Who makes the best 1" threaded headset?
Bikes: Homebuilt steel
Quoted: 2213 Post(s)
Liked 428 Times
I get a good laugh everytime I hear the clones say that King headsets are the best. Yes, they are the most expensive, but not the best. I used to install King headsets on all high end bikes. Not one, would I recommend to a carbon fork steerer user. The King mechanism leaves a scoring mark on a fork steerer. Repeated cycles and abuse would eventually lead to a crack and possibly steerer breakage.
I’m pretty careful and anal about my equipment but every headset I’ve ever used, other than a King, suffered brinelling failure after a few years. King headsets seem bullet proof in this regard thus I use them on most of my bikes.
To concur with what bellweatherman said, King threadless headsets put a lot of pressure on carbon steerer tube forks and will create a dent where the top bearing contacts the tube. I’ve got 9000 miles on one bike and this thread reminds me to pull that bad boy apart again and give it a good inspection. This IS a real concern, and people with lots of miles on their King HS/carbon steerer tube bikes should pay attention.
Bikes: Too many to count
Wrong! Hincapie's bike had an aluminum steer tube. https://www.cyclingnews.com/road/2006.../hincapie_trek
The fork steerer still failed at the junction between the stem and headset, caused by the scoring mark left by everyone's favorite headset. I think Hincapie opted to switch out to a lighter carbon steerer fork against the recommendations of his team mechanics. The mechanics obviously are not going to blame a crash on a component issue.
Quoted: 143 Post(s)
Liked 163 Times
Considering the OP's question was "what's the best 1"threaded headset?", your point doesn't really apply in this case. I sure like my Chris King for what I'm using it for (mountain biking), despite being a "clone" in the eyes of bellweatherman. I think I can live with that-
You need a new bike
After making several google searches, I don't seem to find any reports of C-K headsets causing steer tube failures. I certainly would expect that if your assertion is true that there would be numerous reports of face plants caused by C-K induced failures. Both C-K headsets and carbon forks have been out long enough for this sort of problem to have surfaced. Do you have any substantiating links?
I'd also expect that C-K's insurance carrier would have forced the company to recall headsets that cause any significant risk of steer tube failures, or at least a warning that such headsets not be used on whatever types of steer tubes are vulnerable to the damage you claim to be caused by the headset.
BTW, I know several randonneurs who put over 10,000 miles per year on C-K headsets (unknown steer tube material) but have yet to see one of them have a steer tube failure.
Bikes: Wabi Lightning, fixed 13.6 pounds. Cera steel road bike Campy veloce 9s
At our shop it's the standard headset on our go anywhere, steel framed, Rohloff equipped trekking bikes, be it in 1 1/8 size.
Sadly, they are being discontinued and we will be replacing them with Tange headsets of the same quality.
Liked 5 Times
George Hincapie's crash in Paris Roubaix a few years ago was due to a carbon fork steerer break. The mechanics did not blame the crash on the sponsor's componentry. However, if you look at pics of Hincapie's steerer break, it is in the exact location as where the King headsets leave this scoring mark. Granted, people aren't going to ride super light carbon forks over cobblestones at speed, but the King design is flawed in this regard.
I think most on here are willing to listen to your counterpoint bellweatherman, but it is starting to sound like a troll. You offered an opinion that was a big outlyer, with some innuendo, some apparently wrong information, some name calling and some alleged better information than others. Your info is now being questioned. I really hope you can back up what you implied. The only part of your story that seems to have backup is the tight tolerances on the cups.
I also hope you will chime in with your favorite headset nomination(s) given your other strong opinions. This is not "Celebrity Apprentice" or "Survivor" where the one who can make others look the worst without taking risks will win.
Bicycle Repair Man !!!
Tange delivers a really good value for the dollar and I believe, and someone might confirm this for me, that Kuwahara used Tange to produce their rather exceptional headsets. I'd choose the Levin as it is an exceptional value.
Stroglight A9 - 'nuff said...they are legendary.
Shimano headsets of very high quality and it looks like Harris has an excellent selection of them.
I can't see myself forking out $$$ on a CK when there are other products that deliver equivalant performance at a much lower cost.
The longest lived headsets I see are those I find on old Raleigh bicycles... they seem like they were designed to work forever and seem nearly wear proof if they are kept properly adjusted and maintained.
Liked 428 Times
I’m not defending bellweatherman, but I can categorically state that the steerer tube on my Look HSC-3 fork IS DENTED where it contacts the King headset. Is it going to fail? I sure as heck hope not! Had another frame with Columbus Muscle fork and King headset and it also had the dent. Is there a design flaw in the headset which creates undue stress on carbon steerer tube road forks? Maybe. Fortunately, carbon steerer tubes are pretty darn robust and apparently seem capable of absorbing a LOT of abuse.
BTW, Darrell McCulloch of Llewellyn Cycles posted a similar notice about King headsets and carbon steerer tube forks on the Framebuilders list a while back. Darrell is a world class framebuilder, and wrenched for the Australian National team for a good many years. Very qualified source of information. https://www.llewellynbikes.com/main.htm
Likes For Nessism:
Quoted: 143 Post(s)
Liked 163 Times
Jonnys ilegitimate Father
Bikes: too many too list
Also the O.P. asked for THREADED headset suggestions. How the debate turned into a slam against a threadless headset is funny.
I have an old riding buddy who has an original 20+ year old King that has been installed in at least 7 1 inch bikes over the years. He has taken care of it and he is still riding it in his Ritchey P-22. They are expensive, but if this is a "best' competition then King wins hands down.
FYI Shimano never made threadless headsets to avoid paying a patent fee for it's usage. Besides keirin usage, this why they have continued to make only threaded headsets for so long. We used to bore the threads out of the top race and use em threadless before there was a good choice of quality aheadsets. Any of their cartridge headsets are a good economical choice.
The manual only says 24TPI, which means { Campagnolo BC1", BSC, ISO, .. }, but exaxtly which one?
The GripNut costs 220 euros here, and the handmade steel NivaCrMo fork (650g!!!) costs 300 euros. That's a lot of money.
For 500 euros I would like the headset fork combination to be perfect, rather than a botched job that "just works".
The homemade fork has not yet been threaded, I would like to understand exactly which thread I should use.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3931 Post(s)
Liked 6,587 Times
Likes For SurferRosa:
Quoted: 1955 Post(s)
Liked 2,200 Times
The best threaded headset is one that fits stack requirements, especially if it needs 35mm.
John
John
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 58 Times
I concur with the Chris King fan boys here, CK headsets are just about bulletproof. I have had one installed on my primary ride since 1998 with three clean and grease cycles, zero signs of wear or brinelling. I also have the Shimano 6500 Ultegra headset installed on 4 additional bikes. Again, I have found the Shimano 6500 headsets to be pretty close to indestructible, thousands of miles and many years of use with no perceptible wear or problems.
Quoted: 4867 Post(s)
Liked 4,023 Times
The bike of my avatar photo came with a Chris King Gripnut HS. It would not stay in adjustment. By 400 miles it was loose enough to rattle on tough roads. 600 miles was the absolute limit. I figured I simply did not have the hand strength to get it tight enough but good bike shop mechanics did no better. Neither did the CK factory when I took it there. At around 8000 miles (quite a few adjusts) I finally took it off and put in a Tange. Dead simple. A tweak at 200 miles, a tweak every few thousand. At 8k, either a new $35 HS or loose balls in the lower cup to take it to 10k.
I hear the Gripnuts are wonder headsets. I won't touch another until I know why I had that nightmare. (My other good bike has a threadless CK that's been dead easy and I'd do that one again in a flash if it wears out. I also love the Stronglight roller bearing HSs. (A23?) My Mooney's at 27k feels brand new.
Quoted: 554 Post(s)
Liked 488 Times
Ideally you would have cut the thread in a lathe before assembling the fork, using the headset you intended to use as a guide to depth of cut for best fit. Then build the fork and put it back in the lathe to cut the crown seat, again using the headset as a guide to finished press-fit dimension.
Between the DA 7400, Ultegra 600, Campagnolo C Record, and Stronglight A9 headsets I had on my bikes in the late '80s and early '90s, my vote is for the needle-bearing.
Likes For kcjc:
