Motobecane!
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Motobecane!
I was moving bicycles around the house and this Motobecane ended up on my stand…
I believe it’s a C5 from old research done…might be a C4 with the Huret dropouts…
Anyhow, the only numbers on the bottom bracket is J68.
I’ll be posting more pics and info as I get back to this bicycle…I’m working on other bicycles at other areas…
Thanx…
Thanx…
Quoted: 3814 Post(s)
Liked 3,345 Times
___
WOW!
just look at this work station boys & girls!
looks like an exhibit one might see at a trade show
recall mention of all bikes not ridden cleared out prior relocation to St. Cloud
seems strange to receive a new thread from billnuke1 which does not include an image of our Massimilliano
___
WOW!
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
Please do not clamp it by the middle of the top tube. That is the thinnest tube, in the thinnest spot.
Clamp near the top of the seat tube.
Motos generally were the nicest bikes in their price point compared to Raleigh / Peugeot / others.
Definitely the nicest ride.
/markp
/markp
Likes For mpetry912:
Can't help with the ID. I presume you've seen (or already knew) this, but just in case:
https://www.sheldonbrown.com/velos.html#bottom
There's a para near the end of this section concerning Motobecanes. Per the late Mr. Brown, apparently many Motobecanes used Swiss-threaded BBs instead of French-threaded ones.
I believe I've read elsewhere that the change from French-threaded to Swiss-threaded BBs on Motobecanes occurred sometime during the 1970s, but I don't think I've ever seen a specific year mentioned.
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
First year of cable braze on was 1978. Not sure when braze on shifters were introduced, 1980-81?
Columbus used from 1978. This was after the Reynolds 753 debacle where (so the story goes) they were refused tube from Reynolds because they didn’t submit two frames for destructive testing which Reynolds required from all manufacturers who were supplied 753 tubing to apply certification.
Sometimes you get a stamp inside on the fork tube, which might help.
Swiss thread can run to early 80’s I believe. If it is and you buy one, pop a photo onto this thread.
https://www.bikeforums.net/classic-v...bb-cup-id.html
Look for the thread Motobecane serial numbers.
https://www.bikeforums.net/classic-v...-database.html
Brochures here.Look at ‘81 Le Champion, close?
bulgier.net - /pics/bike/Catalogs/Motobecane/
Quoted: 69 Post(s)
Liked 122 Times
Motobecane C4 spec sheet
Motobecane C4
Motobecane C4 brochure, these are hard to find on the web, maybe I am not using the right search terms!
Quoted: 350 Post(s)
Liked 782 Times
/markp
/markp
The decals on the seat tube on this frame are kinda torn up because someone didn’t tighten clamp up tight enough to keep the frame from moving in the clamp…the older style clamps were hard on the frames,too!
Each of my shops has one…
Likes For billnuke1:
Quoted: 350 Post(s)
Liked 782 Times
Not clamped tightly, just kinda balanced there… if I’m actually working on the bicycle I’ll either clamp on the seat post or swap the seat post out for ISC-1, internal seat tube clamp…
One indoor shop, two stations…One outdoor shshop, two stations…that leads out to a covered patio, soon to have a sturdy multi purpose bench that will use the tools from the outdoor shed/shop.
Multiples keep me from running in and out to find “that tool!”
Quoted: 5888 Post(s)
Liked 3,471 Times
Quoted: 350 Post(s)
Liked 782 Times
Sorry! Not bragging!
Using the extreme clamp on this new orphan that showed up on my doorstep…I had planned to do a quick once over then ride it. Too much of a Frankenstein! Otherwise a perfect scenario for the seat post thingie!
Quoted: 350 Post(s)
Liked 782 Times
It’s been kind’a Frankensteined…
Complete Ultegra groups are relatively inexpensive…parts were swapped out and others-left shifter doesn’t work-have some road rash.
I’ll check the front and rear drop outs for true then take it from there…
The price was right!
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
Nicely built frame, very handsome, I think it looks better without the diagonal stripes.
