10 speed to 11 speed hub upgrade
Quoted: 142 Post(s)
Liked 34 Times
Want to upgrade my 10 yo rear rim from old 10 speed Shimano to a new XT compatible 11 speed cassette. I can think of the two options:
- Get the complete hub unit with disk mount and QR, new spokes (or maybe reuse the old ones?) and re-lace/true the wheel?
- Get the hub body only, ball bearings kit, spacers and replace and service the old hub
Quoted: 18447 Post(s)
Liked 4,559 Times
Is this a "Road" cassette or a "MTB" cassette?
For cassettes with < 34T large sprocket, the 10s and 11s Shimano freehubs are not compatible. And you'll have to replace the entire hub.
For cassettes with > 34T large sprocket, they work fine on 10s freehubs. Nothing to replace. They come with a spacer to use on 11s freehubs (you don't need the extra spacer).
Quoted: 454 Post(s)
Liked 104 Times
So what do you currently have? Take it its an MTB hub from what your saying, MTB 11 speed is the same spec freehub as 10/9/8 speed MTB, it only changes when you go to 12 speed and microspline
If road, you could just get a R8000 11-34 which is a 11 speed cassette which will fit onto a 10 speed road hub.
Would avoid any idea that involves re-building a wheel for what your proposing, as your going to take working parts effectively replace so much that you may as well have just bought all new. Also, unless you can build wheels already, really would suggest that it's not really worth it today, factory wheel for MTB are so cheap (relative to the components needed to build a wheel & good quality) that unless you have the skills needed/ a source of cheap parts/be prepared to wait it's just easier and cheaper to buy off the shelf factory wheels
Likes For jimc101:
Quoted: 142 Post(s)
Liked 34 Times
This is what I am up to:
https://www.bikeforums.net/bicycle-m...te-anyone.html
That's a lot of chain capacity from FD and RD, don't have any choice but to use MTB XT derailleur and an 11s MTB cassette.
So... AFAIK the old Shimano 10s freehubs are incompatible with 11s. Also, 11s freehubs for road and MTB are incompatible too. Not sure if I can buy a wheel that fits a hybrid bike with MTB XT hubs, for cosmetic reasons would prefer to have matching wheels.
Are there any decent quality wheels under £100 that match the description?
Liked 4,559 Times
A 10 speed freehub will work fine with any 11 speed cassette with 34T or larger for the large sprocket "MTB".
The difference between 11 speed road and 11 speed MTB is the road freehubs are wider. The MTB cassettes will still fit on the road freehubs, but will require a spacer.
Obviously you'll also need to upgrade your shifters to go to 11 speed.
Lots of info about shift ratios here:
https://en.wikibooks.org/wiki/Bicycl...ing_Dimensions
Somewhat complex info, but 10s and 11s MTB derailleurs have the same shift ratio, and may be interchangeable..
Likes For CliffordK:
Quoted: 142 Post(s)
Liked 34 Times
What spacer do I need to make it work?
Quoted: 1872 Post(s)
Liked 1,748 Times
Oh... I now understand what you and others mean by 34+ MTB cassette fitting the road 10speed hub. For some reason the Shimano compatibility chart doesn't mention that option, I think you are right though.
https://youtu.be/VqS4uPhV3mw
Likes For alcjphil:
you can run 12 speed too you just have to get a cassette where the small cog is an 11 instead of a 10. The 10 tooth cog is what takes the special freehub with shimano and sram. Sunrace makes 11-whatever cassettes in 12 speed that will fit fine.
Likes For Canker:
