Is my road bike too big for me?
I'm a complete noob to road biking and made a rather quick purchase of an entry level road bike from Amazon the other day. (Wish I had researched more)
Issue #1 : I'm 5'8" - 5'9" and with that alone I went ahead and bout a 54cm frame. When straddling, the frame does barely touche my balls...but I can stand flatfooted and bounce a little bit as long as I rest my balls on the frame.... From my understanding, there should be a small gap of space between your balls and the frame. This honestly isn't a huge deal for me but then again I'm new to road cycling and don't know any better.
Issue #2 : When I'm riding, my hands naturally go to the "ramps" or the "shoulders" of the handlebars. I do not feel comfortable going ALL the way to the hoods (with my fingers on the breaks) because I feel way too outstretched. So instead, I hold this part:
![](https://bikeforums.net/attachment.php?attachmentid=384608)
I basically only feel comfortable going all the way to the hoods when I'm going downhill so I can break if needed, otherwise I avoid it because I feel outstretched.
With me not being comfortable on the hoods, feeling outstretched and whatnot, could that be an indication that my bike is too big for me? My seat is pretty much all the way forward, maybe I can move it a few more cm. Should I play with the handlebar postion a little more and see if that helps?
Maybe you can a shorter stem to bring the controls closer to you. This is why I have found personally that the length of the top tube (or effective top tube) is much more important than stand over. A person can have a bike that they can not straddle the top tube but still ride comfortably. But if you can't comfortably reach the brakes and shifters than that is not good which is why I have learned what length top tube works for me and I try to shop based on that.
Luckily this is an entry level bike and I assume you didn't spend much money on it from Amazon. If you get more serious you'll likely outgrow the bike quickly and want to upgrade so you can do a better job fitting the next bike. But getting a shorter stem may help with this bike. You may also be able to get a zero setback seat post which will let you move the saddle closer to the bars (assuming this bike came with seat post that has set back position)
For the record, I'm 5'11 and I ride a 54 road bike. But most people my height seem to ride a little bit bigger frame and I think a lot of people 5'9 fit a 54. But your proportions might be more similar to me. A lot of people my height ride 56 and when I ride a 56 I feel like you (way too stretched out). But I have made 56 fit with a shorter stem but if you go too short on the stem like 80mm or less it can effect handling
Here is my bike: as you can see the actual handlebars are pretty long.
![](https://ecx.images-amazon.com/images/I/71DIV50w0oL._SL1500_.jpg)
Since you don't have brifters that opens more possibilities. You might be able to switch the bars to flat bars, risers or bullhorns and have cross levers on the flat portion if there is enough room for the shifters and brake levers on the flat parts.
This stuff is a little too complex for me, I'd rather just keep the drop bars and make the necessary adjustments.
Getting a shorter stem is the first thing to try . See if the stem has a size on it. It is probably 100mm so you might want a 90 or even 80mm. The Vilano website doesn't have good details. I can tell you the stem needs to be 1 1/8" with 25.4mm clamp size to fit your handlebars. It looks like there are spacers below the stem. If you haven't already, you can try moving the spacers on top of the stem to lower the handlebars/stem to a lower position.
Maybe something like this?
Amazon.com : Zoom 25.4mm Adjustable Stem : Bike Stems And Parts : Sports & Outdoors
Bikes: Cannondale T-2000 & SP-1000 (Silk Path hybrid)
Don't worry about that stand-over height. That used to be way everybody rode a few years ago - tippy-toed on the top tube when stopped. Good looking bike, by the way.
If you're not comfortable in the drops, the first thing I'd suggest is getting an allen key wrench and rotating the handlebar up slightly so you can reach the brakes easier.
Get the saddle position in some semblance of a balance point where you're not sliding forward or backward due to tilt and fore-aft where you can pedal comfortably, and then decide if you want a shorter stem with more rise.
I don't have any experience with adjustable stems, but that looks pretty neat. At least it will let you decide what angle you need and/or you can rotate it lower when you get some mileage and start feeling sportier. Do verify your handlebar size before ordering. (Some handlebars have the clamp diameter printed on front near the center, or you might find the handlebar model in the specs and do the mighty Google.)
Here is a direct link to the bike, I have the 54cm size: https://www.amazon.com/Vilano-Aluminu...ad+bike+vilano
Full Specs:
- Speeds: 21
- Frame: 6061 Double Butted Aluminum
- Fork: 700c 1 1/8" Threadless
- Shifters: Shimano A050
- Front Derailleur: Shimano
- Rear Derailleur: Shimano
- Crankset: Alloy Triple 50/40/30
- Wheelset: 700c Doubled Walled CNC Alloy Machined Sides
- Freewheel: 7 speed
- Tires:700c x 25c
- Chain: KMC
- Brakes: Alloy Caliper
- Headset: 1 1/8" Integrated
- Handlebar: Alloy
- Saddle: Urban comfort
- Seatpost: Alloy 27.2
On Vilano's website, the bike is named Vilano TUONO.
Thanks, I had already adjusted the handlebars to my liking (they were more pointed downward before) and I have my seat to the max forward position it could go and a slight downward tilt (for my own comfort). It's still too much of a reach for me to get down to the hoods with my fingers resting on the breaks, at least comfortably. I'm not sure if it's just my proportions (somewhat short arms, but then again I don't know what's considered short) or the fact that this particular bike has a really long stem, long handlebar horns, and brakes that are hard to reach unless you have big hands to begin with,
Hehe - it's hard for me to reach down in the drops, too, but I've been doing something about that, slowly but surely.
If your bike has the setback seat post as shown at Amazon, you could try turning it around and adjusting the seat rearward to see how that feels. When I see a setback seat post coming standard, I wonder if the manufacturer included it because it was hard for testers to get behind the bottom bracket.
I really think I just need a shorter stem and that that would be the simplest resolution.
I'm currently looking at these stems from Amazon, no idea if they would fit my bike though.
1. Robot Check
2. Robot Check (this one has a billion sizes which I have no clue what size I would need)
Liked 671 Times
And with the advent of zero-setback seat posts I have not seen seat tube angles become more laid-back, if anything it's the opposite to create tighter rear geometries.
In any case the OP should first do a conventional initial saddle height adjustment with a level saddle that is centered on the seat tube axis, and take it from there. There is some method to this. If he's tilting it downward, the saddle is probably not right, and he shouldn't be adjusting handlebar position without improving it (at least checking it) first.
Liked 671 Times
As far as too big, I don't think it's too tall. That little bit of contact will not occur often, in my experience. What can really hurt you is hard contact with the pubic bone, and what you describe is not close to giving you hard contact, or any contact.
It might be too long, but we'd need to see pix to get a handle on it. With pix we can also help to get the saddle better adjusted, too.
As far as reaching into the drops, don't worry about that until you get the saddle more dialed.
Are you pushing yourself back with handlebar pressure as you ride?
Bikes: Franken-mountain bike, mid-90s Performance TR1000, 1990 Cannondale ST400
You could check if your local shop has any used stems kicking around for you to try out. That way you could get the feel for a few different lengths.
If not, I might suggest taking a look at the Wrench Science bike fit calculator. I'm sure it's not exact, but it'll get you a ballpark overall reach number based on your body measurements. Then, all you should need to do is measure the effective top tube length of your frame and the reach of your handlebars with a tape measure, and subtract these from the overall reach the calculator provided. The result should be the stem length you need, give or take a bit. This method suggested a 125mm stem for ke. Ended up trying a 120 and a 130, and chose the more comfortable of the two.
Thanks for the replies guys. I honestly feel that my saddle position and handlebar tilt is at the proper position to suit my needs and my comfort.
I saddle is at the max forward position with no tilt, it's completely level and it feels comfortable.
I just need a damn stem. I think I'll just visit a LBS tomorrow and see what comes of it.
Bikes: Rivendell Chevoit and a Panasonic 1986 7500 MTB
How much have you ridden? Are you leaning forward from your hips, or are you letting your back curve? It's healthier to bend from the hips.
Bikes: Émonda SL 6
Hey man, this vid might help - https://www.youtube.com/watch?v=FAl_5e7bIHk
Thanks for the replies guys. I went out and got a much smaller stem from a LBS. I forgot what size exactly but it's much smaller and helped with the reach tremendously. I still have to have my seat at the max forward position but at least I can reach the hoods better now.
Down the line when I sell this bike and get a better one, I'll definitely consider looking at the smaller sizes considering my proportions (30" inseam, short arms but long torso). I should have known better than to just get the medium 54cm based on height alone, but I just wanted to ride and didn't know any better lol.
I hope the small size bikes aren't too small for me though since I'm probably at the very end of the spectrum for a small. But I guess it's better to get a smaller road bike than one too big right?
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Liked 208 Times
