Road Bike - Bike changes for lower gears/hill climbing
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 262 Post(s)
Liked 1,116 Times
Thought I would throw this in:
https://ridewithgps.com/routes/41321775
The Triple is 117 miles and 11K of climb with the max gradient being 10% but the climbs are long averaging 3-4% over 5, 15 and 27 miles.
So not really steep, but long moderate grades that will test your endurance.
To the OP, have you attempted these type of climbs yet in your training and how did you do?
Quoted: 262 Post(s)
Liked 1,116 Times
My primary road bike is my "climbing" bike so I do have the 12 speed, 50-34/11-34 combo on it. If I didn't live in a climb-fest of an area, I'd either have a 11-30 on the back or run the now-standard 52/36. However, virtually all of my rides are above the golden ratio of climbing, so granny gears it is.
Quoted: 5969 Post(s)
Liked 2,877 Times
So, I'd be fine with the gearing the OP has now. However 20+ miles at 3-4% would severely try my patience, and I doubt I could solve that gearing.
FB
Chain-L site
FB
Chain-L site
Quoted: 4605 Post(s)
Liked 5,144 Times
That is a lot of sustained climbing and a 1:1 ratio will be very welcome on those 10% ramps and even when tapping away up those long, long relatively shallow climbs. People often underestimate how much power you can actually generate in a low gear at a normal cadence on a 5-6% slope. It’s nearly always better than grinding away at 50 rpm in a higher gear - especially on a 27 mile climb!
I just rode a simulated profile of Mt Fuji which averages around 5% gradient for 25 km. I had a 48/35 chainset and 10-33 cassette. I rode the whole thing using mostly the lowest 3 gears at an average 230W. I only used 4th and 5th gears for a few short standing stints and flatter sections.
Quoted: 8429 Post(s)
Liked 9,356 Times
I see 105 10s compact cranks brand new on flea bay around $100. If that would work with your bb, I recommend it. I have a 34x29 low gear and I climb with it and I'm old and fat.
Should Be More Popular
Quoted: 22737 Post(s)
Liked 9,106 Times
Liked 2,877 Times
Let's just chalk it up to newbs covering their bets because they don't know which sub forum is right.
FB
Chain-L site
FB
Chain-L site
What you need for gearing depends greatly on your age, fitness and body weight. I've been riding the Colorado mountains since 2003, when I was 50 years old. Back then, 10 speed was the only and best option. I changed to 53/39/28 triple cranks to go with my 12-25 or 12-29 cassettes.
Average grades don't mean a thing if you can't get up the steepest climbs. Even 4% will start to feel tough if long enough or if there's a head wind. I came back to cycling after 8 years of in 2818 at age 65. I had 11 speed in 2010 with 50/34 compact cranks. I still had one bike with those cranks and a 12-27 cassette in 2018. That wasn't low enough for a 10% grade so I got a 48/32 crank and 11-34 12 speed Campy setup. Until recently I had Shimano GRX 46/30 cranks with SRAM AXS 10-36 cassette. The older I get, the lower my gearing goes.
As someone else noted, the 46/30 GRX cranks would help and they're cheap if you can find leftover 10/11 speed models or good condition used. The only issue is the chain line. You'll need 2mm spacing washers behind the 8 chain ring bolts to move the rings inward. I have the 12 speed model on 3 bikes.
Likes For DaveSSS:
Quoted: 4029 Post(s)
Liked 7,593 Times
You really should spend some time to learn a tiny bit of math. If the OP added only 1 tooth on the big end of his cassette, the effect would be much larger than the added weight from the heaviest disc brakes.
Quoted: 456 Post(s)
Liked 1,088 Times
My gravel bike is running 46-30t and 11-36t cassette. I can climb most mountain trails with this combo, but there are times I wish I had something like a 44/42-28/26t chainring. I prefer an 11-36t cassette mainly because anything bigger doesn't feel as concise when shifting on a 2x setup.
