Mercier 300
I will do some digging once I am home and see if I can find any numbers.
The reynolds decal is certainly boom era as mentioned. The decals are the same as my 1972 px-10 except there is only one fork decal on the drive side and it has reddish font instead of the typical green. Maybe a French way to save half a cent per bike or it has been lost along the way.
I have also potentially found a damaged stem bar clamp after reviewing pictures this afternoon. Undersized French diameter bar and overzealous clamping?
![](https://i.imgur.com/PhsKzWh.jpg)
Stop reading my posts!
Quoted: 1476 Post(s)
Liked 1,123 Times
Red font in a 531 decal usually meant "SL" or later was called "531 PRO" (at least for the complete tubeset) but not sure if that's the case for fork-blade decals or if (as you think) it may be a case of using what was on-hand that day. Also not sure if the SL/Pro 531 sets came in metric versions but that would not have been a factor for just fork blades.
Quoted: 4722 Post(s)
Liked 3,049 Times
Bad example
Quoted: 899 Post(s)
Liked 427 Times
![](https://i.imgur.com/bNRkl2J.jpg)
Date code July 72. No other codes or serial numbers I could find on components or the bike itself.
![](https://i.imgur.com/4vVyzmp.jpg)
Unfortunately cracked stem clamp. Will have to find a french stem now.
Quoted: 470 Post(s)
Liked 351 Times
Mine also has chrome as well as different graphics. I hope to learn whether Narhay's bike, and others like it, appear different because of the model year or perhaps because it is a special model. To me it looks just like the Gan team bikes. Any any case it is a fine looking bike!
Liked 3,049 Times
Bikes: A few
Quoted: 290 Post(s)
Liked 203 Times
It's all Simplex Criterium.
To be totally honest, my sister was the original owner of the bike. I purchased it from her in the mid/late '70s That sort of explains the extended seat post and stem. It has all original equipment, except for tires, spokes, bar tape, cables and housings. Kickstand is missing though.
Liked 3,049 Times
1st generation Dura-Ace side-pull brakes were boss in the mid-1970s. They were 40% less expensive than Campagnolo, with all the performance and drilled levers to boot. The quick release wasn't as nice and they didn't have the patented toothed washer but you could buy something that performed the same function for 2 cents. MAFAC Racers can perform almost as well. They have just as much stopping power but aren't quite as stiff. They're more tunable due to the number of set-up parameters but this also makes them more difficult to set-up and prone to changes in settings. The first generation Dura-Ace side-pull brakes were my favourite side-pull brakes for over a decade.
I am assuming a set of cane creek hoods will fit on the DA levers.
Ive also found the serial number in the head tube badge. 383759.
Not that serials are ever as straightforward but 1973, august, 3759th bike? The mid 1972 component and boom reynolds decal support this as well.
I started the teardown yesterday:
![](https://i.imgur.com/01jbOa0.jpg)
![](https://i.imgur.com/ttfdaya.jpg)
![](https://i.imgur.com/BrX9qSz.jpg)
The bearings in the headset and bottom bracket were bone dry. Hopefully it is salvagable but the lower crown race and cup in the headset might need a replacement as there is some pitting.
Quoted: 5937 Post(s)
Liked 3,643 Times
Cool. I'm wrapping up a 1979 Trek 510 build. Once I wrap that up, I think it's time for me to get to my Mercier 300. This is mine as I bought it.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1288x966/mercier300_9827fc4f301e64fa6161b5b3bf558468e3a7890d.jpg)
Quoted: 3882 Post(s)
Liked 3,502 Times
Thanks very much for the update!![Thumbs Up](images/smilies/thumb.gif)
Now that HS disassembled maybe you could check steerer to see if marked NERVOR or Reynolds.
![](https://i.imgur.com/H0VPM04.jpg)
I polished and waxed the frame and I think it came out pretty nicely. A few rough spots around the bottom bracket but otherwise the frame is in good shape. The bottom bracket was bone dry but turned out ok after a lot of scraping and polishing with no damage to the cups and spindle. The upper headset is so-so but the lower assembly needs to be replaced as it is pitted and the headset doesn't swivel properly without binding or having too much play.
Likes For Narhay:
Liked 3,502 Times
Thank you for this update.![Wink](images/smilies/wink.gif)
Fine to see she's coming along nicely for you.
Have not before seeen a 300 with a transfer directly below the tubing one. Is this perchance from the retailer? Went through the gallery to attempt to read it but in the closest image the pump is in the way.
In the image from the front of the machine it appears the front wheel is not quite centered; off by two mm or so. You might wish to check it with a dishing gauge.
Do you plan to look for a replacement P3?
Liked 3,643 Times
Velo orange sells a French threaded headset. That's too bad about the original headset though. Those old stronglight headsets are good quality.
Thanks for all the comments. It is nice to see people responding to things I post.
![](https://i.imgur.com/CUtyGm2.jpg)
![](https://i.imgur.com/EcFgNia.jpg)
![](https://i.imgur.com/8UooQ69.jpg)
![](https://i.imgur.com/QfAWZ99.jpg)
The decal is Bloor Cycles from here in Toronto. And juvela you are right, the wheel sits about 2mm to the drive side. Annoying but testing a few wheels resulted in it being off by a little bit here and there but not by a large amount. The fork legs may not be perfectly straight but I think I can live with it for now and maybe get it checked at a framebuilder when the pandemic is over. The dropouts are aligned and they continue to be aligned as I screw the barrels to one side or the other.
As for the headset I had this issue with a stronglight P3 on a Gitane Tour de France. Replacing the lower headset crown race and cup with a low stack new Tange unit sorted the problems there and I hope it will do it here too. I just have to measure the crown race to see whether it is 27.0 or 26.4 unless someone here knows. The problem with replacing the whole headset is that the stack height on these P3s is very low (low 30mms) and new replacement french threaded headsets have much taller stack heights (40mm+).
