Ways to lighten a steel framed bike?
#101
Liked 2,101 Times
Yikes! My buddy and I thought we were so cool lightening our UO-8s by removing the reflectors, spoke protectors and plastic brake lever covers. Probably got them close to 28 lbs.
My stock 03? Lemond MJ(carbon/alloy fork) hit 17.0 on a bathroom scale without pedals but with cages.
#103
The Space Shuttle tanks were made with an Aluminum/Lithium alloy.
Pure Lithium (like Sodium) is rather flammable, and probably not appropriate for one's frame.
The shape of bonded lugs tends to be a bit different than brazed lugs.
#104
Bikes: 1996 Trek 970 ZX Single Track 2x11
Liked 593 Times
R&E Cycles (Rodriguez) has a bike called the Outlaw, which they claim to be 13.8 lbs (without pedals).
Might be worth reviewing their full-build parts list, to get an idea of what they've done to achieve that, above and beyond the gains from their frame+fork.
Rodriguez Outlaw
Rodriguez Outlaw
Likes For Clyde1820:
#106
With an advertised weight of 19.9 lbs with tubular wheels, I was curious what my Trek 770 weighed. With clincher wheels,two bottle cages, but without the seat bag, it weighed in at 21.09 lbs. With no cages or pedals it would weigh under 20 lbs.
1985 Trek 770 by cb400bill, on Flickr
Also, couldn't miss that pic while on the scale. I just completed my mongrel build '84 760 with heavy Mavic CXP30 32 hole clinchers, same V-flex Masters, standard SPD pedals / total weight 21.1 lbs..
#107
I’ll weigh my 83/85 760 this evening.
#108
I'm seeing notes that the pretty paint job weighs somewhere around 100 grams of wasted weight.
#109
Bikes: A few too many
Liked 2,193 Times
IMHO it is worth the weight.
Best, Ben
Best, Ben
Voltaire
Voltaire
#110
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Liked 97 Times
Best approaches for dumping weight on a steel C&V while maintaining C&V aesthetics are as follows: (IMO)
- Titanium bottom bracket set (assumes replacement of solid axle CrMo)
- Cold-forged crankset (vs. gravity cast)
- Titanium-railed saddle (ex. Selle Flite or San Marco Ti Rolls)
- heat-treated aluminum handlebars
- carbon fork with aluminum threaded steerer (they are out there)
- Stronglight A9 headset
- Titanium TIG quill stem
- single bottle cage (or no bottle cage)
- forged seatpost
- Aluminum chainring bolts
- Lightweight derailleurs and shifters (Campagnolo NR, Suntour Cyclone or Superbe 1st gen for friction shifting; Dura-Ace with downtube shifters for indexed)
- forged single-pivot brakes (vs. center pull brakes).
A focus on reducing the rotating mass can help.
- Swapping clinchers for tubulars (latex tubes)
- Reducing spoke count (ex. 36/36 to 32rear/28front)
- Reducing cross pattern in the wheel build (3-cross front/rear to 2-cross/radial rear/radial front)
- Butted/forged spokes; thinner gauge overall up-front
- Alloy spoke nipples vs. brass
These are the most cost-effective things you can do. Titanium spokes and chains aren't worth the coin. Neither are aluminum rear cogs (as they don't hold up that well). For city riding, expect to destroy more equipment and spend more money on upkeep, unless you weigh 120 lbs. and ride like a butterfly.
#112
Master Parts Rearranger
Liked 2,040 Times
For a fully lugged steel frame (aka the starting point), this is what has worked for me:
Frame, fork, and headset have an combined weight of 3000-3100g or less. Most high end '80s frames will accomplish this.
If using Shimano components, employ Dura-Ace and nothing else. The weight increase from DA to Ultegra will kill your chances, especially with cranks and shifters.
7800 or 7900 DA for high performance yet not stupid expensive (also, 7800 is the most available).
A BB9000 (DA 9000 generation bottom bracket) will be just 66g and not cost much--7800-era BBs are about 98g. Cranksets don't get much lighter from 7800-onward (even 7700 is not super far behind).
Shimano 7900 10s down tube shifters and a brake lever set that is about 260g/pair (BL0R600 levers etc) will take cable and housing weight away up top.
7900-era 10-speed cassettes are incredibly light, even in 11-28t form. Lighter in 12-25t form but only a little. And actually, 6700-era (Ultegra) aren't bad either.
Vuelta Corsa Lite wheels (1657g or so) or similar. Wouldn't want to go heavier. Vueltas are pretty cheap for their weight, and the rims are sturdy (aluminum freehub body/splines...not as much).
Quill stem conversion to threadless stem - 100%. Stem around 100g and handlebars around 250g or less. Seat post around 200g and a saddle less than 275g.
Obviously a carbon fork will give you a lot of weight 'head room' but I'd only advise that if your frame came with no fork, thus freeing you up to do whatever. It's a fun and winnable challenge with a traditional steel fork!
Vittoria Open Corsa Evo CX 23mm tires are 155g or so each! And the tires are like $30 or just over--crazy deal for a really supple 320 TPI tire. I am a huge fan of these. I run regular tubes as well. Standard Shimano SLR cables and housings (or similar).
#113
Did anybody suggest bottom bracket cutouts?
#114
Liked 2,040 Times
I wonder how many grams that saved and if that had any effect on frame rigidity (from those who know!). There certainly is a good bit of metal down there.
#115
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Liked 56 Times
Seal frame and handlebars airtight, fill with helium - or hard vacuum.
Kevlar spokes and carbon fiber nipples.
Kevlar cables and alloy housings.
Shaved tires.
Ceramic ball bearings.
Remove extra pawls from freewheel.
Paint delete.
And wouldn't it be great if someone would invent Delrin derailleurs :-)
Shaved tires.
Paint delete.
#117
I also thought: ride to the top of the highest nearby mountain. gravity is an inverse square- so the further away you are... the less it weighs. Do that every day and you will really start to lose the pounds.
#118
Liked 2,645 Times
Shaved tires.
Paint delete.
Shaved tires.
Paint delete.
#119
Liked 2,193 Times
How about this?
Drill Baby Drill!
Best, Ben
Drill Baby Drill!
Best, Ben
Voltaire
Voltaire
#121
Liked 2,040 Times
One day I heard knocking at my door. I opened it and there standing before me was the Reaper.
"Oh. Hello," I stammered, quizzically. "I wasn't expecting to see you."
"I heard you bought a bike, with the express purpose of lightening it extensively. I just thought I'd stop by and look through it..."
#122
I progressively lightened my old 1986 Fuji Team until it weighted about 19 lbs. I kept scouring local ebay and CL listings buying odd but cheap parts. The results are not pretty - a complete miss-match of brands and eras like Campy 10spd levers (shimergoed) , Durace 9000 rr Der, TRP magnesium brakes (they were cheap), DT swiss hubs (fr "Coda" rr "Specialized). And the paint is cos it was rusting badly and I had a can of gold paint leftover - I didn't build it for looks.
Eventually, the frame was swapped for a trek carbon frame more becoming to its parts but is now built up again as my winter beater, weighing about 21 lbs. Of note, bikes-direct sell an 853 Reynolds framed bike advertised at 16.9 lbs which shows what's ultimately possible if you go all completely modern on parts.
#125
Liked 2,204 Times
Since people are obsessed with round numbers, I have found that it is easier and sounds more impressive, at least in the US, to get a bike under 10kg than 20lbs.
John
John
Likes For 70sSanO:
