How to center these brakes?
I am tuning this bike and having trouble getting the brakes not to drag. Is there a way to recenter the brakes location? I have tried the bolt behind the fork. It seems to work but slips back off center after the brakes have been applied.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12777 Post(s)
Liked 7,694 Times
See the flat sides on the piece of metal the spring is coming out of? Get a cone wrench (usually 13, 14 or 15) on that and hold it in place while tightening the nut behind the fork.
Quoted: 4208 Post(s)
Liked 3,874 Times
LoP has it right, Likely the center bolt's flats are for a 13mm thin wrench. However the comment I pick up on is " I have tried the bolt behind the fork. It seems to work but slips back off center after the brakes have been applied." I wonder if the recessed nut (what the OP calls a bolt) is not tightening down enough, as in its bottoming out before being fully tight in the fork crown. Also is if the star/anti turn washer/spacer is in place between the center bolt and the crown on the front side of the crown. Andy
AndrewRStewart
AndrewRStewart
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
First, make sure that the spring carrier stays centered and doesn't end up canted to one side or another. I'm only slightly embarrassed to admit that mine is shimmed - with a bit of cut-off zip tie end.
Next, you need to balance the spring tension, which can mean unhooking the ends of the springs and bending them outwards, then re-hooking them.
Of course before doing any of this you should make sure that the cable moves freely in the sleeve (lubricate if necessary) and that the routing of the sleeve isn't biasing things to one side.
Liked 3,874 Times
AndrewRStewart
AndrewRStewart
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
Is the housing long enough? Show us a pic of the entire cable routing. Looking at that ferrule inside the barrel adjuster makes it seem too short. Especially with aero brake levers, the housing needs to be almost perfectly sized.
Likes For SurferRosa:
Thanks guys you have given me an idea of what is at work with all these parts now. I have owned this bike since last century but only now figuring out how to make this adjustment. I usually just trued the wheel to the brakes.
This is part of a total overhaul of the front with new cables all around. I do think the springs are tensioning it in one direction. I am doing both front and back brakes.
So I put a 13mm cone wrench on the nut with spring, lossened the bolt positioned the brakes with the cone wrench and retightened the bolt. Look good so far.
The bike is currently being used on a trainer so it is all working well but want it to be working well in the spring when it is time to hit the road.
Here is the photo of the cables. I decided after the fact to add the aero bars.
Looking for suggestions on how to route these cables better.
I think the centering problem is solved with holding the nut in front of the fork and tightening the bolt. I still need to rewrap the tape to get it right. I will change the lengths of cable and routing a bit to get it right for real riding in the summer.
Quoted: 4806 Post(s)
Liked 3,930 Times
It looks to me like you could get a slightly better front brake cable run going over the left aero bar. I doubt the brake will care but to my eyes, a little cleaner. The housing a touch shorter might make for better bend if you stay under the aero bar. I'd disconnect the cable, pull the housing down just enough to clear going under the bar and look at the exit from the handlebar tape. Is the housing being forced down? Will it develop a bend there? If yes, I'd go over.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
As others have noted, there should be flats on the pivot bolt to accept a thin wrench, like a cone wrench. Center the caliper using the thin wrench, then tighten in place with the mounting bolt on the other end of the pivot.
Likes For JohnDThompson:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Or get a Park OBW-4. Much easier to use than a cone wrench. If the brake doesn’t have wrench flats, use a Park OBW-3. Not as nice as the OBW-4 but better than a cone wrench.
The cone wrench worked flawlessly. I am going to go back and adjust the handlebar wrap and the cables so the brake won't have any external pressure from the cables.
In 22 years of owning this bike I never thought of doing this, I always just trued the wheel to fit. This centering option is great. Thanks guys.
Likes For Wyoguy:
Quoted: 431 Post(s)
Liked 460 Times
This was the culprit on more than one occasion for me. Either too long or too short, both can force the caliper out of center.
Likes For tFUnK:
Liked 4,218 Times
Stuart Black
Stuart Black
Old fart
Liked 3,400 Times
Sometimes lower pressed cup overhang prevents even the Park offset brake wrench from reaching the pivot bolt flats. That's why Campagnolo started shipping their brakes with two star washers to put on the pivot bolt in front of the crown, to move the flats out to where a tool can reach them.
Liked 4,218 Times
That’s where the OBW-3 comes in handy. It hooks into the springs. I’d use the other wrench first but the the OBW-3 has its uses.
Stuart Black
Stuart Black
I have another old steely, hanging up on the rafters. When I pull it down I will see how the brakes work and look into a specialized tool for it if needed.
Liked 4,218 Times
A pin punch will work as well but it is very, very rough.
Stuart Black
Stuart Black
Quoted: 117 Post(s)
Liked 71 Times
It also wouldn't hurt to periodically oil the ends of the return spring where they tuck into each brake arm. Makes them quieter and smoother operating too. Nice Marinoni btw, must be a real rush to ride. Okay, bad Canadian joke.
Quoted: 966 Post(s)
Liked 1,629 Times
Am I missing something?
Likes For Ryan_M:
Are those required on all side pull brakes? Neither my front nor rear brake has one. I will check with the local shops to see if they have one in stock.
Thanks
I put it on correctly and my speed on the trainer has gone up dramatically.
Thanks
