Issues: Class II rear hitch tray rack into class I receiver
Hi.
I have a 2015 VW Golf TDI and can only find class I undercarriage receivers to fit it (11/4" receiver). They state the torque limit is 200lbs. Before I decide on an undercarriage receiver of the two I can find that will fit my car (from Draw Tite), I want to ensure I can find a rear, hitch-mounted dual tray bike rack that will fit the class I receiver. So I find that there are several rear tray racks that will fit the class I 1.25" receiver, BUT either the receiver or bike manufacturer may install some sort of stop so you can't insert these class I tray racks into the class I receiver. I've reached out to Draw Tite to see if this is the case for either of the available receivers I am looking at. In the meantime, I have several questions I can't find answers to:
1) I have read it is easy enough to shave this stop off, but that you shouldn't so you don't kill kids when your rack snaps on the freeway from overloaded torque. How do I calculate my total torque weight to the receiver in addition to just the weight of the rack + bikes (which is def under the 200lbs. weight stated by the manufacturer)?
2) I am doing this all super on the cheap as a grad school student so will be looking for the cheapest receiver and rack I can find that is still safe and responsible to others. I am wondering if it is EVER safe to put a class II rack into a class I receiver, whether I have to shave off a stop or not. I know lots of people do it because it is possible, but aren't you running the risk of your rig falling off at some point?
Any suggestions besides recommending super spendy products are welcome, thanks!
I think I know nothing.
I think this is a really bad idea but...
https://www.etrailer.com/Hitch-Adapt...tch%20Adapters
The people at etrailer.com really know their stuff. I would speak to them on the phone, explain your situation, see what they say. What’s possible may not be wise and we live in a litigious age. You won’t be a poor grad student forever.
SE Wis
Liked 3,428 Times
are you confusing tongue weight with torque weight?
Most hitches are rated as "tongue" weight which is he dead weight on the ball (ie how much the trailer weighs at the hitch). The only place I've seen "torque weight" being an issue is when using extended hitches.
Extended Hitch Calc
Extended Hitch Calc
Hi.
Any two bike tray rack sized for a 1 1/4" receiver will be within the class I tongue weight limits and will work with your hitch. I'm not sure what you mean by a "stop" to prevent insertion, classes I and II both use 1 1/4" receivers but differ in ball diameter . For reference I have a Mazda CX-5 with a factory receiver hitch and a Kuat Transfer 3 bike rack that works correctly with my cars 2000 lb max tow rating. My rack also includes a sleeve to work with a 2" receiver and if that is shipped installed on your rack you would have to remove it to use in a 1 1/4" receiver
Thule and Yakima make racks that will fit both 1.25" and 2" receivers.
This is my Thule rack that fits both the 1.25 receiver 2" receivers. I have 2" receivers on my Subaru and my Truck. I got this particular rack because our touring bikes have fenders. It secures the bikes to the rack by clamping the top tube not the wheels.
![](https://live.staticflickr.com/65535/49660532092_766065950c_c.jpg)
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Liked 812 Times
Get the 1.25 inch hitch if that's all you can find..then buy whatever bike rack that gets you what you need at the price you want to pay. If you need a 1.25 inch too 2 inch receiver adapter..get it. You may need the extension to get the rack away from your car anyway.
No worries on using a 1.25 to 2 inch adapter..zero..nada..not one...for a bike rack. You'll never get close to the 200# rating. The adapter isn't meant for towing..at least rational people wouldn't tow with it(beyond a super light kayak trailer or some such thing). .
Likes For fishboat:
I also use a 2" extender now with my Kuat Transfer 2 as that is the only way the rack will clear the spare on my Jeep. No problems whatsoever.
Just make sure the extender is securely fastened at each end.
It's not. I used one of those for a number of years carrying 3 to 4 bikes at a time. Used it for both local runs and long distance drives. Never a problem.
Exceeded rated limits always works just fine, until it doesn't.
No, it's a really bad idea. The text on the extender clearly says that using it will HALVE the rated weight capacity. It was 200lbs, that drops is 100lbs, which is pretty trivial to exceed considering most racks weight 30-50lbs empty. Yes, it'll be fine with a carbon road bike or two, but toss a couple of hybrids or a single ebike and you'll easily exceed the limits.
Advanced Slacker
Liked 2,557 Times
Here is a 2” hitch receiver that will fit your car:
https://torkliftcentral.com/2015-201...-golf-ecohitch
For bike racks, 2” racks have advantages over 1-1/4”. Get a 2” receiver if you can.
Avoid adapters or extenders if you can. They add more points of play and slop.
Likes For jennc:
SE Wis
Liked 3,428 Times
https://motoiq.com/project-mkvi-golf-tdi-lets-tow/
Liked 3,208 Times
towing rating in the US on cars is mostly BS anyway.
-YMMV
-YMMV
SE Wis
Liked 3,428 Times
For what it is worth. The hitch on my focus has one of those stupid tabs on it so I drilled it out. I did it because I run a 1up rack and couldn't insert it as far as I would have liked, doesn't use a pin. Drilled that tab out and now I can slide the rack in so it is tight up against my bumper when folded up and more secure to boot. Think a lot of people in here are confused about the difference between a class 1 and 2 hitch.
"Class I and Class II hitches both have a 1-1/4 inch receiver opening. The difference is that a Class I hitch has a lower tongue weight rating, usually 200 pounds and a lower towing rating, usually 2,000 pounds. A Class II hitch usually has a tongue weight rating of 350 pounds and a towing rating of 3,500 pounds."
The tab is in there to prevent people from using class 2 required dohickies in class 1 rated receivers, class 2 things slide in further. I'm sure there are some out there but I don't know of any 1-1/4 bike rack where any of this matters.
Bottom line is if you do not exceed the tongue weight of the hitch you are ok. Canker is correct, the tab on the draw bar is there so a class 2 drawbar in not put into a class 1 hitch. As long as you know that, and don't exceed the max rating you are good to go. For the record, I was one of three engineers that designed the hitches at Draw-Tite back in the late 80's. Every hitch we designed went through V-5 dynamic load testing. Assuming they still do this, there is a LOT of safety factor built into the hitch...
Liked 3,208 Times
