Why does one bike climb better than another?
Loaded question, I know.
I have two bikes. One is a Breezer Doppler, the other is a Novara Buzz. Both are steel, both weigh almost exactly the same, both are sized and fitted correctly for me, both have fenders and a rack, both create a reasonably heads-up riding position, both are well maintained. Gearing is similar. Doppler has 650 X 47 wheel and tire combo, Buzz has 700 x 40.
I normally ride the Doppler, but took out the Buzz today to get some mileage under the tires. The thing feels like an absolute pig compared to the Doppler. Climbing is remarkably tougher and more exhausting on the Buzz. Even a slight change in incline and suddenly it feels like I'm pulling a trailer. I'm dropping gears and burning the quads. With the Doppler I usually don't even drop gears, I just give it a little more onion and keep cadence with no problem.
What could cause such remarkably different behavior on climbs? Rotating weight is of course a big one, but the wheel and tire combos of both bikes are close in weight. Is it all just a geometry game? What accounts for one bike climbing so much better or worse than another when the normal factors are all pretty close to one another?
Quoted: 4083 Post(s)
Liked 7,671 Times
Likes For tomato coupe:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Ever notice how riding up some inclines just feels faster than you’d expect? Maybe due to the angle of the hill and how it changes your position over the bike, or the additional resistance vs power vs gearing vs hp/torque ratio…. Could be lots of things, but different bikes sometimes feel a lot different on the same section of road or trail. Sometimes the faster/smoother/more comfortable (etc) bike is not the one we would have guessed it to be.
Version 7.0
Bikes: Too Many
Quoted: 1367 Post(s)
Liked 2,537 Times
Gear inches are different for the same gear due to different wheel size. A larger wheel diameter has to travel farther for the same pedal rotation.
Likes For Hermes:
Thread Killer
Quoted: 3271 Post(s)
Liked 1,813 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
Likes For livedarklions:
Quoted: 3261 Post(s)
Liked 2,583 Times
It might be the color also. That's really important, maybe.
Likes For seypat:
Quoted: 4645 Post(s)
Liked 5,180 Times
It's mainly down to total weight and gearing and tyres if they are dissimilar.
Likes For PeteHski:
Quoted: 6392 Post(s)
Liked 4,986 Times
Even though you might be properly fitted to each bike, one just might have you in a better relationship to the BB for the position you climb in to produce better power.
Though I'd favor that you haven't gotten use to what gear you need on that bike to produce your best power since you said you don't ride it often.
If the cassettes have the same size cogs along with the same chain rings and crank length and bike weight, then that leaves the wheel diameter as the big difference too that you will perceive. Smaller wheels make the same gear ratio easier to pedal.
Everyone I know that have ridden bike with a 650 road tire say that they were more sporty handling and maneuverable compared to their 700c bikes. I've never ridden a bike with 650 road tires so I don't know.
Thread Killer
Liked 1,813 Times
I have a Doppler, and I had a Buzz— an ‘04 aluminum model— until about three months ago, and I’d prefer to say that the Doppler, which is a 30lbs stock bike, is good to climb on, rather than saying it climbs well. I think the reason it’s good to climb on is due to the comfort factor; it’s the right geo for my riding style, the 48c rubber is smooth, and the gearing is low enough for me to pedal at a comfortable cadence on most of my climbs. The Doppler feels good to me.
I particularly like the Doppler on gravel climbs, I think for the longish wheelbase, but to be clear, the Doppler does not climb fast.
Dammit, I knew buying a matte gray bike was a bad idea. It's just so....ordinary. Maybe I should try painting it a fluorescent yellow/hot pink fade and see what that does. Clearly the electric blue metallic is working for the Doppler. Krylon rattle cans, here I come!
Likes For BadgerOne:
Liked 3,174 Times
maybe one has a sharper fork? Really grabs at the hill versus pecking into it..
-YMMV
-YMMV
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 768 Post(s)
Liked 4,100 Times
![lol](images/smilies/lol.gif)
Liked 4,986 Times
Bright red or bright orange is the fastest!
Likes For Iride01:
Wanna preorder one from my Kickstarter page?
REI was never known for commissioning bikes that were exactly attractive....it's probably what they had the most of/was the cheapest in the Chinese factory. It might have been off white to start, but they left it out in the urban pollution for a week and environmental fallout turned it this color.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/784x446/buzz_fda091e0265b2e07aa1684cc26cad29ae245bea4.jpg)
Liked 3,174 Times
nah, I'm waiting on the Sharrtork. Uses a special gas for the cylinders & is supposedly a blast of an experience.
-YMMV
-YMMV
Likes For Troul:
Sunshine
Quoted: 11104 Post(s)
Liked 7,711 Times
difference in tires rolling resistance.
difference in geometry which affects feel.
difference in bike weight.
Take your pick. Probably more possibilities too.
Likes For mstateglfr:
Klaatu..Verata..Necktie?
Quoted: 10660 Post(s)
Liked 12,332 Times
Likes For genejockey:
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
Probably not a big factor here. Wide 650b tires tend to have higher volumes than narrower 700c tires and, as a result, the difference in overall wheel diameter is often minimal. Also, he never said that he has the same gearing on both bikes.
Thread Killer
Liked 1,813 Times
Ha! Mine was a matte grey, too!
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/1a8d79af_b964_492c_8227_77d8a587419d_e7268ec3bcd33aad160482cda64c3b002c478817.jpeg)
Likes For chaadster:
Quoted: 1956 Post(s)
Liked 2,201 Times
I guess it might help to know if you timed each bike up the same climb.
John
John
