Moistures not so Unique Frame-Fit?
Expired Member
Quoted: 3803 Post(s)
Liked 5,804 Times
Skeptical regarding this epiphany....
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
I gave it a try. I completely dreaded it. It wasn't terrible, but switching to a 40mm stem with the drop bars felt much better, yet still aggressive enough where I would still have to adapt to a fairly aggressive position.
Since then no. Last year before i got a bike in March, i weighed 245. I was working out everyday and eating crazy amounts of food . I got down to 220 after biking everyday which is the weight I usually hovered around. Then, in December I ended up getting down to around 190lb.
Drip, Drip.
Liked 193 Times
By the way, I switched to this 80mm riser stem I had laying around. The "effective" length is 70mm. It feels much, much better than the 40mm stem after trying it out quickly. Its still not long enough to put my into a position which the bike is designed around, however. I'll ride around like this a bit and start to gradually switch to longer stems with the goal of comfortably adjusting to 100mm.
Drip, Drip.
Liked 193 Times
So honestly, I do love the bike and all, but considering thst I didn't find it comfortable with the stem and bars it was designed around indicates its not the bike for me despite the fact I've made it work well for me.
Do you guys in your racy positions genuinely find butt comfort even with those very stiff, thinly padded seats?
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
And I don’t care how you fit your bike or don’t. I’m just concerned some total newbies that’re actually looking for and are receptive to advice/suggestions on bike fit are going to come on here, see some of your stuff and take that as an actual baseline to work with.
Think about it.
That’d be messed up, man.
(Humblebrag): My saddle has virtually no padding at all yet on Sunday I rode 108 miles with 7000ft of climbing on my fixed gear bike; I was on the bike for about 8 hours; I had absolutely no butt soreness whatsoever.
Sure I was pretty useless for a couple of days but no localised pain at all. The more upright your position, the more weight you’re putting on your butt and more shock through your spine.
Habitual User
Quoted: 5110 Post(s)
Liked 8,430 Times
Yes. There is an adaption period, and finding the right shape for your body is critical, but I have no saddle discomfort doing 4+ hour rides. If you're not aware, sitting on a bike seat is not like sitting on a chair. The "sit bones" of your pelvis are the critical points.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
You had a cadence of 88 in the first video with a little fluctuation between the start of the video and the ending of it. You were picking up speed as you rode off into the sunset...
Likes For Bigbus:
Quoted: 7150 Post(s)
Liked 11,352 Times
You guys should not feed the troll.
Likes For Moisture:
Drip, Drip.
Liked 193 Times
I'm really happy with the way these 190mm crank arms feel for my spin. Its so much better than what i have used in the past.
In the future, I think I would go 187.5mm.
As for the 80mm stem I'm currently using, I feel like I shouldn't go any longer. Do you guys think that the Nishiki is still a good choice for me despite the fact im not exactly riding it in the position it was designed for? It fits me comfortably as is and I love riding it, but if it wasn't for the thickly padded seat, I wouldn't be able to ride it very far.
Drip, Drip.
Liked 193 Times
With that being said obviously its better to have too much weight in your saddle versus your handlebars..
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
You are putting too much weight on your saddle... because stem is too short. It shows in the videos. it's not a bike seat, it's a saddle. Their is a difference. You are sitting on the bike, peddaling the bike. You should be riding the bike. Looks like you are peddaling a spin bike.
Frame size looks good to me. Listen to what everyone is telling you.
Drip, Drip.
Liked 193 Times
I'm going to change to my original 100mm stem today. I will upload pics of my bike with the current 80mm stem as well.
quite frankly, I am getting sick of riding so upright with my weight in the saddle.. putting my body over the bars with a 90 degree bend in my elbows, it becomes especially apparently just how long of a stem I need to achieve the proper riding position.
90 degree elbow bend? Where did that come from? Do you mean 90 degree shoulder angle?
Expired Member
Liked 5,804 Times
^^^^ He mentioned that in this thread as well. https://www.bikeforums.net/fitting-y...size-stem.html Like so much of this weird stuff, nobody knows how he came up with it.
Likes For shelbyfv:
Drip, Drip.
Liked 193 Times
I'm about 191cm.
I switched back to my original 100mm stem yesterday. I'm very happy with the fit. I already have the bars comfortably below the saddle, but Im still not quite as low as i would like.
Ican see why you guys suggested 140mm for the stem - if i really want to get low.
The longer stem slowed down the handling more than I expected. But the bike feels great. I will get around to uploading another cruising video sometime.
Drip, Drip.
Liked 193 Times
Much better!
Would going 120-140mm stem be too long? The handling already slowed down enough. It feels fantastic at speed though.
140mm + flat bars i think will be the longest id want to go even with long term goals in mind.
If I find a drop bar that is wider at the hoods (not just the drops like those gravel bars) , ill consider switching back.
