Old 05-22-24, 06:31 AM
  #7951
chrispope248
Bikes: 1957 Carpenter,1960s Duckett, Boardman carbon framed road. Bitzer mountain ( my fav)
Liked 3 Times in 2 Posts
Hi Ya, I have a 1957 carpenter and a 1960s ish Duckett that I'm restoring
chrispope248 is offline
Likes For chrispope248:
Old 05-22-24, 11:58 AM
  #7952
cjefferds
Learning To Fly
Bikes: '62 Schwinn Continental, '69 Raleigh Tourist (DL-1), '79 Raleigh Grand Prix, '71 Raleigh Sprite
Liked 296 Times in 68 Posts
What happens when you put bullmoose bars on a classic road bike? I am really tempted to find out!
If I proceed with this project I will likely go with a triple up front for improved climbing capability.
The thing is that the frame doesn’t fit me. Does anyone have something similar in 21.5 inch frame size (c-t) that you want to trade? This one is 23.5 in. If I build it I want to ride it!
P.S. This is a 72 Raleigh Super Course with nervex lugs. Straight gauge 531 main tubes.
cjefferds is offline
Likes For cjefferds:
Old 05-22-24, 12:59 PM
  #7953
santa fe 2926
Bikes: 1984 Chas Roberts Audax tubing?, 1985 Roberts SLX, Mercian 531, 1984 Torpado SLX, 1981/82 Peugeot PSV-10, 1978 Charlie Roberts full touring, 1970 Charlie Roberts 531 road.
Liked 195 Times in 75 Posts
Finally got the 84 Chas Roberts back together. Rode down to shop while passing thru London on way to NZ, Chas said that’s one of my dad’s bikes when I met him. The pound was really cheap, so I asked about a bike to pick up on return in 10 weeks, no problem, since I was not a racer, he offered up an audax, or ‘club’ bike. Asked to be all campag, didn’t discuss tubes. Rode it a lot, but finally had some bad rust on top tube. Took the frame to Groody Brothers, in west KC, around 2012. Fun to see the ATSF Argentine yard, across the street, as I was working as a switchman for them in OKC. Then the frame sat, finally putting it back together. When the bike arrived home, Chas had used Simplex shifters rather than campag, as I later learned was normal. It’s still a nice ride, w/o pump or water bottle, 9.4 kgs on my luggage scale. Ordered decals from Roberts a long time ago, and asked if they knew what tubes the bike had, and they sent some Reynolds Super Tourist decals. It’s as light as any other bike I have, Reynolds 531 Pro, Columbus SLX, and Super Vitus 980, so I wonder what tubing it actually is. Nice lug work.
santa fe 2926 is offline
Likes For santa fe 2926:
Old 05-22-24, 04:08 PM
  #7954
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Liked 6,975 Times in 3,441 Posts
These Campagnolo pedals I recently bought were pretty rough, the left one especially, which was previously built two balls short in both cups.
After an overhaul and some paint, I think they'll work.
SurferRosa is offline
Likes For SurferRosa:
Old 05-22-24, 05:25 PM
  #7955
santa fe 2926
We referred to those we thought lacking in skills on the railroad as two bricks short of a load….
Old 05-22-24, 06:26 PM
  #7956
bikamper
1991 PBP Anciens
bikamper's Avatar
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Liked 489 Times in 187 Posts
We called it, "Couldn't find their way out of a one door room".
bikamper is offline
Likes For bikamper:
Old 05-23-24, 08:55 AM
  #7957
Mr. 66
Mr. 66's Avatar
Liked 1,998 Times in 1,072 Posts
On a recent pickup the bb was installed way too tight. It felt good after adjusting, mostly. Upon removing inspection showed otherwise, a massive amount of grind on the nds, and a deep pit on the drive. Oh this was frustrating, until I realized I had a NIB OEM, YES!
As you can see above the pitting, you may also note that the dust cover allen stripped the hex. I drilled the cover and used a pin wrench for removing.
The dirt, grime, crust, and rub down of Meguires Carnuba Wax cleaned just about all. A rub of turtle wax rubbing compound has freshened the light scuffs on the clear celeste metallic. A light rust stain remains on the fork from the on board computer sensor.
The headset was also very, very tight. That was inspected, not bad, not good, in need of the loose ball treatment for the lower stack.
The original saddle was replaced with a woman’s version of the Avocet touring I. At minimum insert the ITM seatpost is not enough for the 66. A spare ti-flight with the crook Thompson has been put in its place.
The wheels are worn on brake tracks, the tires were mismatched and dry rotted. The spoke’s tension was all over the place, have been retuned. Good news! Rims are straight and true, with nice even tension. The front hub is missing a dust cover on one side, dang. An initial few drops of oil in the bearings tells that side is probably ok. The front felt normal roll
The 600 group is in ok shape, levers and hoods very nice. The shifters are soft between 3 and 4. The front derailer is good. The rear derailer, while it follows commands shifts correctly, does have a lot of clatter needs attention if not hanger alignment should be replaced.
The bar wrap, from top to bottom, needs a rewrap on the lower on the drive side. Here is how it looked on the test ride last night.
I have lowered the stem 1/4” since this picture was taken.
Mr. 66 is offline
Old 05-23-24, 12:12 PM
  #7958
SoCaled
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Liked 4,841 Times in 2,265 Posts
Cinelli - Break down and pack, sending to a friend
Originally was planning to pack small, with both wheels off, box was too narrow to make that happen, had to backtrack and put back wheel on again. Bike is very secure in box and (fingers crossed) just under the dims where the price doubles.
SoCaled is offline
Likes For SoCaled:
Old 05-23-24, 03:33 PM
  #7959
noglider
noglider's Avatar
Liked 3,015 Times in 1,710 Posts
[MENTION=181693]bikamper[/MENTION], I really enjoy displaying reverse snobbery. I've brought a lot of clunker bikes to rides where people have fancy bikes. You can be proud when you keep up with everyone.
noglider is offline
Likes For noglider:
Old 05-23-24, 03:41 PM
  #7960
noglider
noglider's Avatar
It often works out well when you do something as radical as changing the type of handlebars, but not always. I have a 1971 Super Course, same color and geometry. I put on North Road (swept way back) bars, and it didn't work well. The bike was unstable and had floppy steering. It seems to want some weight on the front end. I think bullmoose handlebars will be fine.
Mine is 21-1/2 but I don't think I can use your bigger size. Try it, and you might find it's not as bad as you think. Ideally I should ride a 22-1/2, but up or down an inch is fine.
noglider is offline
Likes For noglider:
Old 05-23-24, 07:32 PM
  #7961
cjefferds
Learning To Fly
My #1 rider is a 21 1/2 Super Course which fits me like a glove. The 23 1/2 size is actually ok given the relatively short top tube. Standover height is the only issue. It’s a bit snug where you really don’t want it to be. 22 1/2 would probably work. But I have almost everything I need so why not? I’ll enjoy the build and will be sure to take it on at least one repack style off-road bomber decent before I pass it along to the next owner. That said, if anyone is looking to trade please let me know.
Old 05-24-24, 07:34 AM
  #7962
IdahoBrett
IdahoBrett's Avatar
Bikes: Aluminum and Steel
Liked 652 Times in 212 Posts
I picked up a Schwinn Varsity last fall and replaced the minimum to make it rideable (brake pads, cables, tires). Recently I needed to downsize and listed a half dozen bikes locally. A Schwinn Continental sold lickety split. So I figured if that is what will sell to make room I decided to do a full service on the Varsity. Good thing too as the grease was dry as a popcorn fart. No pitting and all the caged bearings are reuseable.
“Ride like the wind boy! Ride like the wind…”
-The Voice inside my head, circa 1982
IdahoBrett is offline
Likes For IdahoBrett:
Old 05-24-24, 08:00 AM
  #7963
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Liked 1,239 Times in 603 Posts
I have been working on the paint on my FW Evans and I had decided to do it in British Racing Green with yellow highlights. While I was spraying the seat and head tubes with the yellow, I like how it looked so much that I was tempted to keep going and paint the whole bike yellow. Ultimately, I decided to stick with my original plan, but I think I know what my next project will be.
Pompiere is offline
Likes For Pompiere:
Old 05-24-24, 08:38 PM
  #7964
RCMoeur
Cantilever believer
RCMoeur's Avatar
Liked 2,331 Times in 1,017 Posts
Spending a relaxing Friday evening engaged in the sordid task of sorting stuff. Finally getting the not-3/8-26 nuts away from the 3/8-26, finding a smattering of seat binder bolts, and making nefarious plans for colorful quick releases.
RCMoeur is offline
Likes For RCMoeur:
Old 05-25-24, 09:40 AM
  #7965
Hajo
Bikes: Several Gazelle Team steel bikes
Liked 138 Times in 44 Posts
Originally Posted by Hajo
Finally begane this weekend rebuilding my Chesini. First I had to fit all new decals, that I ordered from Cyclomondo. This was rather easy fortunately. Then some (Chesini panto) parts of the Campagnolo Nuovo Record groupset have been put on. I will need a new set of brake lever hoods, a smaller inner gear for the front (the current 53 - 48 does not fit) and a new set of tyres. Most have already been ordered, such ad the Vittorio Rubino Pro Graphene 2.0 duo pack tyres. Pics will come soon!
Some pictures as promised.
About 90% complete now. New tyres fitted and a period correct bottle holder. New hoods for the brake levers and a new chain on the way.
The 48 teeth inner gear changed for a 42. Nice panto outer gear with plenty miles left.
And the unmistakeble Chesini down tube shifters.
The frame has not been repainted so some marks and scratches add to its character!
Hajo is offline
Old 05-25-24, 01:51 PM
  #7966
IdahoBrett
IdahoBrett's Avatar
Finished up a rehab on a 73 Schwinn Varsity. I went for a ride to the neighborhood baseball field and stopped for a photo op.
Old 05-25-24, 09:23 PM
  #7967
RCMoeur
Cantilever believer
RCMoeur's Avatar
Spent much of the day on work for a client preparing for an upcoming meeting, so it's nice to unwind by getting the fixie ready for tomorrow's club ride. Plus peeling sun-wrecked covers off some old saddles, and stretching a few new covers on to extend their useful lives.
RCMoeur is offline
Likes For RCMoeur:
Old 05-26-24, 06:34 AM
  #7968
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Liked 3,263 Times in 1,645 Posts
bikamper that looks like a cool motorcicle Mr. 66 Beautiful LImited! I love that Metallic Celeste which was only used on two models.
It’s a chilly start to day here on the edge of the prairie and they are calling for storms about the time it gets warm enough for me to ride. So I'm going to at least try and keep mostly on my feet doing stuff. No not housework I have more important things to do. Poor Samantha got booted from the stand and Barbara Batavus is up to get a new tire.
Not sure how many miles are on this old Rally. I had the wheels built around 2003 from some almost NOS rims and hubs from a warranty bin or something, but they didn't see much use until arounf 2012 or so
This looks to be culprit!! Not much more than a block and half - tweo blocks from home! I just walked back and grabbed Esmarelda and had a nice ride despite the constant stiff breeze
Finished! I should have switched to tape decades ago, it’s so easy. I must have removed this tire off a wheel I sold or something, it looks in good shape and held air overnight so it’s “good to go”. In the fall of 2022 someone had a big sale on Rally tires so I bought a few and I just mounted he last two for stretching today. I must have done something to me settings or something, I thought I could add music to video on the youtubes.
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Likes For Bianchigirll:
Old 05-26-24, 12:42 PM
  #7969
bikamper
1991 PBP Anciens
bikamper's Avatar
After finishing PBP, albeit poorly; having several 24TTs under my belt, and done retired after almost 55 years in the work force, I think I have earned the right to be a bit of a curmudgeon.
Bianchigirll That motorcicle is more fun than you are legally allowed to have. It attracts old dudes and families with little kids. I let the kids sit in the sidecar so their parents can take the kids pictures. I'll give Veterans rides.
bikamper is offline
Likes For bikamper:
Old 05-26-24, 09:52 PM
  #7970
RCMoeur
Cantilever believer
RCMoeur's Avatar
Moar tube testing & patching! This time with a friend helping. One more bin emptied and 5-6 more to go.
I'm beginning to suspect this tube is just deciding to be a pain in the butyl...
RCMoeur is offline
Likes For RCMoeur:
Old 05-26-24, 11:15 PM
  #7971
etherhuffer
etherhuffer's Avatar
Bikes: Mercian King of Mercia, Surly Long Haul Trucker,81 Fuji Gran Tour SE, 83 Fuji S12S LTD, Voyageur 11.8 chrome, Raleigh R300 Touring, Voyageur 11.8
Liked 713 Times in 269 Posts
My brother in law said Here, take this. I had overhauled it for him years ago but he didn't ride it much. Trying to decide if I should sell it or strip it.
etherhuffer is offline
Likes For etherhuffer:
Old 05-27-24, 05:46 AM
  #7972
djimb
Bikes: Current: '89 Centurion IronMan Master; Projects: 90's Olmo Sintex; Past: '88 Ralleigh Technium 400, '74 Peugot PX-10, '85 Nishiki Tri-A, 80s Bianchi Sport SS
Liked 63 Times in 18 Posts
[MENTION=228769]djimb[/MENTION] I love it when an adult helps a kid to build a custom bike. It's the best kind of bike building story.
It's been really fun! We went to the thrift store and a local shop/museum called Bicycle Heaven on saturday to pick up a couple of parts bikes to finish up the stingray build. got a 20" kids' bike to take wheels and BB/crankset from, and an old beater 3-speed cruiser for the internally geared hub. She's running single speed for now, but I'm going to clean up/overhaul the 3-speed hub and build a new wheel for her.
Originally Posted by daverup
Since I have some experience with a mid 70's Fairlady Stingray, I'll offer a couple of thoughts.
First, our Fairlady (well used) came with the Sturmey-Archer S3C internal geared hub, which was broken. This hub has some rather fragile NLA springs, which are a problem. I did eventually get it sorted out, and it works, for now. The trick is, you need a 3 speed with a coaster brake. I think you can probably buy a new one that would be less trouble in the long run for your kiddo.
Not all of the Stingray forks have the mount for a front caliper brake. You will probably want that too.
The OE crankset was the one piece with bottom bracket. You might be able to adapt a newer 3 piece, but I have not tried.
It would be difficult to adapt the rear fender bridge to mount a caliper brake there, but it is possible.
Good luck with the project!
Thanks for info! The hub I ended up finding on the parts bike is a shimano 333. I only learned recently that Shimano made 3-speed hubs, and I understand that they're more complicated than the proper English 3-speeds, but for $15 for a whole bike, you can't really go wrong. Unfortunately, it doesn't seem like there's a coaster brake, so we'll have to see about a braking solution when the time comes to swap the wheel. With the 20" wheels that are on it now, I'm not sure calipers would reach the rims. I've seen some clamp-on v-brake bosses, but I'm not sure how confident I am in those. We'll figure it out though.
djimb is offline
Likes For djimb:
Old 05-27-24, 06:10 AM
  #7973
daverup
daverup's Avatar
Bikes: A bunch of old bikes.
Liked 1,090 Times in 496 Posts
The only direction I would suggest is to look at the Sheldon Brown caliper brake page for more ideas on mounting,
https://www.sheldonbrown.com/calipers.html
Good luck with that Shimano hub, I've never been into one of those.
daverup is offline
Likes For daverup:
Old 05-27-24, 02:45 PM
  #7974
cjefferds
Learning To Fly
So I teased this build last week. Spent all day yesterday building the bike. Went on a longish mixed surface shakedown ride this morning and really enjoyed it! It’s a bit tall for me but top tube is only 22in so it actually fits me better than I thought. Standover is a bit snug but not uncomfortable.
Old 05-27-24, 02:57 PM
  #7975
sbrudno
Old age cyclist
sbrudno's Avatar
Bikes: Motobecane Grand Record, Motobecane Super Mirage (3x5 speeds), Motobecane Mirage, Atala (unknown model), Peugeot mixte frame Tourist and Schwinn Sport. A bunch more kids bikes. Most recently a Trek Verve One, tricked up for serious touring.
Liked 79 Times in 39 Posts
Only "snug" if you don't come to an emergency stop...
Love the gearing for just about any ride you might like to take!
sbrudno is offline
Likes For sbrudno:
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
