Retro roadies- old frames with STI's or Ergos
#101
TCR Advanced SL
Wow this has become my favorite thread. The pics are absolutely stellar. I have an 88 Nishiki Modulus with a 64 cm CrMo Kawamura frame. I have replaced the brake calipers,Rd,Fd with Ultegra 6500. I replaced the brake levers with Shimano Bl R600. Still using the 6 speed cluster and down tube shifters. Until finding this thread I was not going to attempt any further mods ---- But OH Baby!! Think I'll start looking for the rest of those goodies I'll need to make it happen. Thanks and keep the pics coming. Lp
#102
The 7400 der. will only index right with 7400 shifters, dt brifters or other wise. Any hyperglide cassette will work along with any HG hub. the 7402 hubs are the ones that you need to look out for as they are uniglide
#103
Don't call me sir
Bikes: 1954 Holdsworth 3 speed, 1969 Bob Jackson, 1988 Miyata Twelve Hundred (retired), 1989 Schwinn Paramount, 2004 Santa Cruz Blur Classic, 2012 Specialized P3, 2013 Specialized Roubaix Expert Disc
As mentioned in another thread this frame has been compromised. While setting it up with the current components it was found to have stress cracks in the TT around the back cable routing hole. Being as I do not have a frame to hang these parts at the moment, and the cracks don't compromise the ride or my life as of yet, I decided to finish building it up and ride it until safety really becomes an issue. Hopefully soon I will be receiving a 1990 Waterford Paramount frame from my brother-in-law, but until then...
Full 9-speed Dura Ace except:
Sram chain
r550 wheelset
SR Laprade seatpost (heavily polished)
Nitto stem (miyata branded)
Nitto B105 bars
105 pedals
Selle Italia saddle
Fizik bar tape (might as well)
Jagwire housing and cables (which I think looks pretty swift)
Pictures:
Sram chain
r550 wheelset
Nitto B105 bars
105 pedals
Selle Italia saddle
Pictures:
#104
Dolce far niente
Quoted: 20 Post(s)
Liked 18 Times
I really like the Campy Centaur group, very smooth, very crisp, nice looking. I'd go Centaur if you're on a budget, and Chorus if you have the money to spend. Chorus shifters use ball bearings in the shifter mechanisms, Centaur uses bushings.
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
#105
Klaatu..Verata..Necktie?
Quoted: 10641 Post(s)
Liked 12,291 Times
For 2007, Campy changed the guts of the ergo shifters. With Centaur and below they now use a "release" mechanism, like the Shimano STI, so that each throw of the thumb lever only drops you one cog, versus the older mechanism which allowed you to drop multiple cogs at once. This feature was retained on Chours and Record.
I prefer the older system, because when you change from big ring to small ring, you can instantly drop the right number of cogs to put you in the right gear. This is even more important if you go with a compact, because 1) you'll shift the front more often, and 2) you need to drop 3 cogs, instead of the 2 that works for standard cranks.
#106
road curmudgeon, FG rider
Bikes: 1973 Nishiki Professional, 1990 Serotta Colorado II, 2002 Waterford Track
Thanks for the advice guys! I was partial to Chorus.
What would be the weight savings over 8-sp DA STI using the modern 10-sp Chorus?
Is PBK the best place to score the whole group?
Everything works well on the Serotta but after getting the CF Madone the Serotta seems like a tank, but a great handling tank. I don't think it would be worth spending the extra $$$ only to save 1-2 lbs
PS I am already using tubular wheels but might be able to build up some lighter wheels.
#107
Liked 12,291 Times
Ritchey Road Logic, 58 cm, with steel fork
8 speed Dura Ace kit
Ritchey seatpost
Salsa steel stem
Cinelli Nerve bar
32 hole D/A hubs laced to Velocity Aerohead rims
Avocet 02 Air 40r saddle
Look A3.1 pedals
Weight: 21 1/2 lbs
59 cm Battaglin, with MAX tubing (including MAX-bladed fork)
2006 Chorus kit (excepting the RD and SP, which are Centaur)
Phil Wood BB
Chris King HS (threaded)
3T Motus stem
Cinelli Nerve bars
Fulcrum Racing 5 wheels (Not in this picture)
Look A3.1 pedals
Weight: 22 1/2 lbs.
The MAX frame and fork are probably 1.5 lbs heavier than the Ritchey frame and fork.
#108
Quoted: 2953 Post(s)
Liked 3,106 Times
I believe that online you can still find 2006 Centaur shifters with the "dump" feature. Check Nashbar and Lickton.
#109
Liked 12,291 Times
Nashbar is where I got my 2006 Chorus levers.
#110
Dolce far niente
Quoted: 20 Post(s)
Liked 18 Times
FWIW, PBK have SILVER 2007 Veloce shifters, with complete cable kit, for $100 delivered. Hard to go wrong with that - I just received my set for the upcoming Battaglin build.
For the best complete group prices, either PBK or https://www.gvhbikes.com/. Tom at GVH is very competitive, and his group builder tool on the website is very versatile.
S. J. Perelman
S. J. Perelman
#111
Liked 12,291 Times
Details! Give me details!!
#112
Señor Member
Quoted: 1517 Post(s)
Liked 1,140 Times
It will work wit 105 downtube shifters also.
#113
Dolce far niente
Quoted: 20 Post(s)
Liked 18 Times
So, like..... where where you when I was asking about it?
See this thread:
https://www.bikeforums.net/showthread.php?t=363913
S. J. Perelman
S. J. Perelman
#114
Liked 12,291 Times
I wouldn't have been much help anyway - I don't know much about the brand, and very little about Battaglin himself. I bought mine off Ebay because it was Columbus MAX tubing, in my size, and I wanted to build up a bike from a frame.
#115
Will it really? My info came from Sheldon. Here.
I only ask because I have an extra set of 7400 dérailleurs and and extra set of 105 dt shifters and it would be nice not to have to track down more Dura Ace stuff.
#116
JefPac
Bikes: Iron Horse MTB, Giant Road, Titan Road, Pinarello Montello Road, Amsterdam SA 3-Speed Road, Peugeot SA 3-Speed Road (#1), Peugeot SA 3-Speed Road (#2), Unknown 'hack' TBD
I am in the process of re-inventing my bike collection to consist of STI/Ergo hybrids and SA 3-speeds for road use. Currently, the Pinarello Montello 8-spd Ergo and the Titan 9-spd STI are the only bikes relavent to this thread. The Pinarello is just about done. The Titan is the road warrior and an ongoing work in progress ( I'm not completely happy with the fork and cockpit).
These bikes ride VERY differently but both are vastly superior to the aluminum and composite bikes that they have replaced. 25 years and 25 pounds ago I probably would have expressed a different opinion but here and now, given the way I ride today, they are just perfect!!!
#119
Bikes: Formerly...1978 Proteus, 1981 Miyata 912, 1983 Schwinn Paramount, 1962 Raleigh Sports Deluxe, 1976 Alan Super Record.
I've got a bare pearlescent orange Miyata 912 frame that I planned on putting all the original 600 Arabesque stuff on it. Since then, I've come across a full 8-speed Campy Chorus gruppo for free (granted I sell the frame it's currently attached to). Would it be sacrilege?
#120
Quoted: 1871 Post(s)
Liked 670 Times
Capitalists are always looking to make a buck. Not that there's anything wrong with that...
Take the rear wheel out. Grip the dropouts in your hands. Pull them apart. It will take a lot of strength. Try to put the 130 wheel in. You'll probably need to pull some more, harder this time. Try the wheel again. Eventually it will fit. You will not break the bike. Your alignment, dropouts, etc. will not be ruined. You might be sore in the morning. It's not rocket science.
You will, of course, have to deal with having offending the gods by putting a 130 wheel into your classic bike, but that's your problem to sort out.
HTH!
HTH!
Road Fan
#121
Liked 670 Times
#122
Liked 670 Times
#123
Liked 3,106 Times
#124
Bikes: 1993 Bridgestone XO-3, 1981 Trek 613, 1988 Fisher Montare, 1986 Univega Alpina Uno, 2010 Surly Long Haul trucker, 2004 Rivendell Quickbeam. 1970s Gitane Mixtie (60cm), 1994 Diamond Back Axis TT
Quoted: 61 Post(s)
Liked 34 Times
#125
5' 19"
Early 80's Proteus road bike updated with Shimano STI 105 and all 2007 105 componentry....along with Neuvation wheelset.
https://i60.photobucket.com/albums/h4...s/100_0429.jpg
I own my dream bike, a 2023 DirtySixer MkII 3xl
...and also a 2006 R-14 66cm Waterford road bike, my former dream bike :)
