Caveman down! (some road rash content)
#51
Quoted: 409 Post(s)
Liked 433 Times
I recommend Polarity Therapy. It re-aligns the energetic structure. Very useful after trauma. There is no manipulation of the physical body. Often done with crystals as an adjunct. It can't hurt to talk with this person: https://www.wildrosehealing.net
--Shannon
#52
Quoted: 1628 Post(s)
Liked 635 Times
I guess I've been initiated. Only took 55 years of riding to do it, eh?
Here's the horse that threw me, in happier times - 2019 Cino, with a slightly less comfortable saddle, but otherwise just as it was last Thursday: 1973 Nishiki Semi Pro rocking 38mm Paselas
Likes For Lascauxcaveman:
#53
Liked 635 Times
That's what my friend Stuart is for
#54
Liked 635 Times
Tim, I hope you heal up fast. I hit the ground twice last year and was fortunate that it was mostly road rash with maybe some tendon damage to a finger on my right hand.... Quick reminders that what we do can have some negative side effects. It still beat sitting on the sofa eating chips. I'm sure you will be back at it as soon as the docs clear you to ride! All the best, Andy A in Durango.
BTW, I really miss your spring Metric Century rides. Good times for sure.
#55
Happy banana slug
Quoted: 1555 Post(s)
Liked 1,572 Times
All in all, it could've been much, much worse. At least you don't have to buy a new helmet. I hope you heal quickly.
#56
Quoted: 822 Post(s)
Liked 1,047 Times
I had to get back to work earlier so I was unable to complete my post with unsolicited advice.
My mom had a bad wound and ended up under the care of a wound specialist. One of the things that he had her doing was what he called "wet to dry, twice a day". This involved washing the wound, letting it dry in the open until a scab formed, usually about a half an hour, and then applying triple anti-biotic ointment and a bandage. Cleaning the wound twice a day minimizes the chance of getting an infection and applying ointment allows faster and better healing while minimize scaring. It also tends to feel better with ointment too. This worked great for my mom and I follow it myself. This can probably be done once a day since your wound isn't nearly as bad as my mom's was.
My second tip is to use a sanitary napkin or feminine pad for you bandage. It is perfect since it is soft, absorbent and doesn't usually stick. It is so much better than gauze pads or even the better bandages. Cut them to size and you can get more coverage with less pads. The thin ones work well. The first time I tried it was a revelation. Of course, my wife called me an idiot. I replied that "you had these all along and I never knew anything about it until now.". I am an idiot!
I wish you the best with the healing.
#57
Bikes: Yes
Quoted: 3284 Post(s)
Liked 4,043 Times
Seeing those numbers, I can't believe I made it to the top. I do remember about 36 times that I stopped and Tim told me the summit was just around the next bend. That was actually helpful.
My Bikes
My Bikes
#58
Quoted: 4560 Post(s)
Liked 2,804 Times
Ah, that unique blend of yellow and purple -- I know it well. Had the same colors on my busted up arm and shoulder.
#60
Extraordinary Magnitude
Quoted: 2611 Post(s)
Liked 1,731 Times
Hope you heal up quickly- and I am also happy that your cochlear device didn't get lost or broken.
And, of course the most important thing- I'm glad the bike, saddle and Acorn bag aren't ruined.
Commence to jigglin’ huh?!?!
#61
Quoted: 3466 Post(s)
Liked 2,842 Times
Broken collarbone is a typical sprinter injury.
heal fast.
need to are those anti gravity supplements.
heal fast.
#62
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
#63
Quoted: 939 Post(s)
Liked 1,352 Times
Ouch! My sympathies! I crashed and broke my collarbone riding Cino two years ago. Mine was pretty bad so they had to operate and install a steel plate (and later operate to remove it). I still have zero recollection of the crash since I had a significant concussion (and destroyed helmet). My only advice is to go hard at the physical therapy exercises to maximize your chances of getting back full functioning of the shoulder. Good luck to you!
Likes For davester:
#64
small ring
Quoted: 440 Post(s)
Liked 938 Times
I look forward to that ride again, enjoyed the two I've been on. This thread is not the triumphant return I was hoping for.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
#65
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4715 Post(s)
Liked 5,936 Times
I recognize that pic - from the skanky Symes Hot Springs Hotel in a room we shared. Yeah, good times.
#66
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1303 Post(s)
Liked 958 Times
Let me get this straight: You were riding one-handed on a steep descent and then applied the brake? It takes a brave man to admit that.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
#67
Liked 635 Times
No steep descent, that was 1/4 mile back. It was almost dead flat where I crashed, but I was still going at a good clip "taking the lane" or "vehicular cycling" or what you will. I do right side braking like this fairly often, but I think I was just a bit too aggressive this time. Not my finest moment.
