Show Us Your 650B Conversions
#676
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
( @noglider, if you'd rather I didn't, I can take this down.)
#677
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
$25 for a set of Pacenti rims with Compass tires - plus a Surly bike! Great find - and put to good use modifying your 412.
I'll never get tired of seeing 650b Treks - you've got a beaut. 42's with room for fenders - very nice - and I like that front rack.
Good to see the 650b conversion thing is still alive.
#678
Quoted: 7348 Post(s)
Liked 2,470 Times
This is driving me crazy. How about now?
#679
Liked 2,568 Times
Works for me, @noglider! (In two ways.)
#680
Liked 2,470 Times
The tires are Pari Moto 38mm. The wheels are cheap hubs with Sta-Tru rims. It has a 7-speed freewheel which is odd because I have 10-speed shifters. I plan to renovate the drivetrain eventually, but it works OK so far. I might not keep 650b wheels on this bike but put them on a different bike.
#681
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
@noglider....
fantastic creation! i really like how it all looks together. what length of stem did you use? maybe 7cm?
#682
Liked 2,470 Times
@noglider....
#683
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
in my experience, the veloce levers seem to me to have a longer reach when resting on the hoods. i mean, the lever body is pretty long. in which case, to me, they seem to work better with a compact bar around 80mm reach when trying to optimize fit/reach. just a consideration
#684
Liked 2,470 Times
#685
Quoted: 21 Post(s)
Liked 16 Times
650b conversion for Switchback Hill tires
In process: https://www.flickr.com/photos/216244...57711839216552
This will fit 650b x 48 (that's 48, not 42) Switchback Hill tires and RAID brakes.
Recent vintage Columbus SL main triangle so conventional diameter and 858 walls. The rest is either Columbus or True Temper.
Rinko and head/tail light configured.
73 HT, 73 ST, 565mm TT, 570 ST (C/C), 825mm Stand-over, 450mm Chainstays, 75mm BB Drop, 67mm Fork Rake, 33mm Trail, 126mm Rear Space (or 130).
Likes For Jmclay:
#686
Quoted: 457 Post(s)
Liked 462 Times
Can somebody give me the width and height measurement of a Pari-Moto on a Pacenti rim?
I've got a conversion in mind, but it will be tight with a Pair-Moto.
#687
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
But hold on, I'll get you some numbers.
Edit:
Pacienti Rim,
"38" tire is 38.5 mm wide, 334 mm radius
"42" tire is 41.5 mm wide, 337 mm radius
Uncertain WTB disc rim
"48" tire is 47.3 mm wide, 340 mm radius
I used a pretty cheap wooden ruler, so caveat emptor.
Likes For rhm:
#689
Quoted: 5888 Post(s)
Liked 3,471 Times
As shared in a different thread. Bernard Carré frame tarted up as a Sauvage-Lejeune. Wheels and brakes courtesy of my tandem that does not get ridden. I may go back to the 47/34 or a 47/27 double on it. Fenders are a possibility, but they complicate transportation. Got some nicer tires for it also.
DSCN2596 by L Travers, on Flickr
#690
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Mafac Raid. Maillard 700...nice hubs.
#691
Liked 3,471 Times
#692
Forgot to post my Trek 614 last year! A few changes made since this photo, few more coming!
Likes For natterberry:
#693
Liked 3,471 Times
Likes For bikemig:
#694
Likes For jlaw:
#695
blahblahblah chrome moly
Quoted: 1176 Post(s)
Liked 2,572 Times
I agree those 3-pulley mechs are cool, but how about this (below) with a wider gear range, and a vintage Campy short-cage 2-pulley:
650b conversion of a late-'50s Follis road racer. Zero original parts -- mostly '60s and '70s gear with some modern stuff, like rims tires and spokes.
Derailleurs are Campy Record (the one before "Nuovo", circa '65), which I hope will be forgiven on this French bike because it came with Campy dropouts. Rear mech is a hybrid "frankenderailer", with a "Sport" top knuckle riveted to the Record parallelogram, to give it a sprung upper pivot (like a Simplex). That lets it shift a much wider range. That's a 14-30 in back, 26-36-46 triple. Stock Record only reached to about 26t, and with a much smaller range in front.
The head lugs have bands around the front with cut-out letters that say "Follis" (top lug) and "Lyon" (down lug).
Sorry, I didn't take a picture of that.
The lugs have brass fillets added around the outsides, filed and smoothed to make the transition radius larger and more swoopy. A time-consuming step only done on a "special" frame. I have seen lots of Follises, never seen another one this deluxe. The Nervex Pro crown also has some brass built up and filed down in a couple places to make the shape more aesthetically pleasing. The fork blades are rapid-taper, and "pencil-thin" (what the Brits called it), small diameter through the curve. I think Reynolds called them the "Super Resilient" model. These blades are fully 2 mm smaller diameter than Kaisei "Toei" blades, the smallest diameter you can get today. Internal rear brake cable in the toptube, with nice braze-ons at the entry points. Curved bridges. Campy dropouts with nicely shaped stay ends.
My plans may change, but so far I'm thinking I'll add braze-ons for the Raid centerpulls & a few other BOs, add rake to the fork, and build a custom front rack.
I like what's left of the paintjob, but a previous owner started sanding it down, to hand-paint it himself, until he realized what a big job that was, so he stopped where you see it now. Decals are almost 100% gone. So I'm thinking braze-ons and repaint.
Oh yeah it came to me with the derailleur hanger sawed off! Gugie called it "castrating" the dropout, maybe putting it a bit strong, but definitely vivid! I brazed on a replacement hanger (Campy part # 80/1), but of course that means the chrome is wrecked on the right rear DO, another reason for a repaint.
More pix here. Album about the hybrid rear derailleur here. Here's the album about the decaleur I made to hold the top of the handlebar bag.
Mark B in Seattle
Mark B in Seattle
Likes For bulgie:
#696
Liked 2,572 Times
I didn't check to see if all those sellers are willing to ship to USA, but I have bought lots of stuff from ebay France, sellers always were willing. Or if there were exceptions, I have forgotten. Brakes are usually not too expensive to ship, but ask for a shipping quote before you commit to buy..
#697
Liked 3,471 Times
[QUOTE=bulgie;21307020]I agree those 3-pulley mechs are cool, but how about this (below) with a wider gear range, and a vintage Campy short-cage 2-pulley:
Cool bike and neat running gear. I wouldn't mind finding a Follis either! [QUOTE]
#698
Quoted: 1136 Post(s)
Liked 650 Times
Very cool bike, bulgie . I agree, does deserve some braze-ons for rack and brakes, and the paint flaws are a perfect excuse. Would you go back to that metallic blue?
#699
Liked 2,572 Times
I'm pretty boring when it comes to paint. For my first three frames I ever made, I told the painter "blue", "yellow", "red". He of course asked "which blue" and I just told him to use whatever he liked and had in stock; same with the yellow bike and the red one. As long as it slows down the rust and doesn't hide the frame workmanship too much, that's good enough for me. But this Follis probably deserves to be brought back close to its original glory. I'm not going to rechrome it though, that's a bridge too far.
It's not a show bike or an investment, it's a rider, so I may just throw a one-color powdercoat on it. My wallet is not so fat that I can throw money around painlessly. At least PC will protect it for now, and I or someone else can still restore it all the way later.
Mark B
#700
Liked 650 Times
Mark B
Mark B
