Water Bottle Mount Storage
Quoted: 608 Post(s)
Liked 699 Times
I've seen a bike bag that mounted directly to the frame using the water bottle mount holes.
Problem is, I don't know what it's called or my search terms are not correct.
Note: not an empty water bottle using the cage, but a specific pod or bag, usually larger that a standard bottle.
Or I just imagined it.....
Any guidance?
Any guidance?
Quoted: 1611 Post(s)
Liked 1,801 Times
I use the Fabric tool keg myself:
https://fabric.cc/products/hydration/cageless-tool-keg/
It comes with two sets of mounting studs. You can easily transfer between 2 bikes.
It's a little bit smaller than a standard sized bottle though. If you are looking for something larger- there are lots of tool storage cans that go into your bottle cage. Like this Zefal one:
https://www.amazon.com/Zefal-Bag-Z-Box-Black-Medium/
Likes For icemilkcoffee:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 767 Post(s)
Liked 4,079 Times
Any guidance?
Any guidance?
Likes For MattTheHat:
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 478 Times
I use one of these. Holds a fair amount of stuff and I can still carry two water bottles.
It contains zippered compartments on each side. Around three inches with contents. Does not chafe my cycling motion.
Amazon.com: WMAWJBT Bicycle Beam Bag Frame Bag, Bike Rack Storage BagWaterproof Bicycle Triangle BagAccessory BagRoad Bike Mountain Bike Accessories (XL) : Sports & Outdoors
Clark W. Griswold
Quoted: 4452 Post(s)
Liked 4,117 Times
I have an older one from Scott. I know Topeak makes the Cagepack and Cagepack XL but those I believe just go inside a normal bottle cage but I see that as more of an advantage as I can easily remove it and carry a bottle of water. They also do bottle style holders as well but if you want fabric the Cagepacks would be the way to go.
Also Topeak does the Gearpack which is a strap on for the downtime typically for FS MTB.
Quoted: 1445 Post(s)
Liked 2,015 Times
Likes For t2p:
Quoted: 1465 Post(s)
Liked 1,491 Times
This looks like the Wolftooth B-Rad system, which works very well. I've used this on my gravel/CX bike and run a similar setup. The only issue I had was that my bag had to be stuffed in the "crotch" of the frame a little bit, and it rubbed on the seat tube.
(EDIT: In my case I ran the bag on the seat tube, below a bottle - this allowed enough space to carry a second bottle on the down tube - so two bottles plus a tool bag in the frame.)
This is also a good solution for carrying 3 bottles in the frame.
Likes For msu2001la:
Quoted: 608 Post(s)
Liked 699 Times
Great suggestion
ok I didn't know that this was a thing.
It might solve another problem for another bike so this is really interesting to me.
Thank you so much.
Likes For CrimsonEclipse:
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 413 Post(s)
Liked 839 Times
JohnMFlores.com | YouTube: JohnMFlores
Insta: JohnMichaelFlores | TikTok: @johnnymotoflores
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
Man, I need my two bottles full of water when I ride, so I don't want the cage to be used for anything but water.
I think the device shown by T2P is the best solution, it frees up the cage to be used to hold water and has a small storage bag.
Depends on how much space you need, Lezyne makes a cage called the Flow Storage Cage with a small storage container built into the end of the cage designed to hold a certain Lezyne called the V 16 multi tool plus it will hold 2 CO2 carts and a Lezyne inflator. Go to Lezyne website, they also have a tubeless tire tool option for the Flow Storage Cage.
