Quality Engineering and Construction from Wally World
Had this beauty roll into the shop on Saturday. Wanted to know if we could fix it.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,451 Times
Check in the adhesives aisle.
Likes For nomadmax:
Likes For Milton Keynes:
Quoted: 1514 Post(s)
Liked 735 Times
Not sure what I'm looking at. Looks like a suspension pivot? Which tube broke out? You know the famous WallyWorld guarantee:
"if it breaks, bring it back and we'll replace it with another just like it."
Likes For BlazingPedals:
Mad bike riding scientist
Quoted: 6262 Post(s)
Liked 4,284 Times
The edges look like they are machined. The pivot probably pulled out (red arrow below). The welds on Helmart bikes are about as good as you'll get with JBWeld
Untitled by Stuart Black, on Flickr
Stuart Black
Stuart Black
Likes For ljsense:
Liked 735 Times
Thanks cyccommute, that gives me a better idea of what I was looking at. No way the tubing should be that thin in that spot regardless of how good/bad the weld is.
Liked 4,284 Times
Steel tubing for bicycles is around 1mm thick. The tubing in the picture looks like it's in that range. I think the problem is that they cut out the hole for the shock mount. I would assume that most mounts like that are welded to the tube without cutting a hole in the tubing. For a really cheap HelMart bike, I would think it would be cheaper. Cutting tubing is an extra step and you have to weld all the way around the mount as well as align it.
Stuart Black
Stuart Black
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
Looks like the bracket holding the shock mount was welded to the tube, and the weld weakened the tube wall such that it tore out. I don't think it was cut by the manufacturer, the tear is in the shape of the weld.
To OP: I hope you immediately told them you couldn't fix it, or quoted an FO price of $4000 or something.
Likes For Wilfred Laurier:
Bikes: my precious steel boys
Quoted: 438 Post(s)
Liked 603 Times
oh, the old days of the Costco warranty replacement. I'm almost positive you could literally take the product out of the box, break it in front of them, and they'd still give you a full refund back then. I think they had to stop that because people were doing stuff like buying giant TVs and returning them for Super Bowl parties.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
Feature, not a bug. It's the optional spare pencil storage compartment.
Tragically Ignorant
Liked 9,099 Times
Maybe it struck an iceberg?
Likes For livedarklions:
Quoted: 3409 Post(s)
Liked 5,594 Times
Likes For Shimagnolo:
It looks like it is one of these bikes (or one with a similar rear suspension system) https://www.walmart.com/ip/Genesis-29-Abstract-Men-s-Bike-Black/144049425
It's obviously poor engineering, because a failure like in the OP is bound to happen when the rear shock bottoms out hard.
Quoted: 626 Post(s)
Liked 701 Times
After welding any metal (Ti, Al, or steel), unless it's non-structural, and very very few exceptions, there needs to be a post weld heat treat/stress relief, or the weld process itself actually weakens the metal locally. I'm guessing they skipped that step, or simply don't do it when they are cranking these out of their factories.
There is a spec that we use in the aircraft industry that the shops must follow, or bad **** happens.
Quoted: 1070 Post(s)
Liked 803 Times
Better still is products from Flex Seal https://www.flexsealproducts.com/
Liked 3,089 Times
i'm not shocked, not shocked at all..
-Oh Hey!
-Oh Hey!
Quoted: 1002 Post(s)
Liked 237 Times
But what kind of chain lube was on the bike?
That makes all the difference.
