Switching to shorter cranks for road cycling as you get older?
Brisvegas roadie
Bikes: 2013 Trek Domane 6.9 (SRAM Red 10-speed), 2007 Wilier Triestina Mortirolo (SRAM Red 22), 2013 Pinarello FP Uno (Shimano Ultegra 11-speed), 2009 Fuji Roubaix Pro (Shimano 105 10-speed), 2008 Colnago Extreme-C (dream build, under construction!)
Liked 21 Times
Hi all. While surfing the web for parts to upgrade one of my road bikes recently, I noticed some articles and videos from bike fitters talking about shorter crank lengths. While I'm 5'6", I've always used 170mm cranks (I'm in my early 50s now) and never had any problems with them. Fortunately I've never had any lower limb or hip injuries, although I have had some other serious injuries, so I'm conscious of keeping myself in good shape for as long as I can. The sizing charts based on this newer material all recommend 165mm cranks for my height and inseam, so this is something I'm considering. 'On paper' recommendations are one thing; but I'm curious to hear about the experiences of others as to any real world benefits after switching to shorter crank lengths in terms of injury prevention? Thanks!
Grupetto Bob
Bikes: Bikey McBike Face
Liked 6,112 Times
Interesting question. I have no experience here but would think if you are not rocking in the saddle longer cranks would provide better leverage, but we’ll leave it up to the experts.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Liked 1,033 Times
I haven't felt much difference between 170s and 175s, so I expect my first pair of 165s (bought to cure a toe overlap) won't feel all that different either. But I'll report back if that's not the case!
It might be because of my long legs, too. (26" frames or eq.)
Liked 737 Times
Short cranks aren't a magical cure against damage, regardless of what the proponents may say. Those who benefit most from short cranks are the ones who already have some sort of damage. The best way to avoid damage is to spin.
Bikes: Franklin Frames Custom, Rivendell Bombadil
Liked 216 Times
There have been riders on shorter cranks for performance reasons since they've bee around. I started riding 150mm cranks with a mid-foot position some ten years ago or so, I can't remember exactly. I'm 74" tall with 36.5" floor to crotch bone and my largest foot measures 11-7/8 inches, a size 14. I'm at this point as riding up to 185mm cranks didn't equate to better use of what power I do have. Theory is one thing, riding is another. I often hear "longer cranks = more leverage" repeated but that doesn't make sense to me in practice, actually riding. I've also moved my saddle much more forward, about 40mm from where it once was. Just because you're "however you identify yourself" doesn't mean short cranks can't work for you, and I have no physical limitations. This just feels right for me. The best way I describe what I experience I found in this article : https://biketestreviews.com/cranklength/
Some parts that I related to ..
Really though you gotta read the whole article to get the context.
What is optimum for each person can only be determined by trial and error experimentation.
But, what about climbing?
Everyone “knows” that to climb well you need the leverage that a longer crank offers. So, what happens when you try to climb with short cranks. First, as I have shown, it is simply a myth that you need long cranks for the leverage to generate power. The leverage that is important is not the leverage between the pedal and the bottom bracket axle but the leverage between the pedal and the rear wheel. Since there are several links in the leverage chain it is possible to adjust the leverage using gearing to make up for “loss” of crank arm leverage.
And, there is one more lever in the chain that people generally ignore, the knee. The more you bend the knee the more “leverage” you lose (can you press more weight with a full squat or half squat?). Increasing crank length reduces knee leverage such that there is no net leverage benefit using longer cranks within a large range. Climbing is not about leverage it is all about power so you should have the crank length that optimizes power, not a crank that “optimizes” one aspect of the overall leverage equation.
The science revisited
How can this short crank length benefit be explained scientifically? There are two major scientific papers here. First is Determinants of maximal cycling power: crank length, pedaling rate and pedal speed by Martin and Spirduso of the University of Utah. This paper concluded that while the power was maximum with a crank length of 145 mm there was little lost by most riders when using 170 mm cranks because the difference was only about 1% and the difference was not statistically significant. Further, the paper concluded that the most important variable that affected power was pedal speed, not crank length.
Likes For Garthr:
Liked 5,004 Times
If you aren't having issues, then there probably isn't any point in switching. If you are a slow cadence rider at the moment and want to regularly spin a faster cadence as a norm, then shorter cranks might help you achieve that sooner. Spinning faster cadences also frequently improves speed even though you are using lower gearing .
My leg measurements would have me on > 190 mm cranks. But I'm still very happy on 165mm cranks. I didn't care for the 172.5 mm cranks I tried for 4 or 5 months. All my previous bikes were old bikes and for whatever reason just came with short cranks in the 165mm range. So my legs are just to use to them.
You may not care for the 165mm if you were to try them now. Or you might find you like them. Though a good crankset can be an expensive change just to try something out. But if your knees start giving you issues with the range of motion on the longer cranks, then maybe you should try shorter.
Just remember the saddle goes up by about whatever the difference is between new and old crank length. But for 5mm difference in saddle height, you'll probably only notice it if you ride at very hard efforts for most of your ride.
Honestly, I have never noticed any real difference. I have bikes with crank arms ranging from 165mm to 175mm, and ride them interchangeably. There aren’t any noticeable differences in how my legs feel, or in power output.
Liked 2,206 Times
If you have knee issues, maybe. I’m late 60’s, knees are good so am not switching. I use 172.5 on the road bikes, 175 on the mt bikes and my gravel bike, which is used mostly on asphalt. I have never had pain from changing crank length.
Liked 2,201 Times
I used 170mm cranks for many years. When I started to ride mountain bikes, too late in life, the cranks were 175mm. I do think I can spin the 170s easier than 175s.
I found an NOS FC-6503 for a good price. They are 172.5mm. At first I thought they may not have been a good choice, but 8 years and counting, they have been fine and I dont even notice any difference.
While not big proponent of KOPS, I tend to error on further back than too far forward. For me that seems to have worked out for my hips and knees over the years, than the 5mm difference in crank arm length.
John
John
Brisvegas roadie
Liked 21 Times
Veteran, Pacifist
Liked 4,966 Times
Yes, shorter. 165/170 on any bike that has gotten a crank overhaul on the vintage bikes - which have been 175.
Without any hard evidence - I maintain when the going gets tough, spinning smaller circles is easier than bigger circles.
Likes For Alan K:
Liked 1,057 Times
I've used some other logical arguments for shorter cranks, or more correctly right sized cranks (and that means longer cranks for riders with longer legs). But let me try this: Back when all American engines were all basically the same (pushrods), displacement was important. Bigger engine meant more power. Now, we can get powerful engines with not so big displacement. Those smaller displacement engines make power by being able to rev higher. Remember, Torque x rpm = Horsepower (or watts if you are talking about cycling nowadays).
While a longer lever means more torque, spinning faster means more horsepower (until you can't spin anymore). For a BMX start, a long cranks might be just the thing, for endurance, a shorter crank may yield better results.
I am 5'- 10" about average for a male and therefore should be just right for the standard 170mm crank that bike makers put on just about every bike that would fit me. I never questioned it until recently. I changed to 165mm cranks and immediately felt an improvement. I know, it could be the placebo effect. The key thing for me was I did not stop pedaling as often with the longer cranks, I kept going. It was a bit of a new experience to me. I didn't feel tired after an hour of riding. And my knees didn't hurt.
I used to bicycle race when I was in college. When I started, without any training, I did good. I got serious and started training and got slower and slower. My knees hurt, but that was just part of getting serious, right? Turns out, no, I had a problem. I quit racing and even limited my recreational rides.
Now, I'm not saying I'm cured by a 5mm change in crank length. I am saying that my knees have problems that I am sensitive to and these 5mm shorter cranks seem to help me.
If you are pushing a standard or long crank and it's working for you, keep going. If you are experiencing any issues or even want to try to spin more to get more watts, give shorter cranks a try. And let us know how it goes.
Likes For Velo Mule:
If leg Range of Motion has decreased for Orthopedic reasons or age, then shorter cranks might help.
Liked 620 Times
I was 5'-11" when drafted and now at 73 5'-9" but no meaningful change in saddle height however dropping to 165 cranks from 172.5 is moving through my more modern bikes and my vintage bikes are only ridden on short rides.
Likes For easyupbug:
Old fart
Liked 3,461 Times
I run 165mm cranks on my fixed gear bikes, for cornering clearance and easier spinning. 170mm cranks on my other bikes.
I put 155mm cranks on my wife's bike when I converted it from 700C to 650B wheels.
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Liked 1,176 Times
Here's an interesting video on the topic. It's not your average "Youtube bike fitter" vid that just talks about hip angles, this goes further and graphs angles as well as femur velocities, in relation to different crank length. Basically, the rate of acceleration of the femur, through the pedal stroke, increases with longer crank arms. The creator of the video posits that this is more taxing on joints as well as fast twitch muscle fibers. An argument could be made that both of those issues are of increased importance to older riders. Although, the ideal velocity and rate of acceleration of the femur, might not be the same for different femur lengths. I myself feel best on 172.5 or 175mm cranks, and can easily spin a 90-100 rpm cadence on them.
Liked 1,176 Times
My road bikes all have 172.5 or 175 cranks, and I'm not sure I can tell a difference between them. My 2 MTBs are the "extremes" for me. One has 165mm cranks, the other has 175mm cranks. My perception is that I'm not using my preferred range of motion on the 165 bike and that it hurts the force I can put into them. It's not a huge difference and if I cared more, I'd do back-to-back comparisons with my power meter pedals.
Brisvegas roadie
Liked 21 Times
https://youtu.be/S0SpYdxg1UY?si=zdPF77oiQZTlpE8j
My Workshop = Happy Place
Bikes: Schwinns, and many others.
Liked 225 Times
I'll just share I am 5'6" and have a 30" inseam. MUCH of my riding is on Zwift. Measurable.
Indoor trainer bike: I modified a pair of spare arms from 175mm to 155mm (Drilling and tapping) on the basis of many videos on YT exploring this, and my own realization: I'm SHORT.
I could not be more pleased with the result. I found immediately less rocking butt movement on the seat, and they allowed me to spin in a circle.
For the same given heart rate I was up at least 5 watts average.
I have a gaggle if vintage Schwinns and others; I can't convert them, yet I wish I could. Works for me.
If you have a opportunity to experiment try it. The LH/RH taps are only $15 on Amazon.
Coop
Coop
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Liked 164 Times
I just put 165mm cranks on a recent 1984 Nishiki Prestige to 27" to 650B conversion. I can tell the difference between my 170mm and 165mm cranks. I can tell I am turning smaller circles. But I can tell me knees like it a little more, though they don't hardly feel anything with 170's either
Many mountain and road bike riders have been moving to shorter cranks and gaining in pedaling efficiency. I am of the school that it might help and you can always go back to the original cranks if it does not. First hand experience is always better than the advice of a self appointed "expert".
Liked 4,073 Times
My knees do not like crank length change at all (chondromalacia patellae) and I have 6 bikes, all riders, so changing crank length is a big deal.
