122 BCD Nervar Star?
Quoted: 766 Post(s)
Liked 664 Times
I recently talked to a person who wanted to buy a 122 BCD triplizer ring for their Nervar Star crank. I said that as far as I knew, that particular crankset was never available for anything but 128 BCD rings, and suggested that maybe he'd measured wrong. But having been surprised many times by French bikes and components, I said I would look into it and get back to him.
Good thing, because what do you know? Esteemed BF member verktyg, writing on Velobase, postulates that the more recent of the two models of Nervar Star cranks may have been available in a 122 BCD. Interesting, but not exactly definitive. Has anyone actually seen one of these unicorns?
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 3861 Post(s)
Liked 3,445 Times
the set/model received a cosmetic revision for the 1976 model year
my recollection was always that dimensions remained unchanged
wonder if this might have something to do with it...
have never heard tell of any cooperation between Peyrard and Verot
the two firms belonged to different export groups, GEFFAC & FREXA, back in pre-STC times
Veteran, Pacifist
Quoted: 3924 Post(s)
Liked 4,909 Times
122 on two Nervars I have had.
Likes For Wildwood:
Quoted: 766 Post(s)
Liked 664 Times
Cool! Who knew?
Did they come with Nervar-branded chainrings also, do you recall?
--Ogden Nash
--Ogden Nash
Liked 3,445 Times
Quoted: 3832 Post(s)
Liked 6,865 Times
I’ve definitely had 122 bcd Nervar cranksets. They were also definitely more modern and shaped than the old-school blocky ones.
Here’s one on eBay in the style I remember as 122 bcd:
https://www.ebay.com/itm/25606144340...mis&media=COPY
Crawlin' up, flyin' down
Quoted: 1056 Post(s)
Liked 2,611 Times
Veteran, Pacifist
Liked 4,909 Times
Cannot speak for the one that got away on a nice bike.
Not sure I can find a closeup pic of the other.
But I will look for it AFTER a nice bike ride now. Darn, …. note to self…. stop checking BF pre-ride.
Likes For Wildwood:
Liked 3,445 Times
Neither of the Nervar cranksets were original to the framesets. I believe this one has original rings= 53/42. Also stamped as BSA.
thank you!
this G2 set appears to be the one which came OEM on your Olympian
since Herr A-D is an '80-'81 fellow that helps to date chainset
Quoted: 766 Post(s)
Liked 664 Times
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Veteran, Pacifist
Liked 4,909 Times
Ahhh,... Lightbulb moment = I had not checked the Olympian spec for crankset, ....or forgot I did, ....or did not put 2+2 together. Purchased the AD Olympian from a flipper (15+years ago) who had several frames and many cranks, etc. Given 170mm length, it may not be original to the 62cm frame, or that was my thinking. Maybe the BB is also original, too. Doesn't matter to me, this one has been a keeper.
Likes For Wildwood:
Quoted: 1621 Post(s)
Liked 2,240 Times
I believe the one that came on the Bottecchia Giro d'Italia is 122. Nope, measured and it is 128.
P1020410 on Flickr
P1020410 on Flickr
Quoted: 766 Post(s)
Liked 664 Times
If you still have the bike and/or crankset, would you mind measuring that BCD sometime? That's the first version of the crank, I think, and according to the speculation on Velobase, it only came in 128. It would be really useful to know if it also came in 122.
--Ogden Nash
--Ogden Nash
feros ferio
Quoted: 1403 Post(s)
Liked 1,355 Times
I have a 128mm set (never did understand why Nervar chose to go proprietary on BCD), but I have indeed heard of the Simplex-compatible 122mm variations, but never seen one in captivity.
One can easily modify any 130mm ring or triplizer to 128mm by elongating the mounting holes inward by 1mm (been there ... done that, still have the 44T Shimano ring), but 122mm would be a different proposition.
Liked 2,240 Times
Liked 3,445 Times
thank you
reason mentioned your Olympian is that I recalled the Star as being the OEM chainset for that model in the early years of the marque
the A-D launch in a the U.S. market was 1976
first saw of the models in person was 1978 in me LBS who had become a stockist
so the example looked at would have been some variety of the G2
thanks for the reply
Veteran, Pacifist
Liked 4,909 Times
@SJX426 - Thanks for the memory assist. Here's the other Nervar crankset i spun. Never measured the bcd.
edit: This one passed thru @SurferRosa - he is meticulous,and must have measured the bcd and inspected the rings.
Quoted: 1118 Post(s)
Liked 1,345 Times
SR rings are much more common than 122 Nervar, likely cheap, so worth a flutter.
