What does 26x1.5/559 mean?
559mm is the diameter that the tire bead sits at. This is the same as the "26er" wheel size that dominated on older mountain bikes.
1.5" is the nominal inflated width of the tire (inflated tire width can vary a little depending on the width of the rim it's mounted on).
So this tire mounts on a 559mm BSD ("26er") rim, and it inflates to around 1.5" wide, which is about 38mm.
The "26" is a marketing term very roughly based on the diameter of the inflated tire, in inches. But be careful:
https://www.sheldonbrown.com/26.html
Likes For HTupolev:
Bikes: old ones
Quoted: 26475 Post(s)
Liked 10,440 Times
...it's the standardized bead seat diameter. In your picture, for that size rim, it's 622. But that's a 700c rim, so the diameter is bigger.
Droid on a mission
Quoted: 320 Post(s)
Liked 283 Times
There are several versions of 26" tires. The 559 is diameter of the tire in mm
Here is a link that might help you understand this
https://www.modernbike.com/iso-sizes-for-bicycle-tires-and-rims
It is what I consider the most common size of 26" tires
Really Old Senior Member
559mm = 22"
Add a nominal 2" of tire top & bottom and you have 26".
See Sheldon-
https://www.sheldonbrown.com/harris/tires/index.html
See Sheldon-
ETRTO is an international standard so tires fit rims made by someone else .. tire bead seat diameter 559-40 is another way to say which 26" x 1.5"..
Mad bike riding scientist
Quoted: 6255 Post(s)
Liked 4,280 Times
The ETRTO size would be 38-559
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 2026 Post(s)
Liked 1,096 Times
ETRTO is the European Tire and Rim Technical Organization. ETRTO was the organization that brought standard nomenclature and defined sizes to the chaos of bicycle wheel and rim sizing in the past. A while ago the International Standards Organization (ISO) took over the job of defining bike wheel standards from ETRTO so you will see bike wheel sizes stated as ISO sizes which are identical to the older ETRTO sizes. So an ISO 622 rim is the same as an ETRTO 622 rim.
Likes For HillRider:
Quoted: 1439 Post(s)
Liked 1,094 Times
Likes For dsbrantjr:
Quoted: 6319 Post(s)
Liked 4,908 Times
You have a tire that has that on the sidewall? Please post a pic. This will be the first time I ever will see a bicycle tire manufacturer prominently display something useful for tire size. Though not a true ISO size, it sure helps!
26" diameter ?
Outer circumference of the tire. But only very general and rough. Width of tire can very the circumference a lot. There are 26" tires that won't fit your wheel. So it's really a useless number to know. More to do with marketing and salespeople that aren't technically or engineering oriented.
1.5 tire height
Roughly, also roughly the width.
What is the 559 ?
BSD Bead Seat Diameter if you know this number you are well on your way to determining what other tires may fit your rim or what rims will fit the tire.
26" diameter ?
1.5 tire height
What is the 559 ?
