Okay It's Chilly Today, But That's Not Supposed To Happen
It's 34* F, and it broke cleanly right in my hands, after being outside for about forty-five minutes. At least it didn't cost me a bike.
( And yes, before anyone asks, I have heavier-duty locks for other situations -- this one was just for suburban usage. )
Likes For TC1:
Clark W. Griswold
Quoted: 4449 Post(s)
Liked 4,112 Times
That is why I never sell cable locks, they are so easy to get into this one didn't even require any tools it froze to death...poor guy.
For those looking for a light duty lock ABUS Bordo Lite would be my top recommendation as light or potentially lighter than some cables, easy to carry and a lot more secure and resistant to freezing to death!
Pennylane Splitter
Bikes: Yes
Quoted: 1844 Post(s)
Liked 1,490 Times
If metal cable can snap at 34F that's a pretty poor quality metal alloy the manufacturer used. I'd expect that at below -300F, but none of us would be around if temps regularly got that cold here on Earth!
Likes For skidder:
Quoted: 233 Post(s)
Liked 323 Times
The cable looks slightly rust colored at the brake. I wonder if water got in there and corroded the metal. Might be the metal cable was pretty well gone and it was the plastic holding it together, until the cold temps made that brittle.
Broken is broken, but I'm thinking it wasn't the metal that failed due to low temp. Anyway, just a thought.
Likes For Mtracer:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
Clark W. Griswold
Liked 4,112 Times
Yes they are I checked a photo and it does show an ABUS key and ABUS logo on the links however they are using older mounts which use big thick velcro instead of the newer metal bands (which work a real treat, my lock does not move when it is mounted on the bike it stays put through whatever riding I am doing). I don't know about being able to get it keyed-a-like but I cannot imagine that is impossible because it looks like the standard Plus key they use (the lighter duty stuff is going to be wafer keyed or combo locked)
Likes For veganbikes:
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 477 Times
I own a much thicker cable lock with the same 4-digit combo setup.
Somebody gave it to me, but did not know the combination. His friend used it to lock a motorcycle.
I managed to "pick it" within five minutes. Put my old teen lockpicking skills to work!
It takes less time to hacksaw thru, however. These locks merely slow down thieves.
Mondo chain locks weighing ten pounds fare better, although one usually finds the weakest link in the padlock.
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 796 Post(s)
Liked 512 Times
I used to be able to pick those quite easily in my college days. Haven't tried recently. The trick is to wiggle the annular rings back and forth while turning to find the number. If it wiggles freely you are on the number. It was fun to grab a bike off the rack and joyride around campus at night. I always put the bike back but on a different location on the rack. Fun times.
Quoted: 18520 Post(s)
Liked 15,856 Times
What I suspect happened was that the slit in the sheath caused it to flex at the same spot, thousands of times, and eventually the cable strands literally reached their braking point.
It obviously wasn't temperature alone -- this lock has been outside all day in sub-zero Fahrenheit many times -- but a combination of age and a potential manufacturing defect, with a cold day perhaps being the camel's straw.
Bikes: Shmikes
Quoted: 10217 Post(s)
Liked 5,922 Times
Coated wire rope is notorious for corroding under cracks in the coating and then breaking suddenly. This is particularly common and dangerous in marine applications. Not sure, but I think I see rusty discoloration at the break. Inspection of the broken strands for rust can confirm if this was the cause.
Likes For phughes:
Quoted: 1060 Post(s)
Liked 1,319 Times
Likes For phughes:
Clark W. Griswold
Liked 4,112 Times
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 172 Post(s)
Liked 401 Times
I use a 5/8" thick 6' cable with a heavy duty padlock. I only use it in my car/SUV which is anchored through one of the seat lock positions when the seat is tilted forward. Bike lays flat but I cover it with two blankets so that no one can see what is there through the heavily tinted windows and tono cover.
Liked 15,856 Times
Likes For indyfabz:
Advocatus Diaboli
Quoted: 4761 Post(s)
Liked 1,542 Times
Likes For Sy Reene:
Advocatus Diaboli
Liked 1,542 Times
Likes For Sy Reene:
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
OP, have you tried to break any other part of the cable, just to see what would happen? I, for one, am curious.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 307 Post(s)
Liked 417 Times
As for the sheathing, if it's old enough and/or has been in the sun a lot, the elastomers will bake out of the plastic and it gets brittle. That's just the nature of plastics.
Likes For Smaug1:
