Roval Fusee SL - 11sp capable?
Ahh, you go first!
Bikes: 2014 Tarmac SL4 Pro; Intense T275
As the title says, can anybody help me verify if the Roval Fusee SL rear hub is 11sp capable?
Quoted: 6193 Post(s)
Liked 4,810 Times
Many 10 speed hubs are. Depending on whose 11 speed cassette is you wish to put on them. Some aren't. I've no idea specifically about Roval's.
Are they the same hub on all Fusee SL's or is that more about the rim and they come with all sorts of hubs? If you aren't certain whether it will fit an 11 speed cassette, then make sure it's a hub you can at least change the free hub on.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Do you have the wheels now? Is there a cassette on the wheel?
Ahh, you go first!
I do have the wheel set. It came off a 2013(?) Tarmac Pro. No cassette on it at the moment, but I'm guessing an 11sp cassette will work if I use a spacer? FWIW, the plan is to build up an old Tarmac for the trainer and going full R7000 / 105 group set on it.
Really Old Senior Member
Do you have other bikes that you can compare the FH length to?
Sometimes the answer is under your nose.
Bikes: lots
Liked 2,932 Times
Wait...what? Why would an 11 speed cassette need a spacer?
Ahh, you go first!
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
I have a 2010 set of Roval Fusee SL 25 wheels that came on my Roubaix. I've been able to find replacement freehubs for my other wheels, but not Roval Fusee SL 25 wheels. I'd love to be able to use them , even if it means buying a new freehub. My Google-fu fails when I try to figure out if I can use these wheels. Hoping someon ehere can provide info for the OP and my own bad self.
Quoted: 837 Post(s)
Liked 1,061 Times
Contact Roval and they may know the answer. Roval Components
