How do You Keep Your Helmet Chin Strap from Loosening?
Quoted: 1185 Post(s)
Liked 842 Times
Use a sewing needle and a piece of strong thread to put a stitch through all 4 pieces of strap. Nylon thread works good. Tie a couple of good knots, and melt the ends with a lighter. We used this method to keep parachute harnesses from slipping out of adjustment.
well hello there
Quoted: 503 Post(s)
Liked 337 Times
Happens to me too. But the strap loosens in such small increments that I only need to tighten it back up about once or twice a year.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 144 Times
A PITA for me too, since it takes a couple minutes to sort it out when I'm anxious to hit the road. I think I'll try gluing it next time I find myself dealing with it. I have to customize all sorts of products to get them to function properly, so why not the bike helmet...
Likes For gringomojado:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2663 Post(s)
Liked 5,861 Times
Added an O ring - and had to use hemostats to get the ring over the buckle part. Time and a few rides should tell. Otherwise like the ideas about needle and thread and glue gun.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
loose strap on my new SMITH PERSIST helmet
Now its very rigid with a small elastic band wrapped around the strap twice and very discrete...no one can really see this neat fix!
Quoted: 4857 Post(s)
Liked 4,001 Times
I've done that on a number of helmets. And like another said, I find the expensive helmets need it more. I use a Speedy Stitcher, two stitches and a square knot. Easy and easy to slide a knife under to cut later.
ignominious poltroon
Quoted: 2280 Post(s)
Liked 3,503 Times
Quoted: 18526 Post(s)
Liked 15,874 Times
Likes For indyfabz:
I have to wonder if maybe some of the folks who never have had their helmet straps loosen just ride with loose straps. Being one of those who have broken more than my share of helmets as well as being old as dirt, I have owned a lot of helmets in a wide range of prices. I don't recall a single one where the straps didn't loosen. Some worse than others. The o-ring thing helps. I'd put in a stitch if I never rode in cold weather where i wanted a layer of insulation on my head, but it would be a bad fit when it was 20F or below and I wanted to wear a beanie under the helmet. So I just live with tightening it every few rides or however often it slips enough to need it.
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
Every helmet I have had did this.
Doesn't seem like such a big deal to tug on the end of the strap when I put the helmet on.
I eat tons of jelly rolls until my chin has its own jelly rolls. At that point, the chin strap is so tight it's straining to snap in half. Problem solved, no more loose chin strap.
Passista
Quoted: 884 Post(s)
Liked 741 Times
The O-ring in my Scott helmet didn't work. I used a splitter buckle from a discarded helmet as a stop on the 2 straps exiting my helmet buckle, worked OK.
Quoted: 523 Post(s)
Liked 684 Times
Yup, an extra o ring usually does the trick, also make sure the buckle is laced correctly, and keep it clean and dry, skin oil and sunblock will make it slide.
don't try this at home.
Quoted: 987 Post(s)
Liked 528 Times
My Lazer helmet's buckle slipped. I had to readjust about once a month or so.
It's plastic guide that merged the "Y" below my ear moved way too easily. I tried a bit of Gorilla Glue under the guide, but that didn't last very long before it started slipping again. and it looked pretty bad too.
My 2 year old Giro has thinner, narrower straps, and the buckle rarely moves.
I like the sewing idea. I used this on a camera wrist strap that had a cinch-down slider, but I wanted the loop to stay wide open. Just normal thread through the center of the two layers was enough. It made a small dot in the webbing. I probably pushed the needle through 6 or 8 times.
Mad bike riding scientist
Quoted: 6259 Post(s)
Liked 4,281 Times
Salt. Sweat in it enough and the straps will be stiffer than a pair of laundered long johns in Alaska in winter time.
Stuart Black
Stuart Black
Likes For cyccommute:
