Question on Judging a Ride's Real Training Effect
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 454 Post(s)
Liked 164 Times
I did a ride the other day in pretty hot weather (95 degrees, sunny, and NC humidity). It was 90 minutes and by the #'s (power meter) not all that intense. In fact two days prior I had done a ride of similar distance/terrain and almost 10% higher Normalized Power for the ride. That earlier ride felt 'strong' but not a big deal. And it was a good 10 to 15 degrees cooler (earlier in the day).
But today's 'easier' ride left me literally exhausted even though it was, as measured by the #'s, a pretty easy ride. So the question is was there really a 'training effect' of a really hard ride?
Thanks.
dave
Thanks.
dave
Non omnino gravis
just another gosling
Quoted: 3919 Post(s)
Liked 1,982 Times
Is one of your "#'s" a hrTSS number calculated off your HR? If you only go by a TSS calculated off power, you never know your physiological stress.
Whether or no, heat training is the best training. Always ride in the heat if you can. Sounds stupid, but it works very well.
Results matter
Results matter
For me, it is important to consciously drink more when the heat and humidity kick up - or a ride will feel really hard mainly because I'm getting de-hydrated. In the Washington DC area, that first ride when the temps and humidity are high is always a hard ride, usually can see my HR higher especially on the second half of the ride, when compared to same route done during cooler weather. A month or more of hot weather riding and on that same ride (when I drink more) my HR goes down a good deal, though not all the way back to the cool weather numbers.
I agree about the hot weather training - doing that same route when we get a break in the dog days of summer, I can definitely feel the fitness increase!
Quoted: 454 Post(s)
Liked 164 Times
dave
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
It's still work, it's still training. You can't just go off power meters alone when dew points are high, as your body is working that much harder to cool itself.
Once cooler weather rolls around, power numbers will be back up to normal (or higher).
Bikes: bikes
Liked 1,429 Times
Additional dilation of blood vessels and increased blood flow near the surface of the skin for purposes of cooling through evaporation. Particularly noticeable via an increased heart rate and higher perceived exertion for a given workload.
300 watts when it's 95 degrees is a helluva lot tougher than when it's 50 degrees.
Bikes: bikes
Liked 1,429 Times
If you don't think that there's a correlation between your body working harder to cool itself down and a decrease in athletic performance, then I don't know what to tell you.
If you want to communicate clearly, you can't start redefining words willy nilly. Work has a clear definition, your usage is not it. I'm not saying the environment doesn't affect performance. I'm only doubtful that the mechanism involves additional work (precise definition) due to cooling.
Bikes: bikes
Liked 1,429 Times
noun. 1.activity involving mental or physical effort done in order to achieve a purpose or result.
So thanks for the pointless game of semantics, but it really has nothing to do with anything.
If you're that interested, I'm sure some indepth physiology study will get you better answers than vocabulary trolling.
Bikes: bikes
Liked 1,429 Times
“the heart has to work significantly harder on a hot day versus a cool one. This usually means decreased performance that feels quite unpleasant.” -Julien Periard, a physiologist at Aspetar who studies the mechanisms limiting prolonged exercise performance in heat.
And then from the British Heart Foundation, Secondscount.org, and the cooperhealth.org blog:
Your heart works overtime to cope with the hot weather
When outdoor temperatures rise (or you move to, or travel to, a hot climate), your heart has to beat faster and work harder to pump blood to the surface of your skin to assist with sweating to cool your body.
hot weather increases the workload on your heart and the demand for oxygen, especially when you are more active.
Looks like you've got a lot of work ahead of you, agelle.
Quoted: 2953 Post(s)
Liked 3,106 Times
Quoted: 1975 Post(s)
Liked 232 Times
Try to do an FTP indoors with and without adequate cooling/fans. See if you can hit the same numbers. A power meter(and the measure of mechanical work being put into the bike) is only one measure, and an estimate of the amount of physiological work being done at a set efficiency which is affected by many factors.
Quoted: 18451 Post(s)
Liked 4,562 Times
I'm not sure if I think of a single short ride as having much of a "training effect", although perhaps a bit of a fatigue effect.
Sometimes I can feel a bit of an after-effect the day after, but if I have a rest (slow) day, the second day after is generally ok, except in the cases of extreme efforts (150+ mile rides can take a couple of recovery days, and can also have some long-term effects from a single ride).
Anyway, if you had a couple of days rest, then I'd attribute a hard or easy ride on weather, mood, food, wind, etc.
Liked 232 Times
physiological work is the work done by metabolism of energy stores, and can be measured directly through oxygen consumption/respiration. Efficiency is as you guessed. Which we estimate is ~25% for converting power meter work to calories burned but varies person to person and with conditions.
Quoted: 18883 Post(s)
Liked 10,646 Times
Quoted: 3856 Post(s)
Liked 1,078 Times
https://www.outsideonline.com/209855...-training-heat
Studies have found that, in addition to an increased rate of perspiration, training in the heat can increase an athlete’s blood plasma volume (which leads to better cardiovascular fitness), reduce overall core temperature, reduce blood lactate, increase skeletal muscle force, and, counterintuitively, make a person train better in cold temperatures. In fact, heat acclimation may actually be more beneficial than altitude training in eliciting positive physiological adaptations, says Santiago Lorenzo, a professor of physiology at Lake Erie College of Osteopathic Medicine and a former decathlete at the University of Oregon.
Non omnino gravis
Thanks.
dave
Thanks.
dave
As to whether it'll increase your FTP or something of the like, probably not.
Quoted: 454 Post(s)
Liked 164 Times
dave
ps. Thx, W4B
