My FnHon Gust 16", 2023
Quoted: 547 Post(s)
Liked 659 Times
Following the completion of the Tour-de-Korea 2023, I disassembled the FSIR Spin 3 bike that accompanied me on tour, and moved many of its parts to an incipient, incomplete build I had on hand. With the infusion of parts from the FSIR, a new bike quickly coalesced, an impromptu melange of mostly used and some new parts: a Blue Chameleon FnHon Gust 16" with ETRTO 305 wheels.
New to this build are the following parts:
- Avid Single Digit 7 brakes and brake levers
- Shimano Ultegra BBR60 bottom bracket
- Litepro chainring, crank-arms and headset
- Promend removable pedals and handgrips
- Aceoffix alloy front block mount
Likes For Ron Damon:
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 207 Post(s)
Liked 253 Times
Very nice colour. Can you fit mudguards on this frame?
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 463 Post(s)
Liked 413 Times
What is the gear-inch range on this setup?
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Quoted: 547 Post(s)
Liked 659 Times
After installing the cabling, chain and grips, the Gust 16" is now road-ready and operational.
Likes For 3speedslow:
Likes For GeezyRider:
Nice looking bike!
Likes For Pine Cone:
Quoted: 839 Post(s)
Liked 255 Times
Bikes: There is always room for one more.
Quoted: 193 Post(s)
Liked 403 Times
Zizzo has cloned the Brompton front block as well. I think compatibility/standardization in cycling components is good for the consumer.
Don
Don
Likes For FLYBYU:
Likes For FLYBYU:
Quoted: 547 Post(s)
Liked 659 Times
Change log
- Swapped tires to Schwalbe Big Apple 50-305
- Swapped to 53T chainring
- Installed new seatpost
- Installed new pedal straps
- Installed electric bell
Quoted: 139 Post(s)
Liked 52 Times
Yeah...you may be out of luck then regarding weight. On a related note, I'd say to stay away also if you are taller than 175cm. It's not really a bike for taller folk. And yes, paint and weld finish as well as hinge quality are all very good. For the price - I paid $170 towards the tail end of the pandemic - it's a no-brainer, really.
Quoted: 547 Post(s)
Liked 659 Times
Change log
- Installed fenders
- Swapped cogset to Shimano CS-M4100-10, 11-42T
- Installed new QR skewers
- Installed condoms on brake levers
Quoted: 547 Post(s)
Liked 659 Times
Change log
- Replaced front and rear fenders with longer ones.
Working tire pressure on a mix of urban terrains, 2.00" tire (nominal), no luggage load and my own 71kg frame: 30psi front / 40psi rear
