Tern X30 - Second hand Question
Quoted: 8 Post(s)
I can get one for a good price, owned by one person since 2013 and appears to be in excellent condition, What risk am i running into purchasing a second hand X30 in specific? i'm basically looking for a nice bike to ride around the park on weekends, Is the ride comfortable on the X30? Would you guys recommend the model? i'd appreciate any input,
Thank you in advance.
Stay away. It's a good price because Tern had a big problem with broken frames and the recall program was spotty at best. Unless you can see paperwork proving the frame was replaced, forget it. If they tell you it wasn't part of the recall, forget it. I wouldn't trust any Tern from before about 2016 that hasn't had a frame replacement from the company.
Quoted: 8 Post(s)
Yes it's a high end model, but that frame was shared on a bunch of them. You can't just take my word for it, though, so search "Tern recall" and decide for yourself. Personally I can't do it; I was around for the whole drama at the time and I couldn't bring myself to ride that thing while worrying if it's going to snap. I think it's borderline criminal that a folding bike company had so little control of the build quality of their frames.
Quoted: 8 Post(s)
On yer bike
Tern has somewhere that you can check your serial number to see if it is part of the bad batch affected by the recall. Or if you want even more detailed info, contact the US Tern distributor. They are good guys and will give you a no-BS assessment. You can ask them for opinions/options about frame replacement.
Two problems with the old Terns. Frame may snap at hinge, and the hinge bolt may break (see the url below).
https://www.bikeforums.net/folding-b...inge-bolt.html
Quoted: 8 Post(s)
What are some other reasons you guys might advice against purchasing the x30 model? I am a novice and a newbie when it comes to maintaining a bike or any sort of bike for that matter but from what I’ve read about the ownership of these folding terns it entails just keeping the chain belt and gears lubricated just as with any bike and it should be good to go right? I shouldn’t expect any expensive repairs or anything like that right?
Quoted: 113 Post(s)
Liked 8 Times
$950 is high for a 2013 X30. There were a number of recalls on the frame extending into 2016. If you are looking for things to consider, consider the low spoke count front wheel. There were many problems with broken spokes and cracked rims. Although a very good hub, the SRAM dual drive hub is discontinued. The bike will be a hard riding bike due to the high pressure tires with limited tire clearance for larger tires due to the caliper brakes. So consider the types of roads you will be riding.
Have you test ridden this X30 for any distance?
https://www.bikefolded.com/tern-verg...ikes-recalled/
Quoted: 8 Post(s)
No I did not test drive it, what price would be considered a great deal on an x30? I plan on just riding around the park, how is 950 too high though considering the $2000+ original price tag of this model? The seller says that it’s a “rare gem” and that I won’t see one like this anywhere on the road,
Quoted: 46 Post(s)
Another perspective: I had one and found it to ride impressively... fast and responsive. Unfortunately, for my age and body (much abused 70 y.o) it was too stiff so I gave it to my son. He found the components to be of a pleasingly high quality. The frame was replaced without difficulty under warranty. My son still rides the bike when he needs access to a "folder".
I have no comment to offer about pricing.
Quoted: 8 Post(s)
I called the deal off due to the scary comments I received in the beginning of this thread so I won’t be purchasing the x30, do you recommend that I purchase a used Tern C8 for about $400? Are these prone to the recall as well? How about a used dahon Mu P8 for about $300, is that a good deal?
Quoted: 8 Post(s)
55+ Club,...
Bikes: 9+,...
Quoted: 1153 Post(s)
Liked 896 Times
There is no difference, other than mistrust of the Tern branding. Both folders are size adjustable.
Quoted: 8 Post(s)
which gearshift system is better and more reliable for casual weekend riding around the park, The one on the Tern X30 or the one on the Tern C8? I don’t want to buy the dahon I mentioned in the previous post.
Quoted: 113 Post(s)
Liked 8 Times
Here's a Tern recall on the Link series .
https://www.ternbicycles.com/2014-li...ry-recall-faqs
The Dahon Mu series has been reliable through the years. The 'P' designation indicates Dahon's Premium component group..
What model year(s) are these bikes?
What's your location? For a couple hundred more dollars, you're into brand new bikes from either manufacturer.
As far as I can judge Dahon and Tern seem to be more or less par on what you get for your money.
Dahon has a far longer history and a very confusing lineup of models, not only over the years but also in parallel and even more if you look at different countries - the same models are often not the same models, technical data ist vague (at best), plain wrong (somtimes) or missing (often). The quality seems not always to be as good as some people here in the forum claim but generally they seem to be good bang for the buck - still you get what you pay for.
Tern on the other hand wanted to be more innovative and customer oriented than Dahon. They shoot themselves in the foot with the breaking frames shortly after their market entry and their far-from-perfect dealing with that. The number of bikes affected seems to be only a fraction of their production. However - many Tern riders have been in fear for years if their bike will brake at some point. Still today I'd have no issues buying a (new) Tern, if one would suit me - I'd assume they have learned their lesson. In general Terns often seem to be slightly more expensive than Dahon and their model range is smaller. If you stay in the mainstream range of the two companies - 20" geared folders like Tern Link, Dahon Speed, Dahon Vybe Tern Verge and Dahon Vitesse they should be pretty comparable. If one of those fits you sizewise the others will probably as well.
Still even within these models quality may differ vastly depending on the submodel. But for a "ride around the park" there should be no issues with any of the bikes. The Dahon model range is very confusing - one recent addition that looks interesting if you like the Dahon/Tern style of folders is the Hemingway: DAHON Hemingway D9 20? |
Quoted: 8 Post(s)
I still don’t understand though, why is the x30 not a good buy? Isn’t it a class above the C8 and all the other midrange bikes in terms of quality? The seller has contacted tern and provided them with the service ticket number and said that they got back to him that the frame was not affected by the recall
So IF the X30 in question dates from that period I personally would stay away. So this is the first thing you should clarify: When was this thing built? (Built, not bought)
Other than that if I remember correctly the X30 is a bit of a perfomance bike which seems unneccesary for what you intend to do with it. Often the highest spec bikes from Tern and Dahon have i.e. 20-spoke front wheels which are less longlasting than the normal ones and you may face issues getting a new rim. Stuff like that. If you are willing and able to pay 950$ for your folder you could easily get a brand new one for that money that is not even close to low spec. In my eyes probably the better deal in your case. I'm more at home in the Brompton world, so I cannot provide you with specific models or experiendes with those.
Quoted: 113 Post(s)
Liked 8 Times
IMHO, a used 5 or 6 year old X30 is not a good buy at anything over $500 due to the multiple frame recalls on the X30 model. Some frames outside of the production number recalls also failed. First hand user reports and pictures were on the Tern message message site before it was revamped. All of the x30s didn't break, but enough did to cause serious concern. So you might be okay with a frame that won't fail at the hinge and break in two, but I certainly wouldn't pay a premium price on a roll of the dice.
https://www.bicycleretailer.com/reca...s#.W7j9biNVkV0
Berlinaut, you can't call people hysterical and not rational about Tern fears, then agree with them. Pick a lane.
To the OP: If you're willing to spend around $1000, you might find a nice used Brompton which would be perfect for the kind of riding you want to do. I use mine for shortish town rides and shopping runs, then fold it up nice and compact in my apartment.
