Rim width question
Quoted: 43 Post(s)
Liked 30 Times
Rim width question
I’m in the market for a wheel upgrade and the wheels I’m looking at are slightly wider then what’s currently on the bike. The bike has side pull caliper brakes and the new rims would be 3mm wider than the stock wheels. I’ll transfer over the tires since they’re new. Is it safe to assume that with only a 3mm increase in width that I can adjust the brakes to fit? Thanks.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,299 Times
Yes you should be able to adjust your brakes to fit
Quoted: 4231 Post(s)
Liked 3,940 Times
Generally yes, a 3mm added width should be no issue. BUT if your rims are already at the caliper's limit then even 3mm will be a problem. This we can't say as we don't know enough yet or we are not there.
I will add that this is an issue for those who have calipers that were designed around the 23mm tire/20-22mm rim (outer) widths that were so common just 5+ years ago. People want to get fashionable by replacing their wheels with the current wider ones and are finding their calipers no longer have enough travel to allow the QR to fully function. Just one more "cost" of having been in fashion those 5+ years ago Andy
AndrewRStewart
AndrewRStewart
Quoted: 43 Post(s)
Liked 30 Times
Current rims are 19mm wide and I’m looking at something in the 22mm wide range. It appears that the trend is for increasingly wider wheels as many of the wheels I’ve looked at are 25mm and wider.
Quoted: 6325 Post(s)
Liked 4,915 Times
Rims can handle much wider tires typically than what came on them originally. Don't know what your bike is, but for most road bikes, the rim is likely more that wide enough to safely fit the widest tire that also can fit in that frame. For other type bike.... I can't say.
edit.... yes I should have refreshed my memory with the original post before replying. Instead I focused only on the OP's reply to another and forgot that there was a reason given.
Last edited by Iride01; 10-23-20 at 09:19 AM. Reason: being humbled by my own realizations.
Quoted: 3306 Post(s)
Liked 2,146 Times
Quoted: 43 Post(s)
Liked 30 Times
I’m looking to upgrade my wheelset, so the possibility of having a wider rim. Tires will stay the same as I’ll transfer them over to the new wheelset.
Mad bike riding scientist
Quoted: 6256 Post(s)
Liked 4,280 Times
Basically, 1mm is tiny. 3mm is 3 times that but still very small. You shouldn’t have any issues adjusting your brakes to the proper width.
Stuart Black
Stuart Black
Quoted: 1954 Post(s)
Liked 2,199 Times
My only concern if you are going to mount a 25mm tire on a rim with a 22/23mm internal width if the rim is too wide for the tire.
Most charts show a rim closer to your 19mm as the maximum width.
John
John
Quoted: 645 Post(s)
Liked 797 Times
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
The other thing to consider is that if you need to switch to another set of wheels (such as, you go to take the bike out and discover a flat) you can't without first re-adjusting the brakes.
