Creaking seatpost
Creaking seatpost
Old 05-24-24, 10:07 PM
  #51
RCMoeur
Cantilever believer
RCMoeur's Avatar
Liked 2,379 Times in 1,032 Posts
I'll just say that when I had creaking noises from a seatpost, it presaged the snapping of the bolt on the saddle clamp from fatigue.
RCMoeur is online now
Old 05-24-24, 10:19 PM
  #52
Duragrouch
Durable Senior Member
Liked 895 Times in 718 Posts
Excellent point! The bolt had partially cracked through, which reduced stiffness and clamp force, allowing more movement, and squeak. Good warning sign for anything on the bike.
Duragrouch is offline
Old 05-25-24, 09:52 PM
  #53
Ron Damon
Ron Damon's Avatar
Bikes: Several, all affordably priced, none exalted cult artifacts
Liked 841 Times in 554 Posts
Originally Posted by Amt0571
Then I've had too many bikes that had something wrong. Probably all of them.
This is a very strange logic as it would be highly improbable statistically that you had several faulty bikes. A more careful consideration of the issue would focus on the common element to all these allegedly faulty bicycles, to a more statistically plausible cause. That common element is you.
Ron Damon is offline
Likes For Ron Damon:
Old 05-26-24, 12:13 AM
  #54
Duragrouch
I just checked engineering tables for static coefficients of friction.
Dry aluminum against aluminum, 1.05
Dry aluminum on mild steel, 0.61
Dry Mild steel on mild steel, 0.74
"Greasy", all of the above, 0.005 (various heavy greases) to 0.23 (light mineral oil)
(By the way, dry aluminum on dry aluminum, sliding (kinetic friction) actually increases, 1.4, (most solid materials, sliding friction is less than static friction); this increase may indicate galling).
So my friends... there may be sufficient friction force on a clamped greased seatpost to hold the rider weight, but it's gonna be a whole lot less than dry.
Now, based on the above, it would be nice to find an online calculator to kick out the total axial friction force, as a function of clamp force, which is a function of the screw force or clamp lever, for dry and lubed. Some assumptions will need to be made, such as:
- Effective clamped axial length; For my clamping collar, I would assume between 1-1.5X its axial length
- Linear relationship between unit clamp force and coefficient of friction, most specifically, that clamp force does not squeeze grease out of contact point sufficiently to increase friction.
Old 05-26-24, 01:19 AM
  #55
Ron Damon
Ron Damon's Avatar
Or we, you could just go with standard practice and ample user testimony. We are not lying or trying to deceive.
Old 05-26-24, 01:57 AM
  #56
Duragrouch
I get that. If everyone is saying it's standard practice to grease the post, and there's not widespread slipping of them, there must be enough friction force. I'm just wondering how much margin there is greased. Because the difference between dry and greased is almost an order of magnitude.
I also do wonder about that part, a greased surface under pressure, whether at a micro level, the grease is being squeezed out, and also the same for anti-seize, because it's like grease but with very fine metal particles that probably stay put; just because I'm curious.
Old 05-26-24, 05:14 AM
  #57
Ron Damon
Ron Damon's Avatar
a greased surface under pressure, whether at a micro level, the grease is being squeezed out...
Bingo!
Old 05-26-24, 05:43 AM
  #58
Duragrouch
Bingo!
I think moreso with your ribbed post. But that's just a pure guess.
Old 05-26-24, 09:00 AM
  #59
grumpus
grumpus's Avatar
Liked 716 Times in 532 Posts
Back in the day when most bikes had chromed steel seatposts in steel frames we could have problems with them slipping, which was perhaps as much to do with manufacturing tolerances as material choice, but it was OK to drill a small hole in the back of the seatpost and fit a screw to act as a stop. With aluminium posts this is not such a good idea, but fortunately also a far less common problem. The greater problem with aluminium in steel is galvanic corrosion leading to stuck seatposts, which is why greasing is important. Less of a problem with aluminium in aluminium, although different alloys will still have some potential difference, but as you suggested galling might be a problem.
grumpus is offline
Old 05-26-24, 09:59 AM
  #60
RCMoeur
Cantilever believer
RCMoeur's Avatar
Originally Posted by grumpus
...but it was OK to drill a small hole in the back of the seatpost and fit a screw to act as a stop.
Best done after you're 100% certain you have set the fit and height correctly.
Old 05-26-24, 10:53 AM
  #61
grumpus
grumpus's Avatar
You can drill multiple holes in a helical pattern to allow fine adjustment, then transfer the height to a 'good" seatpost if you don't like the ventilated one.
grumpus is offline
Old 05-26-24, 11:07 AM
  #62
smd4
Liked 3,325 Times in 2,001 Posts
I prefer not to drill any holes in my bike.
I swear, the hacks you guys come up with…
smd4 is offline
Old 05-26-24, 11:23 AM
  #63
Kontact
Kontact's Avatar
Liked 2,297 Times in 1,477 Posts
Originally Posted by sweeks
I completely agree; no "strawman" intended. I was trying to explain why greasing a 6" seat tube on a frequently moved 2' seatpost is not a practical solution.
EDIT: I see the previous post. Feel free to grease your seatpost. I'll continue not to grease mine. The anodizing does eventually wear a bit, but there's no problem collecting dust or pollen, and I don't get grease on my hands or clothes. In 14,000 miles I replaced the seatpost once because it broke where I had scored it for location purposes and created a stress riser. In those miles, the post never slipped.
As my dad used to say, "One man's meat is another man's poison."
Cheers,
Steve
You're going to seize your post in place by not greasing it. That's basic bike mechanics.
Kontact is offline
Likes For Kontact:
Old 05-26-24, 11:26 AM
  #64
Kontact
Kontact's Avatar
As seen in multiple threads, you have some weird ideas about lubricants - and many of them are wrong. Maybe stop offering advice about them?
And anyone drilling a hole right about the seat tube clamp on their seatpost is asking for a broken seatpost. That's the stress riser.
Kontact is offline
Likes For Kontact:
Old 05-26-24, 12:16 PM
  #65
sweeks
sweeks's Avatar
Liked 633 Times in 436 Posts
Hasn't happened in over 20 years. Seems like waiting for the Rapture.
But, seriously, the post on a folder like mine is huge, both in length and diameter, by comparison to those on regular bikes. Mine, and thousands like it, work fine without lubrication.
All my other bikes with normal seatposts (AL in AL frame, Steel in steel frame, Ti in Ti frame) are well-greased.
sweeks is offline
Old 05-26-24, 12:39 PM
  #66
Kontact
Kontact's Avatar
The OPs bike is not a folder, so maybe advice that is intended for folders isn't applicable to this thread?
Kontact is offline
Likes For Kontact:
Old 05-26-24, 12:45 PM
  #67
sweeks
sweeks's Avatar
Good point. But there's been a fair amount of folder chat included. I think anyone who's following the thread won't be confused.
sweeks is offline
Old 05-26-24, 12:53 PM
  #68
bboy314
bboy314's Avatar
Liked 1,542 Times in 746 Posts
Yeah, I don’t know how this turned into a folding bike thread, but hopefully the very basic and important concept of greasing metal seatposts on traditional bikes is not lost on anyone reading it.
bboy314 is offline
Old 05-26-24, 01:52 PM
  #69
grumpus
grumpus's Avatar
Do you have a steel seatpost in a 1960s bike? Because that's what I was discussing - maybe you missed the context.
grumpus is offline
Old 05-26-24, 02:03 PM
  #70
Kontact
Kontact's Avatar
Most bikes ever made are steel bikes with steel seatposts. No new techniques needed.
Kontact is offline
Old 05-26-24, 02:11 PM
  #71
grumpus
grumpus's Avatar
Definitely to be avoided with aluminium seatposts, but an old steel seatpost won't crack in the same way, and it was the custom to have taller frames & shorter seatposts back then so a smaller moment at the clamp/hole too.
grumpus is offline
Old 05-26-24, 02:17 PM
  #72
smd4
Sorry—that doesn’t change my opinion about drilling holes in bikes.
smd4 is offline
Old 05-26-24, 02:20 PM
  #73
grumpus
grumpus's Avatar
A lot of those bikes are also pretty shoddy, and a slowly sinking seatpost is not uncommon, adding a screw to stop this is not a new technique.
grumpus is offline
Old 05-26-24, 08:18 PM
  #74
Camilo
Liked 1,410 Times in 906 Posts
No, not confused. But wondering why we're sifting through so much irrelevant discussion. Yeah, I know, it's the internet and digressions occur. I don't know wtf (why tf) it even came up and why it has been so prolonged. It has nothing to do with the OP, nothing,
Camilo is offline
Likes For Camilo:
Old 05-26-24, 08:34 PM
  #75
Duragrouch
Respectfully, I have many weird *questions* about lubricants, when I don't have the answer, and am always open to those that know more about a subject (I think I recognized your knowledge in a very recent other thread). I think my comments above were asking just such a question. Because the book says greased static friction is very low, but greased posts seem to hold. However I have not yet done the calculation on clamping force for what it's supposed to be, so it's still up in the air for me.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
