Battery charging
Battery charging
It seems that my 36v battery has only 2.75 volts from sitting all winter (my stupidity). Is there any way to bring it back. My charger doesn't touch it.
thanks for any help
Dave
thanks for any help
Dave
Quoted: 568 Post(s)
Liked 508 Times
* Risk of serious injury or death: fire and explosion, toxic fumes and corrosive liquid - don't do this without taking appropriate safety precautions.
Quoted: 5983 Post(s)
Liked 2,914 Times
Sometimes you can get a slight boost in voltage by warming a weak battery. I'm not saying to put it in the oven, but leaving on a sunny windowsill before connecting it to the charger again. This is kind of a Hail Mary, but at least won't cost anything.
Also, you might do better by asking on the E-bike forum, since that attracts a crowd with more battery experience than you'll find here.
FB
Chain-L site
FB
Chain-L site
What about trying an initial charge with a low-amp (like 1 amp) trickle charger, perhaps starting with 12VDC output? If it's not a "maintenance" charger that senses battery voltage, just a simple trickle charger like a typical AC adaptor, it may be able to put some charge in. Low amps is safest I think, don't worry about time. Just in case though, wear safety glasses and have the battery and charger on a fireproof surface or in a metal charging box designed for that.
Quoted: 6370 Post(s)
Liked 4,970 Times
You don't offer us any idea what the bike or battery is. And for something drained to that extent, recharging normally might be the next impressive youTube video of a e-bike battery fire.
While the battery should be able to hold a charge for a few months. Many things don't really turn off today and will be a very low but constant drain.
Have you checked with the bikes dealer or manufacturer about what should be done? Anything else and you should make sure you are near by to witness whether something starts going awry. But if the manufacturer or dealer only said to buy another battery, I'd be one of those that tries to revive it first. But probably outside and somewhere fire and fumes won't be an issue.
Welcome to BF
Welcome to BF!
Welcome to BF
Welcome to BF!
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 892 Post(s)
Liked 1,248 Times
A 36V pack at about 4V per cell is 9 cells. 9 cells at 2.75V is 0.31V per cell. (Edit due to wrong cell voltage)
I don’t think there is any coming back from that.
we are not talking about a voltage level that needs a little help.
Reviving batteries is dangerous, that’s why the manufacturer provided charger has that low voltage cutoff.
I’d never trust that battery pack ever again.
A new battery is cheaper than the deductible on your home insurance.
Barry
Barry
Liked 2,914 Times
OTOH if it was put away with half charge or less, then it could bleed down too far, as seems to be the case here.
If the system won't charge it, then it's not meeting the design requirements and for practical purposes is a flammable brick.
Check local requirements for proper disposal.
Quoted: 404 Post(s)
Liked 315 Times
Not an e-biker - my knowledge is more about cars, so perhaps somebody could help me out. Sometimes a car develops a parasitic drain on the battery that slowly bleeds the charge off of a perfectly good battery over time. A classic example is the failure of a switch that leaves one tiny light bulb somewhere on 24/7.
(This can be a bit of a nightmare because the driver may repeatedly try to replace batteries under warranty.)
In this case, if OP has every reason to believe the battery is OK, I would consider checking the bike before it kills the next battery, or at least not storing a battery in this particular bike.
Edit: Break out a multimeter. Put the new battery in the bike and set the bike up like you stored it for the winter. Check for any current flow at all. I would expect there to be stone cold zero - the bike doesn't even have accessories like a clock that a car might have. Measuring amps requires a way to break the circuit and put the meter into the circuit.
Try to get a measurement near the battery so you are checking all possible circuit paths at once.
Likes For ScottCommutes:
Liked 4,970 Times
At least some of the e-bike makers and their battery manufacturers recommend the battery be removed from the bike when it's not going to be used for some time. One even recommends keeping it were it will be between 32° and 68°F. That 68°F would be an issue for my garage in the summer! But that is only talking about when stored and not in regular use.
https://www.aventon.com/blogs/avento...and%2068%C2%BA.
https://www.radpowerbikes.com/blogs/...for-the-winter
https://www.eriksbikeshop.com/blog/p...ic-bike-winter
LR÷P=HR
Quoted: 892 Post(s)
Liked 1,248 Times
ScottCommutes ,
With modern electronics (Cars, bikes, TV,) parasitic drain has become a way of life.
Even if all it's doing is waiting to be woken up or maintaining the time on a clock.
Most modern flashlights don't have a true old school battery isolation switch.
It you really want to avoid parasitic drain, isolate/remove the battery.
Barry
Barry
Likes For Barry2:
Liked 2,914 Times
However the shelf discharge rate does vary with temperature, so cooler is better for long term storage, and they MUST be stored with enough charge to not bleed to zero.
Quoted: 404 Post(s)
Liked 315 Times
The advice about battery storage is the same for all lithium batteries, not just e-bikes.
Even the simple step of disconnecting the battery and leaving it next to the bike is probably a good idea for winter storage.
In other news, my lawn tractor fired right up yesterday after sitting in the shed/yard all winter with zero maintenance. Didn't even need a trickle charge. (gas powered)
Liked 2,914 Times
[/QUOTE]
FB
Chain-L site
FB
Chain-L site
ignominious poltroon
Quoted: 2305 Post(s)
Liked 3,547 Times
Liked 3,547 Times
I was kind of annoyed that my motor/battery software only lets me run the battery to a 20% charge. This thread makes me realize that is probably a very good idea.
Quoted: 404 Post(s)
Liked 315 Times
ScottCommutes ,
Barry
Barry
Quoted: 404 Post(s)
Liked 315 Times
There are a lot of advantages to paying for more amp hours than you need/want/use. As you say, the batteries aren't happy at too low of a charge state. Also, getting a lithium battery to take the last 15% of its charge takes about as much time as getting the battery to take the first 85%. Storing the battery at full charge isn't recommended, either. All of these point to simply getting a bigger battery so you don't have to work it so hard.
Quoted: 404 Post(s)
Liked 315 Times
EDIT: Make that brake cleaner, not brake fluid
Liked 4,970 Times
Lawn tractor batteries are usually lead acid or similar. Not quite the same beast as a lithium battery.
Likes For Iride01:
Really Old Senior Member
Apparently, a "new" battery for my bike is $750-800? Ouch!
Likes For Bill Kapaun:
Liked 3,547 Times
How long did you leave it on the charger when you tried to revive it? It might be worth trying for a few days. Do it somewhere safe.
Likes For Polaris OBark:
