How to keep seat from going down?
Old 06-10-09, 07:03 AM
MarkS
Avatar out of order.
MarkS's Avatar
Bikes: Fuji Absolut '04 / Fuji 'Marlboro' Folder
Ok, my spouse's bike was pretty cheap. Fuji Crosstown. Had it for 3 years. Get's used 4 times a week. 8 miles each time.
The problem is that the seat keeps going down. It has a quickset style seat clamp, which I tighten down about as hard as my hand can tolerate, but 2 days later it needs to be done again. We've replaced the seat post hoping that that would work, but no magic.
Would a different seat clamp, like one that uses a allen wrench, work better? What can we do to keep the seat in place?
Thanks!
Mark
Cars kill 45,000 Americans every year.
This is like losing a war every year, except without the parades.
MarkS is offline
Old 06-10-09, 07:13 AM
probe1957
Bikes: 2020 Scott Speedster 10 Disc
Quoted: 52 Post(s)
Liked 37 Times in 27 Posts
Is there an allen bolt on one side and the quick release on the other? If so, I would close the quick release then tighten the allen bolt.
probe1957 is offline
Old 06-10-09, 07:17 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 644 Times in 365 Posts
Hmmm.
If it was my bike the first thing that I would do would be to look at the slot in the top of the seat tube. If the sides of the slot taper noticeably inward at the top I'd try to find a cheap seat post that's 0.2mm larger diameter. You'll probably have to work a bit to round out the top of the seat tube again so that the larger seatpost will fit.
Retro Grouch is offline
Old 06-10-09, 07:19 AM
SaladShooter
Back in the Saddle Again
Bikes: '04 Kona Kikapu w/ tons of upgrades, in the market for a fitness roadie.
Grease it first. Then look at other option for your clamping mechanism.
SaladShooter is offline
Old 06-10-09, 08:39 AM
kidd546
Used hairspray on my bike to keep the seatpost from slipping.
kidd546 is offline
Old 06-10-09, 09:01 AM
neil0502
My bike's better than me!
neil0502's Avatar
Bikes: (2) Moots Vamoots, (1) Cannondale T2000 tourer, (1) Diamondback Response Comp mtb
Liked 2 Times in 1 Post
If we're talking metal frame and metal post, I'd have an LBS (if you don't have calipers) verify that your diameters match (correct size seatpost for the tube).
Personally, I've only had carbon-fiber seatposts slip. Rule out functional causes first ... including wrong size, and inadequate torque.
After that, you can use hairspray, or "carbon fiber assembly paste" to help limit the slippage ... but ... I'd make sure nothing simpler is going on, first.
neil0502 is offline
Old 06-10-09, 09:09 AM
SaladShooter
You don't need special 'carbon assembly' anything grease. Moly lube from your local auto parts store or Park Polylube work great and are dirt cheap.
The grease increases the holding power of the seat tube/clamp. Never had it not work. I'm assuming this is the stock seatpost so I'm sure the diameter is right. If you aren't able to get enough force on the quick release, look at a Constrictor clamp. If your current clamp has a hex head on one side, get long handled allen keys.
It'll hold, promise.
Old 06-10-09, 09:10 AM
dbc
Either tighten by the allen bolt at the other side of the quick release lever (and forget about using the quick release), or do as I did and replace the lever with just an allen bolt as you described.
If it won't hand tighten properly, then there might be a small bump inside the seat tube that prevents an even clamping force.
dbc is offline
Old 06-10-09, 09:18 AM
neil0502
neil0502's Avatar
btw:
"How to keep seat from going down?"
In my experience ... marry her.
[sorry]
neil0502 is offline
Old 06-10-09, 09:54 AM
MarkS
MarkS's Avatar
Do you mean on the seat post itself? Or just on the restraining bolt assembly? Putting grease on the post sounds like it should make the post slip down faster ... but maybe I'm not getting the physics.
Thanks!
Mark
MarkS is offline
Old 06-10-09, 10:03 AM
kamtsa
kamtsa's Avatar
This post helped me
https://www.bikeforums.net/showpost.p...68&postcount=8
BTW, the Ritchey Liquid Torque is also sold under this name and can be used also for metal on metal
https://www.cswestbikes.com/servlet/t...ssembly/Detail
Edit: somebody mentioned in a different post that a white chalk can be used instead of the Ritchey Liquid Torque to increase the friction. Never tried it though.
Kam
kamtsa is offline
Old 06-10-09, 10:10 AM
SaladShooter
Yup, on the post itself. You just take a tiny bit of whatever grease you choose (the Park stuff is at least bike specific if that matters to you, almost any synthetic grease will do) and smear it very thinly over the area below the seat tube.
Grease IS slippery, yes, but it increases the resistance for seatpost to slide against the seat tube, and most importantly prevents the two from bonding to one another. The grease allows the clamp to hold tighter (and I'm going off memory from advice years ago, it's worked every time so I haven't questioned it in 20 years) because as it tightens down the seat tube can get a tighter grip without binding as it squeezes from metal to metal friction.
Example... I had issues with my road post sliding down a few months ago. Turns out I had forgotten to grease it during assembly. I greased it with moly grease. Holds like a champ now.
Old 06-10-09, 10:54 AM
hernick
Bikes: Fuji Touring 64cm, Peugeot Canada PB-18 61cm and winter beaters
When I got my lightly used Fuji Touring, the previous owner had never been able to get the seatpost to hold tight with the stock Fuji clamp. Why? Fuji shipped the bike with the wrong diameter seatpost clamp!
$5 later my new, proper diameter clamp has solved all seatpost-related issues instantly.
Just like replacing the headset-mounted canti cable housing stop with a fork crown housing stop solved the braking problems the previous owner never could solve... And filing off the alu dustcaps of the front hub solved the rubbing problem they had...
Ah well, what I'm trying to say, is don't think just because Fuji made this bike the way it is, that they took the time to make sure they were using the proper components to build it up.
hernick is offline
Old 06-10-09, 11:35 AM
Spasticteapot
The resins used to assemble carbon-fiber parts are generally very sensitive to solvents and detergents. Standard grease may cause long-term damage.
Spasticteapot is offline
Old 06-10-09, 11:48 AM
mud
Lurker
mud's Avatar
Bikes: 07 Fuji Professional 2.0, Specialized Roubaix SL4 Elite
I had the same problem on a Fuji, I used a little sand paper on the stem, solved the problem.
mud is offline
Old 06-10-09, 11:51 AM
SaladShooter
This is a metal to metal connection, not a carbon post.
Old 06-10-09, 12:23 PM
Spasticteapot
Yes, but if you DO have a carbon post, you need the carbon paste.
Old 06-10-09, 01:44 PM
SaladShooter
Yes, and if you have two cats and are making anti-gravity device, you need super glue.
Old 06-10-09, 02:52 PM
Fidelista
Zip-ties are just as effective IMO,and allow for disassembly and possible restoration at a later date.
If permanence is desired, a metal bracket may be fabricated and attached to the rear mounting hole after drilling and tapping (this may require the use of a vise), or a 10mm bolt may be forcefitted with care. This may also require the use of a vise.
Brazing or welding are not recommended due to the possibility of heat distortion.
Fidelista is offline
Old 06-10-09, 02:55 PM
Ex Pres
Cat 6
Ex Pres's Avatar
Quoted: 500 Post(s)
Liked 184 Times in 119 Posts
If the grease, paste, and anti-gravity cats don't work, I'm with RG and you may need a post 0.2mm larger.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Ex Pres is offline
Old 06-10-09, 03:08 PM
Wordbiker
Pwnerer
Wordbiker's Avatar
Liked 4 Times in 4 Posts
Don't overlook the simplest solutions either.
Grease the QR lever threads and the cam interface (if it has one). Much of your force will be resisted by friction at the lever and threads. Greasing eliminates the friction and increases the clamping torque.
Originally Posted by ahsposo
Ski, bike and wish I was gay.
Wordbiker is offline
Old 06-11-09, 07:15 AM
AndyK
AndyK's Avatar
Bikes: '11 TIME NXR Instinct, '03 De Rosa Planet '79 Paris Sport (Moulton)
Quoted: 17 Post(s)
Liked 16 Times in 12 Posts
Originally Posted by neil0502
btw:
[sorry]
Ha!!!
AndyK is offline
Old 06-11-09, 04:28 PM
norwood
GO BIG RED
norwood's Avatar
Bikes: 1996 Bianchi Veloce 1993 Bridgestone MB-3 1992 Trek 700 1992 Trek 820
Originally Posted by Retro Grouch
Hmmm.
+1
A properly sized metal seatpost should fit slightly snug in the seattube (unclamped) and should not need any special concoction or super-tight clamping. It just sounds to me like the current post is slightly undersized. If you replaced the seatpost using the old one for size reference, then you didn't really change anything.
norwood is offline
Old 06-11-09, 04:39 PM
DannoXYZ
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
Yeah, what Retro said. Make sure the two ears at the top of the seat-tube where the post-clamp goes through doesn't touch. If they do, you can crank on the clamp as hard as you want, but it's not gonna clamp down on the post any harder. Someone may have inserted a smaller seatpost in there. Verify that the slot on the back of the seat-tube is parallel and the ears aren't touching.
DannoXYZ is offline
Old 06-11-09, 08:57 PM
SSBully
HAMMER DOWN
SSBully's Avatar
Bikes: Sold '08 Jamis Coda Comp, building a Leader 720TR. I know, let the hating begin!
Or you can go the super cheapo route(as long as the ears on the seattube aren't touching) and cut a 1" wide strip of metal from a beer can and use that as a shim in between the seatpost and seattube, then close your clamp. If the ears on the seattube are touching, take a dremel and cut a slot between them, allowing them to be compressed again, from the force of the seatclamp.
SSBully is offline
