Ear protection when pumping tires
Quoted: 2731 Post(s)
Liked 488 Times
Do any of you have like having hearing protection the pumping a tire? Recently ive had multiple blowouts (I sometimes get frustrated/rushed when patching tubes and reinstalling) and I have some anxiety around pumping tires up to pressure. Im pretty anal about hearing protection at work, and my ears have rung from blowouts, thinking of getting some earplugs to wear. Ive even been holding back on the pressure and keeping it at around 100-120 when I really want to be running 140+ on most tires because I just don't trust it not to explode.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
No, and 140 is ridiculous.
Likes For livedarklions:
Quoted: 3597 Post(s)
Liked 3,016 Times
140 is fine, but learn how to seat a tire properly.
Liked 488 Times
I recently got a pinch flat (snakebite doesn't lie) on my rear tire that I pumped to 120 the same day, was hauling easily 40 pounds of groceries so the total weight on the bike was well over 300 lbs. 140 on 23-25 rims is not crazy or abnormal considering the weight
Tragically Ignorant
Liked 9,099 Times
You say so. I wouldn't put 300 pounds on 25s if I had a choice.
Make sure you're putting a bit of air in your tubes before seating the tire, and make sure the tubes aren't being pinched after seating before inflating.
...Maybe use wider tires, if they'll fit.
Likes For HTupolev:
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Slow is fast. Take the time to ensure that the tire is mounted straight and the tube isn't caught anywhere under the bead, and then you'll have more confidence taking it to full pressure. Earplugs aren't a bad idea, sometimes I stick them in if a tire needs a little extra pressure to seat.
Likes For ThermionicScott:
Liked 488 Times
Why do you guys think wider tires for heavier riders are ideal? Ive heard this but never understood it. I ride 23s just fine, my father also runs 23s and he is like 220-230 so a little smaller than me (262 currently) but still....
Quoted: 1607 Post(s)
Liked 1,796 Times
Try this, available in Walmart. Reusable, comfortable, and easy to clean and I use them to sleep when it's noisy.
It's also recommended for use in the shooting range. If gun users can use them, it can certainly work for exploding bike tires as well!
Likes For koala logs:
Liked 488 Times
Because I want to be fast? Some of us dont trust the Big Gravel narrative that wide tires at lower pressure are just as fast as thin tires pumped up hard. Its really perverse frankly and its ruining your sport and nobody cares. its really sad tbh
Likes For LarrySellerz:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
So wear protection if you're paranoid about it; I don't see why its popularity is relevant.
Klaatu..Verata..Necktie?
Quoted: 10529 Post(s)
Liked 12,105 Times
As for why wider tires for heavier riders, because they compress less at the same pressure, so you don't have to pump them rock hard to avoid pinchflatting.
Likes For genejockey:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 449 Times
LOL ....ruining the sport ?? ..... and just the dozens of thread on tire pressure on BF shows that many people actually do care. There is some pretty good data out there that says that for your average rider a wider tire at lower PSI is faster up to a certain speed. I use the wider tires because a 32 at 70 psi is both faster and more comfortable for me that a 25 at 120 PSI. A lot more comfortable and quite a bit faster BTW.
Also if you need hearing protection from blowing out so many tires you need to work on your tire mounting skills.
Heavy, fast, 23mm that's suicidal bro. You'll end up slower to your destination anyway if you're flatting often. But the critical issue here is safety.
ignominious poltroon
Quoted: 2280 Post(s)
Liked 3,503 Times
Liked 12,105 Times
As far as hearing protection, try pumping the tires to 40-60 psi, then checking all around both sides of the rim to see that the tire is seated properly and you haven't left any of the tube pinched between the rim and the bead. THEN pump it the rest of the way. I've been doing it that way longer than you've been alive and have had zero blowouts from pinched tubes.
Liked 12,105 Times
Add to this that TdF riders are also riding wider tires at lower pressures, and achieving higher speeds.
What would your Scientist coworkers think of you if you told them you were denying empirical data to favor wishful thinking?
Advocatus Diaboli
Quoted: 4761 Post(s)
Liked 1,542 Times
So, in one post you say you've pinchflatted 25s even at your ungodly high inflation pressures, and then you say you ride 23s just fine. Choose an opinion and stick with it.
Liked 488 Times
Liked 3,016 Times
I'll ride 23s or less until I'm ready for some upright fuddy-duddy bike with upright bars, a massively-wide gel saddle and wide mushy tires--or a wheelchair, whichever comes first. What size tires do you recommend for the wheelchair, if you don't mind me asking?
Liked 12,105 Times
PV = nRT. It's not just a good idea. It's the Law.
Liked 12,105 Times
I pinchflatted 25s because they were underinflated for the type of riding I was doing (hauling groceries.) I needed 130+ in them, and frankly in terms of historical tire pressures this isn't even abnormally high. Back in the day much lighter people went to higher pressures. Thin tires for heavy riders are perfectly fine as long as they are inflated properly
Shawn of the Dead
Quoted: 277 Post(s)
Liked 449 Times
Have fun on your 23s. I ran mine at 120-130 for years and the whole set up about rattled my teeth out. 32s at 70-80 psi are smooth as butter and fast. Far faster than my bikes with 23's and 25's.
Likes For Rdmonster69:
