Ankle lights
Bikes: Custom built LHT & Troll
Quoted: 871 Post(s)
Liked 152 Times
Ankle lights
Biomotion (i.e. moving lights suggesting that the wearer is a human) is arguably best to promote early detection.
Several arm/ankle models available, mostly for joggers. My use case is extended bike touring. I am looking for:
- something durable, reliable and waterproof
- running on CR2032 (batteries can be swapped in the middle of the night if needed)
- comfortable to wear around the ankle
Quoted: 816 Post(s)
Liked 1,038 Times
I'm in agreement with you on the motion of the light. In the '70's and on into the early '90's I used to have this light. This is not mine, I happened to find a picture of a similar one.
I now have a leg band that will glow green when I turn it on and I also have pants clips with reflective tape. One other advantage of these type of lights is that the are not married or mounted to the bike.
As for advice on what is good nowadays, I don't know. Perhaps the glowy band.
Likes For Velo Mule:
Quoted: 3505 Post(s)
Liked 1,490 Times
I assume you want this for daytime when reflective bands would be mostly ineffective. If at night, I would just suggest good reflective material.
Quoted: 999 Post(s)
Liked 1,671 Times
I keep at least two 40cm Reflective Pop Straps on each of my bikes. They offer very good visibility in dark conditions. Be sure to order the 40cm length.
Aliexpress.com
I have noted that nothing beats that reflective vest! I found a very light weight mesh reflective vest that I can compress and store with my little tool kit.
Aliexpress.com
Likes For zandoval:
Quoted: 2629 Post(s)
Liked 1,976 Times
I've thought about ankle lights, but my night-time riding is generally commuting. I figure the ankle lights and reflective stripes will be blocked by panniers, and therefore ineffective.
I still keep reflective bands in my randonneuring gear, though.
Quoted: 871 Post(s)
Liked 152 Times
zandoval Good point. I already use something quite similar. Perhaps sufficient, actually. And excellent battery life
Randomhead
Liked 3,760 Times
I still have a leg light. Should put an led in there.
But I use SOLAS ankle bands. They don't go bad or stop reflecting in the wet like a lot of ankle bands do. On the downside, they are a tiny bit clunkier.
Liked 1,490 Times
I occasionally saw a bit of ankle band, but not often.
Palmer
Quoted: 1699 Post(s)
Liked 1,868 Times
I remember riding with cats that used these:
I was never much impressed. The lamps so often wiggled&squiggled around and uncomfortably dropped and/or pointed in an ineffective direction.
Today there are lighted pedals. AFAIK the too-clever-by-half Pedalite, with its internal belt-driven dynamo, is no more. The USB-charged RedShift lighted pedals are available.
You'd think in this age of miniature LED lights someone would offer an add-on pedal light. (Maybe it's just my Google foo but...) I can't find one, but you can add reflectors to most pedals, or purchase a functionally similar pedal that comes with built-in reflectors.
Quoted: 999 Post(s)
Liked 1,671 Times
Yep... I get ya. I wrapped reflective tape around the base. I also used a Head Lamp powered by a 6 volt Dry Cell on my belt. The things we did. Flexible reflective clothing was around but out of reach till the late 70's. One of the guys I rode with had a Reflective Jacket from the airport. Wow... It was really trick...
Quoted: 4854 Post(s)
Liked 3,992 Times
I used those light for decades. They work very well. Car driver response is excellent. I find cars in general giver me more clearance with those than with far brighter flashers that are stationary on me or the bike.
Several comments. 1) thankfully much lighter and more comfortable options exist now. At high pedaling RPMs the ankle takes a real beating with those 2 C-cell batteries. And, thank you, DuraCell and alkaline batteries and now better! The pre-alkaline days of lead batteries meant a lot of rides home in the dark..
2) For less bone battering and also visibility in front of panniers, strap the light below your knee. Same vertical movement effect, very little pannier screening. (I never rode with rear panniers so that simply wasn't an issue for me but the constant bone bruising on my ankle was.)
Thread Killer
Quoted: 3207 Post(s)
Liked 1,749 Times
To your second point, Specialized Stix lights offer bright, lightweight rechargeable lights which can be mounted virtually anywhere— I use velcro or DuoTec to mount them to headtubes— including to the ankles with the optional ankle strap. They’re my favorite USB rechargeable lights, being lightweight, bright, low-profile, long running, versatile and stylish.
Quoted: 7379 Post(s)
Liked 2,534 Times
I've used them. I got some cheap ones from one of those Chinese web sites. They are terrific attention-grabbers. I've even received compliments from them. But mine were not stretchy, and they were uncomfortable. I stopped using them. Maybe I should make my own.
But there are so many accessories involved in commuting, I have limits. Maybe a reflective vest would help, but I just can't bother with some of these things. One thing that has helped a lot is a dynamo-powered headlight. It's theft-resistant, so I leave it on the bike, and I never ask myself if it's time to charge the battery, since there is none.
Likes For noglider:
Bikes: Fuji Jari Carbon 1.1, Honey Winterando (made by Seven), Litespeed Arenberg
Quoted: 11 Post(s)
Nite Ize Slap It straps- https://niteize.com/slaplit-rechargeable-led-slap-wrap
They can be set on steady or flashing.
Quoted: 11 Post(s)
They also do this one which I have. https://niteize.com/bike-fitness/run...-led-slap-wrap
Likes For jbithaca:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
I do believe in using good lights, not airplane landing lights, but decent lights. I also supplement my lights with reflective stuff, and one of the ways I use reflective stuff is on my ankles when riding at night, I don't do the lights down there because I already use 3 taillights at night, so I don't see the need to add more.
Bikes: 1992 Trek 950
Quoted: 10 Post(s)
Liked 8 Times
You can attach these to platform pedals:
https://www.ebay.com/itm/295970308524?var=594142282221
Can't go wrong on the price, just don't expect overnight delivery!
Liked 257 Times
Liked 2,534 Times
Lights mounted on your ankles or wheels don't need to be bright. People notice them.
Liked 257 Times
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
From riding behind others, I can see that pedal reflectors are effective. However, manufacturers often omit them, especially on the higher-end pedals, and customers do not seem to care either. Myself, I do not buy pedals without them.
Quoted: 645 Post(s)
Liked 1,552 Times
I used to do 15-20 mile rides before work; usually around 4AM. Someone had given me one of those slap lights that I wore on my left ankle and thought it was pretty effective. It weighs next to nothing and it wasn't uncomfortable at all. Of course I also had two taillights (one on the seat post and one on the seat stay) as well as reflective gear. As far as I'm concerned, the more the better when riding in traffic in the dark.
I don't recall how long the batteries lasted but I don't recall having to change them that often.
A number of the single-sided Shimano pedal models - even higher-end SPD-SL - have reflector options that can in some cases be not widely available, at least in the U.S. market. I would guess that demand is limited.
Quoted: 840 Post(s)
Liked 337 Times
Hybrid SPD/platform is not a style of pedal that is to everyone's taste, but I give Shimano credit for having reflectors integrated into the design of the PD-T8000 pedals.
