How much bigger cassette can I put on my bike?
I have a 1996 Trek 2300 with full Ultegra, 8 speed 12-23 HG90 cassette, I have an extra wheel and would like to get a cassette for it so I could simply swap full wheels depending on where I am riding, and would like gearing for climbing, anybody have a suggestion for what the largest cog I could use without changing chains? IOW, how many extra teeth can I put on and still use the same chain? Yeah, I know I should probably get a new chain, but still would like to only swap wheels without running into chain length imcompatibility. From looking at available cassettes, it looks like I will likely end up with a 11 tooth smallest sprocket which will be nice for the opposite direction. 28, 30, and 32 seems to be the next available sizes.
Expired Member
Quoted: 3685 Post(s)
Liked 5,455 Times
With the bike in big/big, eyeball your RD to see how much slack there is. It might be able to handle a 25. The larger cogs will almost certainly require a new MTB RD as well as a new chain.
hmmm, it sounds like even a 26, if I could find one, would be outsized, so then the question is, if I put on a 11-28 with an appropriate sized chain do you think it might be possible to use the 12-23 without changing the chain? Maybe I'd just not have to use the small chain ring when the 12-23 is installed.
Shimano RD-6401? 28, https://velobase.com/ViewComponent.a...d531f&Enum=108
Likes For kcjc:
Expired Member
Liked 5,455 Times
I think there is a good chance a chain sized for a 28 would be OK with a 23. It might be loose in small/small but you don't need to go there anyway.
Quoted: 4212 Post(s)
Liked 3,883 Times
I am not going to do the google searches to find out the exact model Ultegra you have and then find out the largest rear cog it is rated for BUT IIRC your rear der has a 27tooth max spec. Depending on a few factors one can often get at least one more tooth and if you're lucky a couple more. If you don't ride in the small/small combo (or the next small rear cog/small ring) you can size the chain to handle the expanded past the spec rear large cog and the chain will droop a bit in those no-no combos. What you really don't want to do is ever have a chain that's too short for the large/large combo.
Generally when installing a new cassette the chain is strongly recommended to also be changed. Not doing so can cause chain skip (especially on those small cogs), more rapid wear of the cogs, more noise and roughness and retain the chain's old and worn shifting responsiveness. Adding new links to a worn chain is what one does when in a jam and just has to continue on till they can replace the chain. Are you in this position now?
I would install a current cassette with a 28 large cog and a new chain. Adjust the system as Shimano instructs. Then replace that wheel with the other one and see how the longer chain on the older cassette works WRT both chain skip and pulley knock when in that cassette's large cog. You might find out that some B screw adjustment is needed when swapping wheels, or minor der limit screw tweaks.
Are the two wheels running the same hubs? If not then there's one more area of possible "close but not quite right" aspect that would want some slight adjustments. Having installed many hundreds of wheels (especially with different cog sizes) over the years it has been the rare situation where no adjustments were needed and the index setting, the range limits, the chain length and the B screw setting were all perfect. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Thank you everyone for your input, lots to think about Andrew. How I got in this situation is my rim broke, I found a great deal on a whole new wheelset, front and rear (new bearings were sublime!) then I found a good rim at a cheap price, I used a local do it yourself bike shop to install the rim to my old Ultegra hub, so now I have a set of fairly new Mavic wheels and my original Ultegra Hubbed wheels minus a cassette. So I figure add a cassette for climbing.
I see Sunrace makes a 12-25 which I'm pretty sure I could get to work with the same chain, better, but not much over a 12-23 for climbing.
Really Old Senior Member
Put the chain on BIG:BIG and measure how much "slack" you have. You want a minimum of 1". (one link SET)
Likes For Bill Kapaun:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
What are your Chain ring sizes? is the derailleur the RD-6401 mentioned? if so then it has just enough room for the 28 tooth low gear cassette BUT you then only have enough WRAP(slack take-up) for 11 teeth difference in the front... 28 total Wrap..
I'd set the chain length with the small/small method and then you can swap back and forth with no issue.. but only IF that front jump is 11 teeth or less... you MIGHT squeak by wit a tooth or two extra wrap, but it can be iffy... 53-42?.. you're good to go.. 52-39?.. not so fine.
Likes For maddog34:
53/39 so what do you say now? I am guessing no
Quoted: 1565 Post(s)
Liked 1,739 Times
You can read the Shimano documentation for yourself:
https://si.shimano.com/en/pdfs/si/U-...000-00-ENG.pdf
If your crankset has 52/39, then you are limited to 12-27 in the back, to keep the total capacity <= 28 (total capacity = front difference + rear difference)
Likes For icemilkcoffee:
If you don't want to change chains, then you cannot change to a bigger cassette. A bigger cassette requires a longer chain. If you keep the same chain, your derailleur will break the first time you try to ride your bike.
Likes For Yan:
Quoted: 1403 Post(s)
Liked 1,901 Times
back in the 90’s I ran 12-25 on one Ultegra bike and 12-28 on two other Ultegra bikes ...
53-39 chainrings (possibly 38t on one) ... all worked well
pictured is one of the bikes with 12-28 ... (XTR 12-28 cassette)
Most rear derailleurs can handle 12t to 34t cogs at the rear and manage the chain tension throughout that range. I had a 11-42t cassette and when I changed it to a 11-34t one I replaced the rear derailleur to one with a shorter cage for crisper shifing.
A larger cog means more chain length is needed and the derailleur needs to cope with that extra chain and maintain enough tension to keep the chain tight enough to avoid problems.
Quoted: 1825 Post(s)
Liked 1,699 Times
However, you may need a longer chain for the larger cassette. Going from 23 teeth to 28 teeth for your large rear cog will require at least one extra double link. Although you will be adding 5 teeth, keep in mind that the chain only engages halfway around the cog so you will be going from about 12 teeth engaged with the chain to 14-15 teeth engaged, a difference of only 2 to 3 teeth
In looking at the info on my cassette, it says the max difference on the chain rings is 13, yet, my bike came with a 14 tooth difference. 53/39
it seems most cassettes nowadays have an 11 tooth small cog, the info says 12 is the minimum.
When all is said and done, I don't know that I need an 11 tooth cog, when I was younger I'm sure I could have used it but now nearly all my riding is on paved trails (old RR grades and city) RR grades are not steep, where speeds are not high. Typically the hills around here are at rivers where the altitude gain is about 200 feet over 1/4 to 1/2 mile at the steepest . If I go out west I can take my mountain bike which can handle the steeper hills over a longer distance. So I am thinking I really don't need more than a 26 cog anyway, the 23 has served me well for a quarter century, I was just thinking as long as I get an extra cassette, might as well get different gearing.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
I have nothing to add to answering the question. But, I have caught a lot of fish on Zara Spooks. And a fun lure to fish with.
