without a periodic injection of extra energy from the clock works would slow and eventually stop. Why? Because of friction with the air, which generates heat.
#172
Bikes: old ones
Liked 10,406 Times
#173
Liked 7,383 Times
#174
Liked 1,953 Times
...as a physical model, there are many places where energy is lost on a bicycle. Tires, rolling resistance, aero resistance because we don't ride in a vacuum, general friction losses all come to mind. I'm not arguing your general point that in a perfected theoretical model, mass continues to go in the same direction, and at the same speed, once you get it moving. I'm just saying that in this particular case that we started out discussing, (a 112 mile tri race over rolling countryside, with 20-30 mph gusting winds), it's a much more complicated picture of how often you need to introduce new accelerative force into the system.
Results matter
Results matter
#175
Liked 7,383 Times
Likes For tomato coupe:
