Ceramic Hub Bearings
Um, maybe paying a substantial price difference to get a miniscule gain that is likely not even noticeable and might not be even readily measurable?
For non-cartridge bearings (the classic "cup and cone" design), there's also potentially another issue. Ceramic bearing balls are generally harder than steel races (70-90 HRc for ceramic vs 50-70 HRc for most varieties of case hardened steel). That means the order of damage inside a non-cartridge bearing using ceramic balls now is likely to be (1st) cones, then (2nd) cups, and (3rd) bearing balls.
This potential disadvantage also exists for cartridge bearing designs using ceramic bearing balls and hardened steel inner/outer races without a ceramic race insert.
I'd personally rather replace bearing balls than cones or cups, particularly on vintage hubs. So I'll stick with grade 25 or better steel bearing balls, thanks.
Quoted: 3657 Post(s)
Liked 3,095 Times
Adding up all the "unnoticeable" lighter parts has allowed me to shave two pounds off my bike.
Liked 3,095 Times
Expired Member
Quoted: 3811 Post(s)
Liked 5,824 Times
Liked 3,095 Times
However: as I recall bearing damage usually takes time to develop. And if the decision was to use ceramic bearing balls in a classic "cup and cone" bearing, IMO it could indeed turn out to be a bad decision if it causes premature failure of hard-to-find vintage replacement parts (cups/cones) through the bearing balls being harder than the races and causing premature race wear/pitting/failure.
Expired Member
Liked 5,824 Times
As they say, anything's possible!
![roflmao](images/smilies/roflmao.gif)
Liked 3,095 Times
This thread is quite new. I have no idea - nor do I particularly care - if/when he installed ceramic bearings in his bike. I don't recall him indicating anywhere above if/when he actually installed them, and I'm not going to take the time to research older threads to find out.
I'll let you know when my races shatter.
Quoted: 575 Post(s)
Liked 619 Times
Agree, w/ the light cycling loads on the bearing & balls and races are mostly damaged I suspect due to spalling and possibly some brinneling of the races which could take place in a hybrid ceramic bearing with steel races most likely due to lube contamination or lube failure and the ceramic balls would not aggravate these failures or even ameliorate. In a all ceramic bearing in cycling loading the only thing I can see affecting the bearing would be contamination of the lube.
Quoted: 1883 Post(s)
Liked 1,755 Times
What I wonder about is the actual application. Is this a situation where steel balls are replaced by ceramic balls? Or is it where cartridge bearings are replaced with cartridge bearings with ceramic balls? How much will it cost? How much advantage will there be? If the advantage amounts to fractions of a percent, maybe you should look elsewhere unless the conversion is very inexpensive
aged to perfection
Quoted: 869 Post(s)
Liked 1,310 Times
it is probably fractions of a percent in terms of lower "friction". The ceramic balls are harder, and they deform less under load. Probably about the same advantage as you'd get from high end lubrication.
Bearing speed may have something to do with it too. Years ago in the tour Franke Vandenbrouke said he could "feel the difference" with ceramic bearings in his pedals.
/markp
/markp
Quoted: 3070 Post(s)
Liked 1,228 Times
I just recently purchased a carbon wheelset. The difference in price between ceramic and no ceramic hub bearings was a whole $30. I got the ceramic bearing hubs.
Why stainless bearing balls? Dunno. Ask Shimano.
https://si.shimano.com/en/pdfs/ev/FH...-7700-1654.pdf
https://si.shimano.com/en/pdfs/ev/HB...-7700-1653.pdf
Quoted: 5991 Post(s)
Liked 2,925 Times
OTOH it might just be a translation error by whoever produced the chart.
FWIW, I'm not a fan of ceramic balls on steel races, but don't see the choice if ball material a big issue either way.
Sometimes engineering decisions turn on small details. Possibly they went with SS as a form of neglect insurance, especially for all weather users. Or they may have used SS so the balls took more wear vs. the races.
I personally think you may be right regarding using stainless bearing balls to help ensure the bearing balls fail first. In order of expense to repair, for a cup/cone axle bearing setup the least expensive item generally will be the bearing balls (per a quick check on Amazon, about of $0.017 to $0.026 cents each when bought in quantity, and perhaps even less, for G25 chrome steel bearing balls); next the cones; and finally the cups. For that reason, it seems to me you'd want them to wear out/show damage in that order.
G25 bearing balls are so cheap that it makes economic sense to simply replace them with new at each service. Hub cones usually are next, but can be pricey and hard to find - especially for high-end vintage hubs. (Plus, some recent designs have one cone integrated into the axle, like Shimano's FH-9100.) Cups? In general, that means replacing the hub body or the entire hub. For some vintage hubs, finding a replacement body/hub can be quite expensive - if it's even possible.
My issue with using ceramic balls with steel races is that ceramic is typically harder than either the cones or cups - and is also more brittle. Hit a big enough bump, pothole, or other road irregularity and it's at least theoretically possible for a ceramic bearing to chip/spall/fracture from impact while the cups/cones are undamaged. If that happens the resulting ceramic shards/debris (which is harder than the cones/cups) can quickly damage or totally destroy the cones and cups.
Personally, I think ceramic hub bearings are a total waste. This webpage from BC Precision sums up the advantages and disadvantages of ceramic bearings:
https://www.bcprecision.com/blogs/ne...ramic-bearings
I don't see how any of the advantages listed really apply to the cycling environment. And for cup/cone bearings, having a bearing ball substantially harder and more brittle than its races isn't an advantage.
YMMV. If you want to chase a handful of grams and/or a tiny fraction of a percent of total drag, go ahead and use ceramic bearings; it's your bike and your money. But since ceramic has a density ranging from about 40.7% to 76.5% of CroMo steel - and all bearing balls used in bicycles are far less than 1cm in diameter - the savings in weight (and friction) will be small.
Likes For Hondo6:
Quoted: 824 Post(s)
Liked 3,082 Times
F.Y.I. XD15 hybrid bearing,
