Cantilever brakes for touring bike , suggestions?
Hi all ,
Looking for a set of cantilever brakes for a touring bike build . Please let me know what is powerful and good quality . Also is it possible that I could have mounting issues with an older eighties steel frame , mounts seem typical of all other vbrake and canti mounts I have seen .
Thanks ,
J
Thanks ,
J
I don't use many cantilever brakes now, I find v-brakes easier to adjust. However, the inexpensive (about $15) Tektro Oryx style brakes work very well with good pads. I have seen reviews of these brakes claiming they don't work well, but I think most of the reviews are based on the default pads. Using Salmon Kool Stop pads makes braking very efficient. I find the Oryx brakes very easy to adjust, which is nice compared to adjustments of the old style (1990s and earlier) cantilever brakes.
I have used Cane Creek SCX-5 Cantilever brakes on a couple of bikes. They were OEM on CX bike and I put them on a touring bike that I was building. Combined with Kool Stop salmon colored pads they work well. They are a good compromise between cost and quality. I switched over to Paul brakes on the CX bike which are quite a bit more expensive ( I got a heck of a deal on them). I really could not see any significant difference in braking dynamics or stopping power between the brakes. They both have Kool Stop Pads.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Liked 368 Times
OTOH ... If you have a heavy fork...MY SA XL dyno DRUM all weather brake has done 20,500 miles with a bearing change at 17,000. NO pads or adjustments needed. I hardly need anything on the rear and it is that bad, a POS caliper. I wouldn't leave home without lights either, rain, fog, shadows, early sundown.
Sunshine
Liked 8,063 Times
Hi all ,
Thanks ,
J
Thanks ,
J
If thats the case, hit up ebay for whatever was originally on the bike ans use new koolstop pads. Properly set up, the brakes will stop perfectly fine.
What bike are you setting up?
Modern tektro cr720 brakes are a wide option that are well reviewed.
I have 3 sets of diacompe/suntour canti brakes from the late 80s and early 90s. All are different quality levels (xcd, xcm, and xce) and all work great with new pads. If you need older brakes and some xcd are available on ebay, id get em in a second. They are extremely adjustable and set up easily while being an older option.
Liked 4,321 Times
Your best bet are the Tektro cr720s. Canti brakes would be my first choice on a new touring bike and the Tektros are excellent and reasonably priced.
Sunshine
Liked 8,063 Times
Ok ok not really, i just dont have any love for them unless its on a bike with a suspension fork where the vbrake is beneficial. Cantis allow for a wider tolerance in wheel trueness and dont lock up nearly as often since there is better modulation. They also allow for a wider tire and fender.
...all of what i just posted is based on my experiences riding my bikes and servicing mine and other bikes. It may be that i have experience with bad vbrakes.
Liked 4,321 Times
Here is a good discussion of why you really want cantilevers for a touring bike from R&E Cycles, Disc Brakes vs. Cantilever Brakes
I have three cycle cross bike that I built up with canti's, the one I've adapted for touring. I had Shimano R550 canti brakes on all them which have always worked fine, that is until recently, when I took another stab again at mini-V's using ProMax mini V's on the one. The jury is still out as to whether these newer mini v's really show any improvement in "stopping power" over a well set up canti's. There is a difference in feel and modulation where some might prefer one over the other but truthfully, both get the job done adequately with KS salmons.
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Liked 419 Times
CX 70 (shimano ultegra cantis), Tiagra 4400 levers (no shifting) and the cables they came with are good. The lever is very similar to old tricolor 600 levers.
Installing took a while to get my head around but it wasn't very hard.
They squeeled for a while. Now they squeal occasionally, but they've bedded in and are mostly silent.
Power/ feel is very good.
They are night and day different, especially to adjust, to the 80s dia compe cantis with kool stops on my old touring frame.
The reasonably narrow profile is nice, and cantis that extend past your racks would be annoying.
Clearance is good, but adjusted to sit close to the A719 rims on my gunnar, i can't quite release the brake cable, so i have to deflate the tires to remove the wheel. This sucks big time.
These are wide (23.5 mm) rims, and with narrower rims i think it would be fine, but it's annoying.
Overall its a very good system.
There is nothing wrong with canti brakes; they are excellent once set up correctly. They also have lots of clearance for fatter tires and fenders.
Brad
1994 Bruce Gordon Rock n Road, small frame with 700c wheels...
front= 8.5 cm
rear= 8.0 cm
Currently use Paul cantis. Originally Shimanos then Avid Shorty's. All worked fine. Frame is built for wide (45mm) tire clearance. Has a beefy MTB style unicrown fork.
front= 8.5 cm
rear= 8.0 cm
Liked 4,321 Times
Hi all ,
Thanks ,
J
Thanks ,
J
Bikes: 2016 Novara Mazama
Liked 81 Times
If you were changing out brakes and levers at the same time, which system would you go with? Plastic spring housing on my back cantis on my MTB are cracking, the fronts were just a cheap replacement when the same housings broke in a rear end crash, and the levers are bent (but usable) for that same crash. That whole system was due for replacement this winter, even before I decided to turn it into a tourer.
The older Shimano cantilevers (like this) are a tried and true design, are super affordable, and the smooth post pads allow adjustment to make just about any frame and fork work.
If it were my bike, though, I would probably go for mini-Vs, which will work with road brake levers without a problem or an ugly travel agent. The downside is that they can limit clearance for wider tires and fenders.
Yeah this can be an issue and the worst offender may be the Tektro CR 720 which I suggested in an earlier post as being a fine cantilever. It is a fine cantilever but I have had difficulties in setting it up with narrower posts found on older bikes and there are other threads on this as well. As much as I like them, I'd steer clear of them in working on an older bike.
Bikes: Bianchi San Mateo and a few others
Liked 15 Times
I'll second everything said above about the CR720's. They're great and they're easy to set up if you don't need to do much geometry tweaking -- say for narrower posts or for a change in wheel size (e.g. 27" to 700c).
For an older bike, I've normally picked up some older Dia Compe brakes like 960's or 980's. They work well, they're plenty adjustable to work with narrower posts, they look right at home on older bikes, and they can often be found on eBay in great shape.
Liked 1,585 Times
As mentioned above, the Salmon Koolstop brake pads can help you stop a loaded touring bike better than the stock pads.
I like the CR720 brakes that were mentioned above and have them on my rando bike, but they do stick out wide. On some bikes they might interfer with your pannier setup, especially in front. In the photo I have the Oryx type brakes and they do not have any problem with my luggage, but the damp laundry in the mesh bag that I have strapped on top of my left pannier would likely interfere with the CR720 brakes because they are so wide. The wheel size in the photo is a 26 inch wheel, a 700c wheel will mount the brakes a bit higher due to the larger diameter rim.
[MENTION=380714]jambon[/MENTION], I apologize for the delay...
The fork mounted posts on my two Cannondale touring bikes span 77 mm and 78 mm. For grins I checked my mountain bike and they are 80 mm apart.
The seat stay posts on the Cannondales are in the 79-80 mm range apart.
Brad
Brad
