SP Dynamo Hub Fail: I became a statistic
I probably put 10,000km (6,000 miles) on the hub in 2.5 years. I really wanted a 28h rim brake wheel for my randonneur bike so that meant SP or SON (Shimano only in 32 and 36 as far as I've ever seen). The complete build was already adding up for my budget so I opted for SP. It started seizing up on a bike tour in Spain this summer.
SP hubs are warrantied for 2 years. I know SON have a 5 year warranty and I'm sure some of them have failed too. I am also aware that they will service hubs to an extent. I know that no bearing and no electrical component lasts for ever, but 2.5 years? And yes, technically the hub can be taken apart, bearings extracted and replaced, and hub reassembled. But you have to de-lace and then rebuild the wheel to do that. You can't pay anyone to do that. The labor rate would cost more than a SON hub. And none of that is happening on a bike tour, unless maybe you're in a country with much cheaper labor rates than in Europe and more adventuresome bike mechanics with nothing else to do all morning or day.
Also, years prior I had a SRAM dynamo hub. You'd think I'd have learned my lesson after that one failed in probably 4-5 years. At least the bearings just started developing play, not seizing up on me. And I rode significantly less during those 4-5 years.
Now I'm salvaging a Shimano hub from a 700c wheel and building it up for this 650b bike on a 32h rim. My next dynamo is going to be on a gravel and touring/bike packing bike so I figure I'll go with the SON given that it'll be put to hard use.
I've heard stories of other riders doing way more and difficult miles per year than me, so I don't think it's me or my riding style. They're on SON hubs now that I think of it. I think the problem is me being a cheapskate.
Any other SP statistics out there? Anybody have experience with failed Shimano or SON hubs? Does anyone preemptively replace or send their SON hub in every 5 years of heavy riding?
Randomhead
Liked 3,802 Times
I have a Shimano with failed bearings. You can take them apart, but the way it feels I think the races are probably gone. I feel like that lasted a lot longer than 6000 miles. My most recent dynohub purchase was an SP. So far I have been lucky with mine. It is a little concerning to hear of early failures
Likes For unterhausen:
Quoted: 2650 Post(s)
Liked 2,006 Times
Likes For pdlamb:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1267 Post(s)
Liked 341 Times
So how many times have you replaced brake pads at $15 a time, 5? 10? ?? LOL
ZERO on mine. My SA XL-FDD pads have 32,000 miles and are good for another 5,000 I guess. I did have to make a longer pull arm this year.
The elec side sealed bearing went dry at 17,000 miles. 4 of the 10 balls got crunched and sucked into the magnets. Was still rideable.
Took it apart myself, no problem. My lights are always on.
There is ZERO chance of it failing and it's 1/3 the cost of the SON.
Likes For GamblerGORD53:
Randomhead
Liked 3,802 Times
I have an older SoN that seems to have failed bearings. I bought it used from someone that also thinks it needs to be repaired. My LBS sent it to Peter White to have the bearings replaced and he sent it back unrepaired. Said it was fine. I'm not sure why he didn't just replace the bearings, maybe too much schnapps? So I never used the hub and it definitely left a bad taste. The more recent hubs seem to be much better from what other randonneurs report. Maybe someday I'll try to replace the bearings on that hub myself. If PW can do it, I'm sure it's not that difficult. Don't know if SoN will replace bearings, but shipping starts to add up.
I keep hoping some of these brands come to realize that Peter White is costing them sales. But I'm sure they like having a repair center in the U.S. so they don't have to deal with a lot of issues.
I have a SoN wireless hub, unfortunately it has Peter White engraved in it in big gaudy letters.
I’m salvaging a 32h shimano from a 700c wheel lying around that’s got to have over 10,000 and no issues.
Liked 341 Times
I'm not really a randonneur. I go do 90 to 128 mile rides, 11 or 12 hours mostly. Have a big lunch and rest in the middle. Just sightseeing really. Longest ride was 133.6 miles with these 2 wheels on my 73 lb tour bike.
I love my steel IGH roadsters. This Simcoe frame one is 42 lbs plus load. I chucked all the lame alu parts it came with. Just these wheels are 14.5 lb I think.
I never see anybody going my way anymore. I have no interest in cold dark rides unless the days are getting short.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/20230628_132036_edca52836c65c3e1383b59e45ceecdf236962011.jpg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/20230628_132242_b786dc72db725167d4a417e168788fcca4e5e772.jpg)
Quoted: 3523 Post(s)
Liked 1,500 Times
I have never heard of anyone sending in a hub that is working for a rebuild, and I would never do so. I think probability of getting a bad bearing installed at that time is just as great as one of the existing bearings going bad.
This is the third SP hub problem I recall reading about on this forum. I bought my first one nine years ago, my second one about six years ago, another a couple years ago, all three are working fine. My first one is on my heavy touring bike, often used for heavy loads, sometimes off road with heavy loads. Second one is on my rando bike, light loads and almost always on pavement. Third one has less than a thousand miles on it, on my road bike.
More on SP here:
https://www.bikeforums.net/electroni...placement.html
More on SP here:
Likes For Tourist in MSN:
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
I have an SP that has done 10,000 miles, 2 PBPs, and a bunch of brevets. Still working great.
I did once hear of a firsthand story of an SP failing, but many others I know have had no problem.
On my new bike I got a SON, because life is short etc.
Likes For samkl:
Liked 1,500 Times
Tour Divide race, looks like about five times as many Son hubs were used as SP when using a word search (best searched with a space in front and after Son or SP). That is a place you do not want to use something that might fail from hard use.
https://bikepacking.com/bikes/2023-t...e-rigs-part-1/
https://bikepacking.com/bikes/rigs-o...divide-part-2/
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 558 Post(s)
Liked 734 Times
Is there a reason not to use shimano?
Quoted: 923 Post(s)
Liked 2,122 Times
I've bought four SP hubs, for four bikes.
One with about 15k miles, mostly brevets, flawless. One with about 5k commuter miles when I sold it, flawless. Many of the above miles were in the rainy PNW.
On a recent bike build, the new SP hub vibrated and made a growling noise from day one. They warranted it, but of course i had to rebuild the wheel. About 11k brevet miles later, many of those in the rain, it's flawless.
The newest one only has 1600 miles, including pbp, no issues.
Likes For downtube42:
Only reason I can think of is SON and SP have more spoke count options. And with modern carbon rims and higher volume tires, lower spoke counts on anything other than a racing bike are a more viable option than in the past. That's what steered me away from my trusty 32h and 36h shimano hubs (on my town bike, my previous touring bike, and my wife's touring bike). I was trying to shave grams for a more rando specific build so was looking for a 28h hub. After this experience of a hub failing out on a trip and having a heck of a time finding a replacement wheel (how many shops on the planet will just have a 28h 650b rim brake wheel at the ready?) I'm less concerned with the difference in weight between 28h and 32h now. My new touring/gravel bike has disc brakes and carbon rims which is the new standard. Nothing lasts forever, except maybe the bike with SA hubs in the pictures above shared GamblerGORD53
Also, while stressed out on the road trying to fix this problem and being hard on myself for not preventing the problem, I remembered some country wisdom imparted to me by the guys at my local MF Tractor shop, "If something broke, that just means you're using it." Of course that's an oversimplification, but I remembered then there is some truth to that, everything fails eventually, and in 23 years of thousands of miles of distance cycling on really just 3 different bikes this was the biggest problem I've ever had on the road, locally or abroad. Also, the same day this happened, my wife's 15 year old shimano touring pedal bearing started to give out. Luckily in Spain we found a replacement pedal in a neighborhood moped and bike repair shop in the first town we came to that day.
Different hubs have different drag. link with lots of tests. I'm not smart enough to understand any of this science.
Likes For clasher:
Liked 1,500 Times
There are better Shimano models and ones that are not so good. I have one of their better models on my light touring bike.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/922x691/20imgp2211_1271a686371d8216c9f85b31e0e07fbbfd225319.jpg)
Initially I had an SP on that bike when I built up the bike in 2017.
Later I bought the Shimano on a used wheel. But that used wheel had a rim too narrow for the tires I wanted to use, so I put a different rim on that wheel, the ERD was close enough to the same for both rims that I could reuse the spokes. Thus, I had two wheels with Dyad rims with dynohubs, both 32 spoke. Initially I put the Shimano wheel on my rando bike.
When I give the wheel a spin by hand with the light turned on, the Shimano seems to come to a stop faster than the SP wheel. I decided to put the SP on my rando bike, put the Shimano on the touring bike. I wanted less resistance on my rando bike. This was a much less scientific test than cited in a different post in this thread, but that was good enough for me to make a decision on which wheel had more resistance.
Another benefit of the Shimano on the touring bike is that the flanges on the Shimano are further apart, I think that gives the Shimano wheel additional strength from a side impact, but that was secondary in my decision making. The touring bike which sometimes carries heavy loads is where I would like more strength if I have a choice. And also aesthetics played a part, the SP hub was black and that looks better on my rando bike.
Randomhead
Liked 3,802 Times
There is an ultegra level Shimano that's supposedly an upgrade to the 3n72 as well, forget what the model number is. I think the only difference may be that the shape is a little more elegant and it has cutouts in the non-dyno side flange. I have one of them, can't tell the difference from the 3n72 other than looks. And it still looks a little clunky.
I have close to 46,000 km (about 28,500 mi) on the center lock disk brake SP on my 650B disk brake Elephant NFE, my main bike since 2016.
I also have 39,000 km (about 24,000 mi) on my Bike Friday which currently also has a SP center lock dynamo, but most of the distance was with a Shimano dynamo. I had the front wheel rebuilt for disc brakes when the old rim brake front wheel wore out. The Shimano dynamo I used with the old rim is still fully functional and was reused for a wheel build for another 650B wheel (on my daughter's bike now).
All three dynamos (2x SP, 1x Shimano) are still fully functional, not one issue in 85,000 km!
Likes For joewein:
Randomhead
Liked 3,802 Times
I assume that, months later, the OP got their problem sorted. I was interested in the FS hubs, but I feel like it just introduces another failure mode.
For now on my rando bike I took the 32h shimano dynamo hub out of an old 700c wheel, built it up on a 650b pacenti box rim with Sapim laser spokes and it's rolling smooth as ever. I'll leave that as is. Eventually I'll build up a dynamo hub wheel for my gravel/touring bike. I'll most likely stick with Shimano, unless a SON just falls into my lap somehow. I like that SON has more build options and lower rolling resistance, but the price of SON causes a lot more friction on my budget.
